Author Topic: fork and wheel swap info  (Read 8300 times)
Offline Alan F.
« on: September 24, 2009, 09:06:15 AM »
I've made a web page to warehouse my files, notes and utilities for fork and wheel swaps.
Have a look and feel free to send me anything you feel should be included.
http://sites.google.com/site/alansdocuments/
-Alan
Offline HedNut
  • Underwater Basket Weaving
Re: fork and wheel swap info
« Reply #1 on: September 24, 2009, 09:26:46 AM »
VERY COOL OF YOU MAN!!! Thanks... I grabbed a copy of your BT45 spec sheet....thanks a long time.  A bunch of good stuff there.
Offline Alan F.
« Reply #2 on: September 24, 2009, 01:13:07 PM »
You're welcome, I'm just hoping people send me more info to put up there.
-Alan
Offline Bakes
  • Z1 Enterprises, CS Guy, BS Artist
    • Z1 Enterprises
« Reply #3 on: October 01, 2009, 01:28:04 PM »
This needs to be on different page!
Possibly a differnet title as well.
A resource with loads of potential like this needs to be highlighted.
Added what I could for now.
Best Wishes with this!
"Bakes"
Z1 Enterprises
Z1 Enterprises
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #4 on: October 05, 2009, 01:19:59 AM »
this is great, thanks!
Offline Old Scrambler
« Reply #5 on: October 17, 2009, 10:46:47 AM »
This looks to be a great amount of info..........when I tried to open the file for the K3 steering neck I got a long download and a very nice screen of my own desktop RTP.
My question.........I changed the steering bearings to the roller type and used the spacer at the bottom of my K3.  The top bearing requires the spacers on the forks between the ears and the top brace.  I was going to make a tool to remove about 2mm of material from top-side of the inside 'ring' below the top of the neck to allow the bearing to seat at the proper depth.  Would this application be correct for all K3 and newer models?
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Alan F.
« Reply #6 on: October 24, 2009, 01:31:15 PM »
That's a darn good question, but I don't really know all of the in's and out's of each CB750 Model, I'm a K3 guy too and I used the small spacer below the lower bearing and all else lined up perfectly, fork ear spacing and all.
Sorry I can't offer more info, maybe search the tech section of the forum then start a new thread?
-Alan
Offline Alan F.
« Reply #7 on: October 24, 2009, 01:31:32 PM »
I've updated the documents list with 12 new documents, many deal with USD (inverted) forks and more late model bikes. Lots of it was gleaned from forums so if you recognize anything....thank you. And as usual if there is a problem please let me know and I'll take care of it.
-Alan
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #8 on: October 26, 2009, 12:51:36 AM »
Cool and marked!
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
Offline Alan F.
« Reply #9 on: October 26, 2009, 05:03:02 AM »
I'll continue to update when time allows, but anyone can contribute documents by sending them to me at the link provided on the Documents Page.
Thanks for reading, I hope some of this info helps demystify the swap process.
-Alan
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #10 on: October 26, 2009, 07:21:32 AM »
It's good to have this stuff on line within reach of all people.
However,
 The
Dual_Disc_Conversion.doc
  has the same error posted everywhere of using a CB 500 speedo drive plate (and requires no mods to fit). The early CB 750 Sandcast speedo drive plate is the one that requires no mods to fit. The other CB drive plates (single disc) require mods to have them fit on the dual disc conversion.
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline Alan F.
« Reply #11 on: October 26, 2009, 06:12:49 PM »
Thanks for catching that one Fishhead, the document has been amended and due credit has been given.
-Alan
Offline fishhead
« Reply #12 on: October 27, 2009, 07:18:11 AM »
Heres a link showing the different speedo drives used.
http://forums.sohc4.net/index.php?topic=60039.msg651404#msg651404
There are other posts that show what needs to be done to modify the single disc drive plate to work with the dual discs. Feel free to use anything that I have posted.
 Fishhead
Offline Alan F.
« Reply #13 on: October 29, 2009, 06:19:37 PM »
Thanks man.
