Author Topic: bye bye spark plugs?  (Read 3704 times)
Offline Laminar
  • Retsam
Re: bye bye spark plugs?
« Reply #25 on: July 13, 2009, 01:51:11 PM »
Hard to say on a market. If the system was reliable, I am sure some would buy it, especially if it gave a performance boost over stock. I would love to get an fi set up as long as the frame itself did not need to be modded. it would take care of having to sync and the mix could be better controlled. But I do not have the time or money to invest in a system like this or the fabrication tools.
ITBs still require syncing.
The whole point though is that advances like this are cool, even if we can adapt them.
Offline Inigo Montoya
« Reply #26 on: July 13, 2009, 09:07:37 PM »
Yeah, once. Once you have tings in tune, no more resyncing yearly or every couple of years. No more effects from strong cross winds. The fi just will not require as much work over time. Initial setup, yes but after that, about the only thing is if you make engine changes of some sort. Plus, if you use a small computer to store the settings, it is even easier to reset.
Now couple this with a dyna2000, good stuff.
Offline Laminar
  • Retsam
« Reply #27 on: July 13, 2009, 09:15:05 PM »
Things I've read have suggested resyncing every 5000 miles or so, and definitely every time the valves are adjusted.
Offline demon78
  • After work to the "Wets"
« Reply #28 on: July 14, 2009, 04:19:58 AM »
Correct me if I'm wrong gents but dual plugs are for reliability not better combustion all same as A/C engines where were instituted so big thing in front would keep whirling even with duff plug.
Bill the demon.
Offline Buber
  • A bit of spanner spinner, but definitely not a
  • #820 on old mailing list.... :)
    • Mountain Chalets in Polands
« Reply #29 on: July 14, 2009, 05:18:21 AM »
I dunno, an electric powered bike, just doesn't have the same allure of an internal combustion engine...
Agreed.  That's why I'd prefer they work on non gas-powered engines for their future cars so we can keep our gas burning engines going a generation from now.
Hmm, actually don't despair yet. There are scientists that claim you can convert CO2 into methane, and then it's straight chemical reaction, to normal fuel.
http://www.azom.com/news.asp?newsID=15847
or this (translated by google)
http://translate.google.pl/translate?hl=pl&sl=pl&tl=en&u=http%3A%2F%2Fwww.wprost.pl%2Far%2F166360%2FTanie-paliwo-z-Lublina%2F
And there are opinions that this is actually possible... :D
Welcome to my mountains!
Mountain Chalets
« Reply #30 on: July 14, 2009, 06:04:00 AM »
This is interesting, watch till the end, its the bit about acetone i am interested in.
http://www.metacafe.com/watch/524517/double_your_gas_mileage_2x/
« Reply #31 on: July 14, 2009, 06:08:48 AM »
nothing shows up. I have heard of people using acetone to increase mileage though.
As for syncing every 5000 miles, I would not call that a reliable system, not in this day and age. And there should be no reason whatsoever to have to do it from a simple valve adjust unless you are somehow really changing how far they open.
Offline Gordon
  • 750K1, 550K2
« Reply #32 on: July 14, 2009, 06:27:33 AM »
None of the claims about acetone increasing fuel efficiency have been able to be reproduced by third party testers.  Unsubstantiated claims aside, I wonder what acetone would do to all the rubber bits from the petcock all the way down to the carbs?  My guess is it wouldn't be good.
Offline Buber
« Reply #33 on: July 14, 2009, 06:34:41 AM »
Acetone is a myth.. unfortunately....
Mountain Chalets
« Reply #34 on: July 14, 2009, 06:41:05 AM »
Well the amount is negligible. From what I have read on it, people put in a couple ounces to a few gallons of gas. Something like 3 ounces to 10 gallons, so that is WAY less then the ethanol found in most gas at 10% and is not that great for rubber either. but that does not mean there is no effect on parts.
As for 3rd party testers, hard to say. Some people see it, some do not. I think it all depends on the gas in your area and the vehicle itself. I doubt our bikes would benefit much but then I have not tried it in any of my cars.
So maybe it does work but then maybe not, I am not going to try it as I do not want to worry about possible issues. So I guess I could say I am not convinced by the claims.
Offline Laminar
  • Retsam
« Reply #35 on: July 14, 2009, 07:11:41 AM »
Bill the demon.
Two plugs means combustion starts at two points in the cylinder. This ensures more complete combustion of the fuel because the flame front takes time to travel through the cylinder. It's especially useful with large bores where the flame front has a long way to travel.
Offline demon78
« Reply #36 on: July 14, 2009, 09:39:35 AM »
Like 3350's or Merlins?
Bill the demon.
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #37 on: July 14, 2009, 08:06:09 PM »
ford did (does?) twin plug 4 cylinder motors in the ranger
Mark Twain - Notebook, 1894
Offline demon78
« Reply #38 on: July 15, 2009, 04:30:07 AM »
Well the engine theory I learned was that engineers tried to get more HP by staggering the ignition point and producing a better flame front but that HP gain was negligible versus the complexity of the system, so they went back to the original, I will stand to be corrected if someone can point me to the information.
Bill the demon.
« Reply #39 on: July 15, 2009, 06:08:48 AM »
I know my 82 nissan stanza had dual plugs. It was carbed and pretty reliable. The plugs were termed intake and exhaust. I am sure they fired at the same time and you could tell if one was not firing quite right.
Offline CBGhia
« Reply #40 on: July 15, 2009, 09:26:41 AM »
Ducati uses dual plugs in its 1000 DS motor.  I don't know how much of an improvement the plugs were.  Sometimes Ducati does things just for fun.  (Desmo valves anyone?)
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
« Reply #41 on: July 15, 2009, 11:56:55 AM »
Desmo valves are great but a bugger to maintain.  Really do allow the engine to rev more freely.  The sound is distinct but you either love it or hate it.  I think it sounds like a pocketful of change in the top end but my friend just loves the sound of his 748.
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
« Reply #42 on: July 15, 2009, 03:11:59 PM »
I love how topics evolve! We go from dropping plugs to dual plugs to valves. The theory of evolution is true!!! ;D
Offline Steve F
« Reply #43 on: July 16, 2009, 05:52:08 PM »
Can anyone tell me how they propose to get the laser beam into the combustion chamber?  LASERs, being a form of light would require lenses and such, no?  How do they intend on keeping the lenses clear and not fried or carboned up?  Is there a port or a shutter that opens up so the laser can fire through and then closes really quick?
It's a little hard for me to visualize how this laser system is to work in the real world, and not some laboratory.
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #44 on: July 16, 2009, 06:06:02 PM »
They would probably require regular service like oil changes, and tune ups.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
« Reply #45 on: July 16, 2009, 07:39:46 PM »
These lasers would have to just "flash" for a very short period of time right? so if they shorted and stuck on, would they melt the top of the pistons or do i watch too much TV..... ;D
Offline lordmoonpie
    • Moonpie
« Reply #46 on: July 17, 2009, 06:40:19 AM »
Bill the demon.
Twin plugging the Black Bomber head is a common modification in the UK classic race scene. It's mainly on the top end bikes but is good for a whole 1 extra horsepower. very small gains but at the sharp end of racing it's obviously worth it.
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
