Author Topic: Oil tank drain washers  (Read 3806 times)
kaysystems
« on: June 05, 2009, 05:22:42 PM »
CB750 K0
What washers are supposed to be on the oil tank drain plug? The parts manual suggests two, of different sizes.
I have on cupped washer that leaks.
thanks guys...
David
Offline Alan F.
Re: Oil tank drain washers
« Reply #1 on: June 05, 2009, 05:27:19 PM »
They're really dirt cheap, I'd order up a set, the other one will probably fit your sump's drain plug.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: June 05, 2009, 05:39:33 PM »
They are 12mm washers, same one is used for the oil pan drain as well. Buy a fist full, change them each time is my advice.
Offline Jonesy
  • Shop Rat
« Reply #3 on: June 05, 2009, 05:43:41 PM »
The Honda dealer looked them up for me when I bought other oil change supplies. They recommended replacing them every other oil change.
kaysystems
« Reply #4 on: June 05, 2009, 05:46:14 PM »
Thanks guys.
Obviously I have a non-standard washer. No wonder it leaks.
David
Offline Johnie
« Reply #5 on: June 05, 2009, 07:18:38 PM »
Thanks guys.
David
Sounds like you have the non-standard.  You want what is called a "crush" washer.
« Last Edit: June 06, 2009, 03:00:07 AM by Bob Wessner »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
WHALEMAN
« Reply #6 on: June 06, 2009, 07:13:28 AM »
Yours is standard just crushed down all the way. They cup when smashed down. Have to cut off carefully with a hacksaw. don't need to change every other oil change, just when crushed way down. Dan
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7 on: June 06, 2009, 07:31:53 AM »
Sounds like I waste some money changing them each time. I wonder what I will do with the extra $1 or so a year? Where's Bernie Madoff when you need him? Oh, yeah, prison.  :D
« Reply #8 on: June 06, 2009, 09:02:47 AM »
I think I used to get them off with Vise Grips..IIRC
Grab the OD of washer, and turn bolt out with wrenchorsocket.
I reused them a lot, just wipe them off and make sure they are clean, I never torqued them real tight, if you are careful you will find they dont have to be real tight, but check a few times to see that they dont loosen.
Offline Steve F
« Reply #9 on: June 06, 2009, 09:15:16 AM »
I have yet to replace them  ::)  Maybe I should look into replacing my non-leaking washers?
WHALEMAN
« Reply #10 on: June 06, 2009, 03:49:10 PM »
If they have never been replaced they should be. Both drain plugs use the same crush washer. Dan
Offline 333
  • Time for change
« Reply #11 on: June 06, 2009, 06:00:52 PM »
If it ain't broke, don't fix it.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Johnie
« Reply #12 on: June 06, 2009, 07:28:45 PM »
Totally agree with that statement!!!
Oshkosh, WI  USA
WHALEMAN
« Reply #13 on: June 07, 2009, 04:31:54 AM »
Your right don't fix it until it starts leaking oil on your tire at 80MPH. Good advice. Dan
« Reply #14 on: June 07, 2009, 08:28:41 AM »
They dont just start leaking. They usually leak from grit getting in between the surfaces while tightening. Thise should have been wiped off clean anyway.
 I from experience know better that to try to change out a non-leaking part, just because it is a "good idea". That is just asking for something to go wrong.
Offline Steve F
« Reply #15 on: June 08, 2009, 07:53:06 PM »
I will sometimes buy new parts like this "just in case", and end up not using them for years.  Then there are other times I totally miss the obvious until it's too late.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #16 on: June 09, 2009, 06:34:06 AM »
I guess I consider these washers consumables, so I probably won't change my extravagant ways.  ;) However, particularly in the case of the oil pan washer, how many posts have we seen re: cracked pans, usually around the drain hole. Guess what's causing it?
« Reply #17 on: June 09, 2009, 07:12:58 AM »
Overtightening..
 There comes a point, when checking a leaking assembly , that if it is already tight, you should realize, the sealing element needs replacing. Further tightening usually causes damage. (espescially in aluminum)
 That being said though, Carefully cleaning the grit off the washers, has resulted in long life for many.
 I am trying to recall, if I ever changed them in at least 50 K on cb 750,s .
Offline kach_me
« Reply #18 on: September 19, 2009, 01:45:03 PM »
Would a worn out washer cause the bolt not to tighten?  I changed the oil today and the bolt would get finger tight then loosen as I turned it with a socket.  At finger tight, it seems to seal the oil while running but leaks fairly badly when not running (a drip every 20 seconds or so).  I am afraid that I've got stripped threads.  Any thoughts?
1976 CB 750K - Stock / No mods (yet).
Offline mystic_1
  • 1970 CB750K
« Reply #19 on: September 19, 2009, 01:46:38 PM »
Stripped threads or a cracked bung.
mystic_1
- John Augustus Shedd
Offline BVCB650
  • Too Much Thin Air
« Reply #20 on: September 19, 2009, 01:48:01 PM »
Mine doesn't have one. Just the tapered bolt. The one on my Jeep has lasted over 150K miles with no leakage. It is copper. I know I'm supposed to have one by the drawings, but I don't think my plug is OEM.
« Last Edit: September 19, 2009, 01:52:20 PM by BVCB650 »
1979 CB650, 25K miles, recently refurbished
Offline kach_me
« Reply #21 on: September 19, 2009, 01:52:04 PM »
mystic_1
In the pan?  If stripped threads any thoughts?  heli-coil?  or oversized bolt? Or am I looking at a new pan?  Lots of questions.  Oh yeah, '76 750K with no mods.
Offline mystic_1
  • 1970 CB750K
« Reply #22 on: September 19, 2009, 02:17:16 PM »
If I had a pan with stripped threads I'd prefer an oversized bold rather than a helicoil or other insert.  OTOH a good insert would be stronger than stock and would allow you to use the stock drain screw and crush washer.
YMMV.
mystic_1
Offline kach_me
« Reply #23 on: September 19, 2009, 04:38:30 PM »
What oversized bolt would you use?
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #24 on: September 19, 2009, 04:47:32 PM »
we replaced them every oil change at the trump/beemer dealer.
Mark Twain - Notebook, 1894
