Author Topic: Tell me about your aftermarket ignition switch problems  (Read 1302 times)
Online Jerry Rxman Griffin aka MuthaF'er
« on: October 20, 2009, 07:56:14 PM »
I've been researching Honda brand switches for my 75 750F. My part number would be 35100-377-007. UNAVAILABLE. Seems 35100-422-007 is available and appears it might be interchangeable. Good and bad. The set including the seat lock is not available. I want to avoid 2 different keys!
Please tell me your specific problem/beef you have with aftermarket ignition switches. I've seen many complaints such as "junk-do not use". I would surmise it is either &/or 2 things: The actual lock and steering lock mechanism -OR- the plastic connector/base. So whats your problem??
Offline the technological J
  • deliciouso!
Re: Tell me about your aftermarket ignition switch problems
« Reply #1 on: October 20, 2009, 08:01:58 PM »
thats a good question and im posting so i can be kept in the loop... would like to get my hands on all three key locks and matching
94 ST1100..Gone
72 750 K2 Stay tuned!
« Reply #2 on: October 20, 2009, 08:09:33 PM »
It was the switch base for me Jerry, just didn't fit correctly.
All I needed was the ign switch though as I modified a VF750 seat/tail on that bike and the ignition key fit the seat lock so had a locksmith make that key work the lock.
Not much help huh?
Online bryanj
« Reply #3 on: October 21, 2009, 12:55:32 AM »
I hear the same but have never had a problem UNLESS the loom is too tight and pull on the switch----which isnt really a switch fault.
according to motogrid the lock set for the cbx is 35010-422-020 and costs about $160 whilst the contact base part on its own is 35101-422-007 and cost about $35
hope that helps
