Author Topic: Computer gurus I need hep!  (Read 1381 times)
Rocking-M
« on: December 06, 2009, 05:38:23 PM »
I did a clean install of xp on the new HDD (western digital 250GB)
but after I get it booting up and then shut down and plug in the old HDD (40GB Segate)
to try and transfer files the computer freezes at boot up.
I've checked the boot sequence in the bios to make sure it boots from
the HDD and doesn't try the second HDD. The bios has the option
to say boot HDD 0 then CD then Floppy. I tried that then I tried
HDD 1 - CD - Floppy and came up with the same results. No boot up just stops
at the initial bios screen.
I'm also unable to get my internet connection going with the new install of xp
on the new HDD but that's another problem.
Offline the technological J
  • deliciouso!
Re: Computer gurus I need hep!
« Reply #1 on: December 06, 2009, 05:52:22 PM »
you"ll have to surf the net to down load a driver for ur wire less or whatever  ur set up is.... if u google them  they should be fairly easy to figure out... and as far as ur hard drive if ur just trying to transfer files.... i  just found something at best buy that allowed u to use ur old hard drive as an external hard drive... i bought it used it and took it back... just take ur hard drive  with u
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline Alan F.
« Reply #2 on: December 06, 2009, 08:12:41 PM »
Are these IDE drives?  You may simply need to change the jumper position on your 40GB drive to slave or secondary.
Offline Inigo Montoya
« Reply #3 on: December 06, 2009, 08:24:31 PM »
Just what alan said. If you have an old 40 GB drive, I would virtually guarantee it is ide. Check your jumpers. Without them set right, the bios will not know which is disk 0 or disk 1.
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #4 on: December 06, 2009, 09:02:06 PM »
yeah, set it to slave or cable select.
Offline Hush
« Reply #5 on: December 06, 2009, 09:08:44 PM »
Hey thegabrielj what did you find that connected your old PC to your new PC?
I've got stacks of stuff on my old one I want to transfer across but I've bought truckloads of cables and a KVM switch but none of it worked so I've given up!
Offline oldfett
« Reply #6 on: December 06, 2009, 10:37:03 PM »
I recommend one of these puppies if you don't mind diggin into the old box.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812232002&cm_re=ide_to_usb-_-12-232-002-_-Product
We use them all the time at work and they are a life saver.
To the original poster I agree with what everyone said above. If the new drive is SATA and the old is IDE set the jumper on the IDE to cable select and make sure in the BIOS that the SATA drive is set to boot first. If the new drive is IDE and the old drive is IDE set the jumper on the newer one to master and the jumper on the old one to slave.
  • deliciouso!
« Reply #7 on: December 06, 2009, 10:44:10 PM »
it was an external hard drive console of some sort... u plugged the hard drive into it and closed it up it came with the cords to hook it up... i got it at best buy.. something like this
http://www.bestbuy.com/site/Rocketfish%26%23153%3B+-+USB+2.0/eSATA+Hard+Drive+Enclosure+Kit+for+2.5%22+SATA+Hard+Drives/8774301.p?id=1204332553274&skuId=8774301&st=external&cp=2&lp=14
94 ST1100..Gone
  • deliciouso!
« Reply #8 on: December 06, 2009, 10:46:21 PM »
94 ST1100..Gone
Rocking-M
« Reply #9 on: December 07, 2009, 03:42:22 AM »
Slave jumper is what I'll check this afternoon. Thanks!
« Reply #10 on: December 08, 2009, 06:27:20 AM »
So did the jumper option do the trick?
Saw your other post!
« Last Edit: December 08, 2009, 06:36:37 AM by Inigo Montoya »
Rocking-M
« Reply #11 on: December 08, 2009, 12:45:12 PM »
nope, it couldn't be that simple. I'm starting to suspect my ribbon cable is at fault.
Or either I had it hooked wrong. Anyway, I'm on the new HDD now but when I started it, it wouldn't boot.
I switch the cable from the plug at the end to the plug in the middle and she booted.
So maybe I misunderstood the directions (of course that is the technical writers fault :)). It said the black plug
went to the master and the gray plug to the slave. The black is at the end of the line in my opinion and I would
intuitively think that the first plug in the line goes to the master and the second to the slave. Anyway, I'm going for the
external HDD in a box option. BUT WAIT.
What's this I missed about plugging the old HDD into the CDrom slot? Did I understand this correctly.
Thanks all.
Offline Alan F.
« Reply #12 on: December 08, 2009, 01:13:39 PM »
Sounds like you're jumpered for cable select there.
« Reply #13 on: December 08, 2009, 02:23:13 PM »
Rockin, what that meant was to plug the ide cable for the cdrom into the old drive. Your motherboard probably has 2 depending on its age. As SATA come around more, a lot of boards dropped to 1 and most now have none.
They are usually ide 0 and ide 1. Ide 0 is the one the hard drive uses and 1 is the ide the cdrom uses. That would help prevent cable issues in some cases.
