Author Topic: Quick carb question  (Read 728 times)
2tall
Quick carb question
« on: June 03, 2009, 05:04:37 PM »
Hey again,
I am finding some conflicting info on the web on float bowl adjustment, so I wanted to see what the consensus was on here.
1976 CB550 all stock.
Question is: Do I set the float height to 22mm when the floats are resting, but not compressing the needle valve (with the carbs on their side at a slight angle) or with the floats resting their full weight on the needle and compressing it slightly (carbs upside down).
Thanks!
Paul
Offline Inigo Montoya
Re: Quick carb question
« Reply #1 on: June 03, 2009, 05:13:10 PM »
NOT compressing.
