Author Topic: No top end power  (Read 788 times)
Offline worlddrum13
No top end power
« on: June 26, 2009, 08:12:09 AM »
im a proud owner of a 76 750k but i am having troubles with it. i had it running perfect about 3 weeks ago until my rear tire went. its been sitting for a little over 3 weeks and i replaced the tire to find that its running very very poorly. it has no top end power at all. it seems to run fine at lower RPMs and it seems to be running on all 4.
it got rained on for a couple of days it was sitting and it also tipped on its right side while i was at work (no visuall damage, thank god) my first guess is maybe the condensers got damp? i dont know, im not very good at this. any help?
75 750 k6
Offline Gordon
  • 750K1, 550K2
Re: No top end power
« Reply #1 on: June 26, 2009, 09:44:20 AM »
First off you should verify that it's actually running on all four cylinders.  Touch all the pipes as it's warming up to see if they'r all heating up evenly.  These bikes can run surprisingly well on just two cylinders and many before you have been fooled.
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: June 27, 2009, 10:01:34 AM »
Any progress?
Offline worlddrum13
« Reply #3 on: June 28, 2009, 09:51:16 AM »
ive dont the obvious (new plugs, gaps, points, etc) all the pipes are hot although i did notice one that wassnt as hot( still extremely hot) after i rode the bike for a couple minutes. my guess is, is that that cylender is the one thats cutting out at higher RPMs. any idea why. if it was the coil, wouldnt the other cylender that runs off that coil do the same thing?
thanks
75 750 k6
Offline moham
  • .fnord.
« Reply #4 on: June 28, 2009, 10:02:58 AM »
You say it got tipped over, you might want to check carb floats to make sure everything is moving freely. Worth checking anyhow...
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
