Author Topic: 2 questions  (Read 1111 times)
Offline torrinh
  • If you don't ride in the rain, you don't ride.
2 questions
« on: May 20, 2009, 08:13:04 AM »
First, will piston rings from K0-K5 fit a k8 cb750?
Second, where's the best place to find .25mm oversized pistons for a cb750K8?
1983 Kawasaki GPZ 750
1978 Honda CB750K w/ 1976 CB750F1 motor
1979 Suzuki GS550L
Offline torrinh
Re: 2 questions
« Reply #1 on: May 20, 2009, 03:04:42 PM »
bumpity bump
1979 Suzuki GS550L
Offline Old Scrambler
Re: 2 questions
« Reply #2 on: May 20, 2009, 03:59:13 PM »
Second ..........try HONDA.  The difference in the pistons from the K0-K6 models is a very small amount of added compression.  If you can't find oversized for the K8 the 1st-3rd over sets for the ealier models should work.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
upperlake04
Re: 2 questions
« Reply #3 on: May 20, 2009, 04:03:41 PM »
  If the Honda part numbers for the rings are all the same, they will be interchangeable. You can check that in the fiche at Crotchrocket.com
  The Honda dealer would be a good place to start for the pistons.
Offline Clyde
Re: 2 questions
« Reply #4 on: May 20, 2009, 10:13:46 PM »
No the early rings will not fit- the later rings are thinner.
The very early K rings had one piece oil rings which were changed to 3 piece oil rings
The compression on the K0-K6 is the same. The F/F1 compression was increased slightly and this engine was then used with the K7/K8.
The thinner rings were introduced during the 75F and then Honda used the same thickness rings for the F1/F2/K7/K8. Unfortunately they made a number of changes, mainly suppliers and there are several part numbers for the later rings
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
