Author Topic: Looking to run a Fram Sidemount Oil Filter on my CB --> In need of direction....  (Read 5818 times)
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
Hey ,
In my never ending quest to make my CB more of a Bobber , I have been thinking of running a Fram
Sidemount oil filter setup on my Bike, see pic below.. The late American V-Twin customizer Indian Larry from
NYC was the first "custom" builder to start doing this.
I was thinking of doing this , by placing the Fram sidemount in-line on the return line on the bike. I plan on
keeping the stock filter in the stock location , and doing this for more looks than anything. The cost is not a factor,
as the most expensive part will be the braided lines and AN fittings I will run. This would also act as a
poor-mans oil cooler , with the oil having more time out of the bike , and able to cool off alittle. I had a remote filter setup on my last racecar , and saw a significant temp drop over the filter being in ther stock location. PLUS , I will have more oil on board , which is
always a plus... ;D I will most likely mount the filter on either side of the bike , near where the factory passenger pegs
used to be...
I really don't see this being a big issue , as long as I am sure that their are no kinks or bends in the new lines , and
the new "system" has enough oil to not starve the motor. Which would be easy , by just filling up the new fram filter
before install , just like on a car. Then top off the oil in tank from their..
I guess I am asking , is doing this "appearance" mod worth the damage to my motor ? Will it actually do any damage ? Will the stock pump have enough "balls" to move the oil around the bigger system , with the longer lines and the new added restriction of the Fram filter ?
I have a post going about this topic over at hondachopper.com , but I wanted to post it here as well.  The guys on this board have always
been a big help. The link to the honda chopper topic is ---->http://p196.ezboard.com/fhondachopperfrm4.showMessage?topicID=14643.topic
As usuall , all help is appreciated  8)
« Last Edit: September 01, 2007, 06:33:18 PM by Glenn Stauffer »
Offline ProTeal55
  • Est1968.com
If i run the system as stated above I won't have any oil stravation issues ?
I won't be putting more stress/work on the oil pump ?
Even if I am adding a foot or two more of oil lines to the system ?
Just want to clear up all doubts before I do this to my CB , which I have grown to
love more than I ever thought I would... ;D ;D ;D
Offline dusterdude
imo,once the sytem has all the air bled out,it will push and/or pull oil just fine.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
What size lines are going to run...-6 or -8?
Offline Egil
You may get an idea  on the road from this link to , Terry in Oz builds Oil Cooler Adaptors:http://members.optusnet.com.au/~sherriffbuck/gallery.html
Egil.
73 de La2vpa.
Egil.
On The Edge.....That`s Where We Live Every Day.
My bike :
http://bike.no/member/photo.php?id=1605
Offline ProTeal55
  • Est1968.com
Egil ---> That link you provided did not work. I would assume that doing the sidemount filter would almost be the same
as running an oil cooler. Both have to be ran " in-line" somewhere in the system. If the CB's oil pump can work with a oil cooler ,
it should be able to work with this ....right ....?
MRieck------>
Not sure about what size line I plan on running. Prob. whatever is close to the stock line , which I believe is 1/2 , so
I think that would be 8an off the top of my head...I might run rubber hose at first , to make sure everything works , then go to
braided once all the bugs get worked out...
« Last Edit: November 23, 2005, 10:51:27 AM by ProTeal55 »
Offline Geeto67
  • A grumpy
cycle exchange sells a converter for you honda to take an harley or chrome spin-on oil filter without the cover.
http://www.cyclexchange.net/Oil%20System%20Comp%20Page.htm
I imagine you could get this adapter and then use an AN fitting on the threads to attach a hose to relocate it somewhere else.
They do have a really cool finned oil cooler for the SOHC hondas that I think looks way better than a relocated oil filter.
BTW, why not just get it over with, can the stock oil tank, get a custom oval one (not a harley tank unless you change the fittings to work with 1/2" inside diameter). and put the spin on filter instead. The remote oil filter is so discovery channel.
Edit: oh and indian larry was not the first "custom" builder to start doing this. This was an old 1970's trick that he just kept doing long after other builders stopped. I have seen several old nails form the 1970's built by guys who had shops in the 1960s and 1970s and those bikes had it. Indian Larry and Billy Lane were the first guys to sho this onthe discovery channel. I bet if you look hard enough you can find a remote filter kit from the 1970s for a cb750 (but you may not like the price). Drag racers did this so they could use spin-on chevy oil filters on the drag bikes and the chopper guys followed suit. They also used them when making turbo kits to allow a splitter in place to feed oil to the turbo.
« Last Edit: November 23, 2005, 11:04:55 AM by Geeto67 »
Maintenance Matters Most
Offline ProTeal55
  • Est1968.com
GeeTo67--->
You posted as I was typing the same thing. If I did the adapter from Cycle Exchange , I could just run the AN lines directly from the adapter---> to the Fram filter ---> then right back to the adapter ! That would allow me to leave the stock lines alone ( even though then need to be repalced ) , and then I won't have two filters ont he bike , just one...
As far as the discovery channel comment , to each his own. I had been running sidemount filters on all my HD based bikes years ago, Indian Larry just made it "mainstream"...
Anyone else have any ideas ??
« Last Edit: September 01, 2007, 06:34:46 PM by Glenn Stauffer »
Offline Geeto67
  • A grumpy
Here's my 2nd idea on how to make this work.
The guys over at Cycle X sell a adapter which allows CB owners to run a screw-on
HD style filter. Why couldn't I get one of these adapters , throw a remote adapter on top of that,
then run the lines to the Fram filter ?
It would go Motor --> Oil filter adapter--> Remote Adapter Plate---> Line to filter---> Fram Sidemount Oil filter ---> Line from filter--> Back to adapter plate---> Back into motor.
If I did it this way , I could leave all the stock oil lines in place , as far as the feed and return lines. Then the Fram would become
the only filter on the bike.
Anyone ?
I believe that is why I posted the cycle ex link. I prefer using AN fittings on oil lines when I can because they get a better seal
Offline ProTeal55
  • Est1968.com
Sorry GEETO67 - > We are posting at the same time.. ;D
One question ---> If I get the adapter , and run lines directly to it , what about
the middle "shaft" that allows the filter to screw on ?
« Last Edit: November 23, 2005, 11:20:25 AM by ProTeal55 »
Offline Geeto67
  • A grumpy
I am not sure what you mean....if you get the adaptor to use a harley spin on oil filter and then the relocation kit that adapts the spin on filter to a remote location I don't see how it is a problem. When I posted about the AN fittings I was still looking at your adaptor with the two lines and thinking you would use a two line setup with a collar adaptor for the harley spin-on spigot. I am confused
Offline ProTeal55
  • Est1968.com
GEETO67--->
I was confused , but now I think i have it.
1. I need to get the Cycle Exchange adapter
2. I need to get a adapter to go ONTO that adapter , in order to run the AN lines
I guess my question is now , where would I locate the 2nd adapter ? Noone here knows , and I briefly looked
online and came up empty...
Offline Geeto67
  • A grumpy
I'm just givin ya a little ribbing about the discovery channel stuff...friendly of course...
I'll check with my sources about the source of the relocation kit but IIRC I saw it recently in the JP catalog.
I had a thought though (there I go thinking again). Most of the guys who run harley tanks have to switch to 1/2 id lines from 3/8 because of oil stavation. I am wondering if the "kit" comes with 3/8 lines isn;t this the same problem in a different location?
the more I think about it the more I wonder if the parts america kit that the honda chop guys sggested isn't the way to go since it uses 1/2 id outlets.
Offline ProTeal55
  • Est1968.com
I am going with the Filter and adapter from Parts America, i like the 1/2 fittings.
Then I am pretty much set on the #1 adapter from Cycle Exchange. Net
Just need to source out the #2 adapter.
As far as lines go , I would prob. run 1/2 rubber hose , or 8AN lines.
Offline cb(r)
question:
how are you mounting the filter?  the inlet is facing upward hopefully?
reason:
if you mount the filter upside down or on it side especially above you oil resevoir you will want to look into a check valve on the inlet side so the stays in the  oil filter.
Offline ProTeal55
  • Est1968.com
CB(R) ----->
I was thinking about mountig the filter pointing towards the rear of the bike, and the fittings
facing towards the front of the bike.  It will most likely go  in the area of where the stock passenger
peg used to be , on the Clutch/Left side of the bike..It will be lower than the stock oil tank for sure..
Offline dusterdude
most fram filters have check valves in them nowadays
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline cb(r)
then there ya go.  I did not know that.  learn something new everyday.
Try contact Terry in Australia  He made adapter ;) and for oil coolers and this kind of ,saw this when the link was up and go  ;D
Egil
I have one of Terry's adaptors with an Earl's cooler(-6 lines)...and his oil pressure gauge. Both work well. I'm going to assume Proteal is looking for something different. Keep in mind that oil pumps since the late 80's incorporated a seperate pump drive for the cooler. I'd use the smaller lines (-6) to reduce pressure lose. I use -8 on my FJ with a large Earl's but there is that dedicated pump.
Offline ProTeal55
  • Est1968.com
Been looking / asking around , and I think this idea of mine is comming to a
halt.
I don't think anyone sells the part I need, because if you think about it , their
is no point to have it made. Most HD guys will run a cooler before it gets to the
oilfilter, which is done easily becasue their filters are outside the motor.
What I need , is an adapter to take the place of a HD oil filter , than has provisions
for AN lines , both inlet and outle on it....
I am off to drink , been a long day  ;D
Buffo
I am still looking and posted a post to see if anyone else remembers/knows where that post is...
It had something to do with a test and that fram oil filters let alot of unfiltered oil pass the relief valve in the filter under normal conditions...I will keep looking
I remember that post...use the high grade FRAM filters (gray exteriors).
cd811
all I really want is the adapter (from cycle exchange) but dam  $70!!??
wish I could get my hands on that cheaper.
Yea indian larry was too cool 8) but not his idea... h-d did it stock long time ago...had a stock one on my 83 fxwg...My local auto shop carries the remote filter mount...I like them(had one on my last shovel head) because you can mount it anywhere and many filters will work.
Offline dusterdude
joe,if im not mistaken our engines use a 17mm bolt ro attach to the engine and the jegs adapter doesnt have a 17mm bushing.cd,you lost me on the hd filter deal.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline ProTeal55
  • Est1968.com
DUSTERDUDE---> I read about the Honda being a 17mm , I need to find out what a HD
size is , becasue that is what I will be using if I go with the Cycle Exchange adapter...
Egill----> Thanks for the link. That cooler is pretty trick, not worth the money in my opinion , but still
cool. It seems as if that adapter , retains the stock filter , and just adds two fittings for the cooler.
I actually really like the setup , but I am sure it will sell for a pretty penny....
I still have this feeling that , once I figure out all the lines and adapters , the stock oil pump might have
a hard time moving the oil through out this "longer" system...I mean , the lines are going to be running
all they way from the front of the case , to the back of the bike , then back to the front. The LAST thing I want
to do is blow/starve the motor over a cosmetic thing such as this.,....
That is a big distance compared to it being inside the block....
« Last Edit: November 25, 2005, 08:24:06 AM by ProTeal55 »
