Author Topic: 3/4-full throttle: sputtering and VERY low power  (Read 31236 times)
Offline BlackMax
« on: July 09, 2009, 03:39:05 PM »
Okay, I just got my bike back today, from my mechanic. He was to put my new head on the bike and tune it "to perfection".
Yea, well, it starts up nicely and sounds good.....revs well, etc.   However, when I jumped on it for a short ride, I cracked open the throttle only to have it basically die, then slightly catch for a second then stumble and sputter.......no power!  It acts a little like a bike would with the choke on.  However, my choke is not on, in fact, if I pull it out, the engine dies.  So, it's not the choke.
I am leaning towards the idea that somehow, the thing is not getting enough air.....but maybe I'm looking in the wrong place.  I guess it could be anything including a clogged petcock screen or something like that.   Maybe I should even fill the tank with fresh gas, but that's a long shot.  What would cause a complete lack of power when under load and with the throttle 3/4 or so, or more open???
Yes, the mechanic should be responsible for making it right.....but that's a whole other story, that I may go into at some point.  I basically got screwed and am trying to cut my losses.  Tip-  NEVER pay someone before the job is 100% done to your satisfaction, no matter how much you think you trust them.    NEVER do it.   ::)
« Last Edit: July 09, 2009, 03:44:26 PM by BlackMax »
1978 CB750SS, 4-1 Yoshi, Pods, 3-angle valve job, ported chambers, ported intake, 41a cam
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: 3/4-full throttle: sputtering and VERY low power
« Reply #1 on: July 09, 2009, 03:42:16 PM »
Firing on all 4?
Whats in your airbox?
No.
Offline BlackMax
« Reply #2 on: July 09, 2009, 03:44:55 PM »
4x K&Ns
Offline Really?
« Reply #3 on: July 09, 2009, 03:48:09 PM »
Maybe you are getting too much air and not enough fuel.  Maybe put the stock airbox back on see what happens.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #4 on: July 09, 2009, 03:56:12 PM »
OK, check to make sure all 4 are firing, and then lets have a look at your plugs.
Did this guy do a carb synch?
No.
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« Reply #5 on: July 09, 2009, 03:56:32 PM »
3/4 to full throttle would be the main jet. That is if everything else checks out alright.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline bikerbart
« Reply #6 on: July 09, 2009, 04:22:14 PM »
that happened to me recently and it turned out that if I switched to reserve I would suck dirty crap from my flaking tank into the petcock and clog the screen.I fixed it and no problems since.
Offline BlackMax
« Reply #7 on: July 09, 2009, 06:11:18 PM »
very interesting.  I happen to be running on the reserve setting, since I left the guy very little fuel in the tank.   I am betting it's getting leaned out, most of the time, but a little gets through, thus the "catching" i'm experiencing.
Let's hope that's it.   Heading down to fill 'er up, and switch back to "on" from "reserve"
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #8 on: July 09, 2009, 06:34:34 PM »
long shot.......compression check.  i just went thru this(seeposts)...and come to find out I had a blown head gasket cause the head bolts were loose and 4 missing.....led to broken rings.turns out my carbs were fine.
MATT
Offline BlackMax
« Reply #9 on: July 09, 2009, 09:24:25 PM »
filled up and switched to "on" from reserve.  It cleared up a LOT; but, it still isn't quite right.  It seems pretty lean above 5000 or so, with a WOT.  It's just not pulling as hard as I'd expect.
I suspect this is one of the problems with guys (or "mechanics") who tune your bike without ever puting it in gear.  No load is a completely different game than with load.    Great, and I happen to not be the best in the world when it comes to tuning carbs (just something I never jumped into).
On another note, the rings evidently aren't seating yet.  I knew that was going to happen.  Let's hope they find their spot in a few miles.
Offline BlackMax
« Reply #10 on: July 09, 2009, 09:26:23 PM »
Yea, all 4 are firing, at least when there's no load. I'll have to pull the plugs and take a look.  I'd expect them to be white.  But then, the rings also haven't seated yet; so, they could also be a bit fouled....but not enough to cut cylinders out.  There just isn't that much smoke.
Offline the technological J
  • deliciouso!
« Reply #11 on: July 09, 2009, 09:27:59 PM »
i had a similar problem one of my floats was a hair low and when it ran out of fuel useally trying to push it in fifth it would lose all kinds of horse power.. noob suggestion by the way what is "WOT"..... heres one from left field.. could the timing be set to the wrong mark and as it advances it acually misses around 5000?
« Last Edit: July 09, 2009, 09:59:06 PM by thegabrielj »
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #12 on: July 09, 2009, 09:36:52 PM »
You can tell the difference between rich condition and burning oil pretty handily. Please go try to flog it, shut it off, and lets have a look at the plugs, wh?
No.
Offline d_soles
  • My two girls...
« Reply #13 on: July 10, 2009, 04:01:06 AM »
WOT = Wide Open Throttle
A.K.A. - The slides in the carbs are fully elevated.
Doug
'75 CB550F - Field Beater at it's best....
Offline BlackMax
« Reply #14 on: July 15, 2009, 06:49:49 AM »
It's still doing it.  Starts up instantly; idles nicely; revs like a champ; sounds good....ON THE KICKSTAND.   Then, I take it out for a ride, and give it gas.  It's still dogging and missing all over the place when you hit the throttle.
PLUGS: are dry and the color of charcoal....so, incomplete or improper burning of fuel (rich).   I immediately go to the Main Jet or main air bleed, but......what about starting simpler.   The wires are good I think.  The plugs are new.  What about the coil??  Wouldn't a bad coil produce a good idle and all would seem fine on the kickstand (rev like a champ, etc.); but, under load, as when actually driving, all would fall apart?  Maybe I swap out the coil first?  (also- the points are new and were just adjusted).
Just a thought....
« Reply #15 on: July 15, 2009, 07:15:15 AM »
I vote for the air bleed to the emulsifier tubes being partially blocked, if the carbs sat more than a year. I see this one a lot: dark, sooty plugs, good low RPM operation, gargles on too much fuel above 1/2 throttle.
Obviously, your mechanic is like the modern mechanics I'm seeing in this area: I've received 2 SOHC bikes now that were worked on by them, only to come out running so badly that they needed a tuneup. And almost everything was adjusted wrong. It makes me fear for those who have to take their bikes to them!
Offline Johnie
« Reply #16 on: July 15, 2009, 07:17:50 AM »
Just to back up a bit to mlinders post, if it runs nice at idle is there anyway you can check the carb sync on it?  If those slides are way off you could be experiencing this condition.  You could have 1 slide way out of wack here.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline BlackMax
« Reply #17 on: July 15, 2009, 07:24:23 AM »
Yea, I was afraid of that.  It sat for a loooooong time before I bought it.  I'm so p*ssed I actually paid a lot of money to have this thing "fine tuned" TWICE!  The first time, when the bike came back, I found the compression was 0 on #4, but the mechanic didn't mention that.  He said he had checked the compression (with his finger) and declared "they are all good."  Turned out the head was basically junk.    Now I have the bike back again with new head and cam and another "fine tune".   Oh brother...... ::)
Now, I'm a rookie with the carbs and cringe at the idea of working on 4 of them.  Any suggestions?  Anyone wish to coach me through checking and correcting a clogged main air bleed to emulsifier tube??    :-\
« Last Edit: July 15, 2009, 07:39:09 AM by BlackMax »
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« Reply #18 on: July 15, 2009, 08:00:02 AM »
 Maybe your main jets are clogged? If you had crud in the tank I would bet its in the mains now. Does it run better with the choke on? If so clean the mains.
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Offline Spanner 1
« Reply #19 on: July 15, 2009, 10:50:14 AM »
Your petcock is blocked with rust and can't supply enough fuel at WOT to keep the bowls filled...need to clean the tank ( for rust ) and take the petcock apart and clean...IMO.
Offline BlackMax
« Reply #20 on: July 15, 2009, 11:46:14 AM »
Another good thought...start simple and work to complex ;D
I did check the tank. It looks pretty good, except for a few rust colored spots, here and there.  Mainly though, it looks shiny.  Also, the petcock screen or whatever you call it (the tall cone-shaped thing IN the tank), is white and looks pretty good.  Still, I'll yank the tank and see if there is any blockage from the top of the carb up to the fuel source.
 If I crack the throttle to WOT, while in neutral, it will stall the engine instantly.  I'm still leaning towards it being clogged air bleeds.....but looking for simple first.  What about timing? ....doesn't seem likely though.
« Last Edit: July 15, 2009, 06:23:56 PM by BlackMax »
Offline Johnie
« Reply #21 on: July 15, 2009, 01:29:10 PM »
Yah, it is a pain in the butt, you have to just keep checking stuff and eliminating things until you find it.  That is the fun with these bikes.  Must have been a bear to do this without the computer community in the early years.
Oshkosh, WI  USA
Offline Spanner 1
« Reply #22 on: July 15, 2009, 10:23:25 PM »
Hold on, we don't know what bike !!!
What bike is it ?...if PD carbs and you crack the throttle and it dies......then it's likely the accelerator pump not working, usually the carb throat nozzles blocked.....
Offline bender01
« Reply #23 on: July 15, 2009, 11:20:05 PM »
"Must have been a bear to do this without the computer community in the early years."
  I threw away a beautiful cb360 in 1997 Because it wouldnt start!
 I did sell the title for a buck. Which was the same amount of money I had in it. ::)
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline BlackMax
« Reply #24 on: July 16, 2009, 09:15:39 AM »
It's a '78 supersport with 150# compression in all cylinders, new head and cam, new points and "tune" (but obviously not really).  The carb. is from who knows what.  I think it's off an auto.
Yes, when I quickly go from idle to WOT, it will instantly die as if I turned the key off.  But also, it has zero power above maybe 3500 rpm....it just won't do much under load.
I came across another guy, on another site who seemed to have the IDENTICAL same problem.  He said he fixed it by:
1) accel. pump springs replaced with stiffer ones
2) he said all the needle clips were on the highest setting (leanest).  He said he lowered them.    Now, he claims all is well.   I'm trying to get more info.
I'll probably replace the coil first, just for kicks.  If it's still a problem, I guess I move to yanking the carb.   Ain't it great!? I just paid a guy $300 to tune the bike "to perfection".  Now, i have to tune the bike myself.  AWESOME! ;)
