Author Topic: Nighthawk 550 Bobber/Chopper, kinda  (Read 57483 times)
Offline Laminar
  • Retsam
Re: Nighthawk 550 Bobber/Chopper, kinda
« Reply #150 on: November 30, 2009, 06:46:51 AM »
Any change on #3 with oil?
I need to redo that one with oil. What does adding the oil do, close the gap in the cylinder wall? And does it indicate that it's only the rings?
Correct. You know the valves are good and that there's not a hole in the piston, as was mentioned earlier.
Nighthawk Rat Racer
« Reply #151 on: May 11, 2010, 07:56:19 PM »
Hows the project coming. I think were working towards the same thing and im wondering if youve gotten any farther. Since the pic ive chopped the mufflers off and ditched the shocks for struts. Im waiting for new jets to tune the carbs since the airflow mods. I started a new post for any one doing any major mods to a cb550sc so hopefully ill get some good ideas.
« Last Edit: May 11, 2010, 07:57:50 PM by Nighthawk Rat Racer »
pikeymick
« Reply #152 on: July 12, 2010, 10:38:41 AM »
Hey There! Sweet Project. Mine has been at a standstill for a bit. But I'm just about to relaunch the efforts. I picked up a second engine and this one was in MUCH better shape! In comparison it looks as though the first engine was run without oil in it, for quite sometime. The second engine will only need rings! I'm looking to order the rings today!
Offline tomsweb1
  • '78 CB750A
  • '78 CB750A
« Reply #153 on: July 12, 2010, 06:42:10 PM »
Makes sure you tighten those con-rods!
 I'm still looking for a third engine...
Present: 1978 CB750A, 1978 CB400A, 1983 Nighthawk 550, 1984 CM250C
Past: 1977 XL100, 1982 KZ1300
pikeymick
« Reply #154 on: July 29, 2010, 08:20:48 AM »
Hopefully someone else has some more insight on this.
For gasket kits for just the top end, do I want Gasket Kit A 061A1-ME5-S00,
or the individual gaskets:
Cylinder 12191-ME5-306 and Head 12251-ME5-005?
I have another engine if you want it. The top end is pretty bad (see pics) but the bottom end would be usable.
Offline tomsweb1
  • '78 CB750A
  • '78 CB750A
« Reply #155 on: August 04, 2010, 07:00:10 PM »
Pm'ed
pikeymick
« Reply #156 on: September 20, 2010, 08:42:47 AM »
Well it's been almost a year and this thing is almost finally done. I remember when I first started and reading other people's projects how they ended up taking that long, well now I know!
The top end is rebuilt,
to
to
These pictures are crap, I'll get some better ones. Got the whole thing back together yesterday, and realized I lost, not one, but two oil filter spacers with the hoses to the oil cooler. So that's on order from ebay...
Offline Laminar
  • Retsam
« Reply #157 on: September 20, 2010, 08:44:44 AM »
Looks like you have the standard 550 exhaust ripple. Love the 650 front end, any chance you're looking into getting a 650 rear rim to match?
pikeymick
« Reply #158 on: September 20, 2010, 08:48:19 AM »
The wheels are actually both stock wheels. I modified the rotor mounts on the front wheel it fit the CBR rotors.
Offline Laminar
  • Retsam
« Reply #159 on: September 20, 2010, 08:53:14 AM »
The front wheel and (at least the right fork) is from a Nighthawk 650. The 550 had two "star" rims, the 650 had 12 spoke (6 pairs of two) rims.
pikeymick
« Reply #161 on: September 20, 2010, 09:07:56 AM »
Maybe I'm just really confused, it has the same rims your bike has. I just painted them.
pikeymick
« Reply #162 on: September 20, 2010, 09:19:53 AM »
Oh wait, it can't be the same front wheel, hahaha the 550 doesn't have rotor mounts for both sides. But it is the same style wheel ala http://www.cyclepedia.com/honda-cb550-cb650sc-nighthawk-online-service-manual/
Offline Laminar
  • Retsam
« Reply #163 on: September 20, 2010, 09:31:16 AM »
Like I said. Your front wheel is '83+ Nighthawk 650, your rear wheel is '83 Nighthawk 550.
Offline Laminar
  • Retsam
« Reply #164 on: September 20, 2010, 09:31:58 AM »
The bike pictured there is a 650. Your rear wheel is different.
pikeymick
« Reply #165 on: September 20, 2010, 09:39:11 AM »
Oh yeah look at that! I never noticed that before! Hmm... not sure if it matters yet...
Offline Laminar
  • Retsam
« Reply #166 on: September 20, 2010, 09:50:47 AM »
Mechanically it shouldn't matter. Visually it bugs me, but that's only because I know what I'm looking at.
pikeymick
« Reply #167 on: September 20, 2010, 09:53:02 AM »
Haha yeah now that I know, it probably will. But until it actually runs, haha, it will be easier to ignore.
Offline Old75_ratafe
  • CB750 Cave Spelunking
  • 1975 CB750K
« Reply #168 on: September 20, 2010, 10:55:40 PM »
Could be worse my 750 is going on 5 years (3 of them didn't touch it) and I've never even cracked the motor.  BTW looking good so far, my buddy is looking to find a cheap first rider bike and I'm watching this thread and getting ideas for him lol.
1975 CB750K
Project Back in Black
Offline The_Crippler
  • Work in progress.
« Reply #169 on: September 21, 2010, 06:55:34 AM »
Makes me feel a lot better about my slow progress.
pikeymick
« Reply #170 on: September 25, 2010, 04:15:34 PM »
Goddamn. I got it all back together. The first startup it ran great! I took it for a spin around the block keeping the RPM's low to help break it in. But now I've got nothing on 3&4. It's the same damn engine it was before the rebuild. Something screwy is going on here.
I tested everything against the specs in the manual this morning and replaced a coil that wasn't testing right. Except for the rectifier, where with the book I get readings nothing like the book, but consistent readings across the range. What would this thing run like if that was bad?
Offline mystic_1
  • 1970 CB750K
« Reply #171 on: September 25, 2010, 04:56:24 PM »
If the rectifier is bad, you'll have low power and your battery will tend to run dead.
BUT
A problem on 3+4 is probably fuel related rather than electrical.  Cylinders 1+4 share a coil, and cylinders 2+3 share a coil, so those pairs tend to share electrical problems.
Cylinders 3+4 share a fuel supply hose, I'd look in that direction.
mystic_1
- John Augustus Shedd
pikeymick
« Reply #172 on: September 25, 2010, 05:00:16 PM »
Yeah that was my line of thought as well... I tried using some starting fluid to see if that would produce any results. I got a backfire, but no regular ignition... and the plugs are wet. damn.
« Last Edit: September 25, 2010, 05:04:29 PM by pikeymick »
Offline tomsweb1
  • '78 CB750A
  • '78 CB750A
« Reply #173 on: September 25, 2010, 10:45:16 PM »
I'm guessing you have rebuilt the carbs already? If not... do so. Or at least get a packing kit. New rubber in the carbs can make a world of difference.
Offline Laminar
  • Retsam
« Reply #174 on: September 26, 2010, 01:59:22 PM »
Nope. One fuel hose tees between 2 and 3, aluminum connectors direct fuel from 2 to 1 and 3 to 4.
Nighthawk carb rebuild:
http://nighthawk-forums.com/index.php/topic,4907.0.html
