Author Topic: how to remove bushings from swing arm?  (Read 2103 times)
Offline Gnat
« on: January 01, 2010, 03:23:40 PM »
I just got my swingarm off my 1974 350-4 and thinking I was through I went in the house and picked up Clymer where I see thrust bushings, felt rings and pivot bushing that are still in the arm.
which brings up 3 questions
1. How in the heck to you get those suckers out without destroying them?
2. If you do destroy them are they available?
3. I'm having the frame blasted...do I have to take them out/ (can I cover them in some way the blaster wont..well, blast them?
Gnat
"Trying to keep the rubber side down"
Offline HondaNorway
Re: how to remove bushings from swing arm?
« Reply #1 on: January 01, 2010, 03:36:51 PM »
I'm also going blast my frame soon. My idea about the swing arm, is to insert a bolt and put o-rings with a nut on both sides.
Smart?
-Stian
« Last Edit: January 01, 2010, 03:39:23 PM by HondaNorway »
'74 CB750
'76 CB750F
« Reply #2 on: January 01, 2010, 04:04:39 PM »
Smart?
-Stian
That's a good idea. To the origianal question, pretty hard to get them out without destroying them. The usual advice is to cut a notch in the length of them with a hacksaw blade and beat them out.
Don't know if they are still available for the 354. For the 750 they are.
Offline mrblasty
  • Expertly
« Reply #3 on: January 01, 2010, 05:29:15 PM »
PM hondaman, I think he is the bushing master around here.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
CB750Winger
« Reply #4 on: January 01, 2010, 05:54:19 PM »
   I have a set coming for my 750. Could you get a piece of pvc pipe or something that just goes and drive them through from one side? Don't know, just asking.
« Reply #5 on: January 01, 2010, 06:00:13 PM »
The old ones, especially if the newer style steel bushings, have become one with the swingarm pivot tube. Cutting a long slot to relieve tension, and driving out with a stout (not PVC) drift like a long steel punch, or fragmenting from the same side with a chisel is about the only way. Requires a medieval attitude. They will only come out on their own respective sides as the pivot tube has a shoulder that they seat on.
CB750Winger
« Reply #6 on: January 01, 2010, 06:09:24 PM »
Thanks Ron, I've not started into it yet but your info helps. I want to get past my carb issues before I tackle the rear.
