Author Topic: Disposable Hand Warmers  (Read 1509 times)
Offline Bob Wessner
  • "Carbs Suck!"
« on: January 12, 2010, 07:41:13 AM »
Anyone ever use them? Do they do the trick? Just spent a couple of hours down by the river and had to remove gloves for fairly long spells. I periodically put them (hands) in pockets to warm them, but hand warmers might be better. I know you can get refillable Zippos, but as frequently, or infrequently, as I would need them, two are too expensive.
Re: Disposable Hand Warmers
« Reply #1 on: January 12, 2010, 07:55:41 AM »
yeah.  i used them all the time during the winter fishing season.  its often at or near freezing, and i wear fingertip-less gloves.  i buy them by the box.  the small ones are good, but the larger (3"x4.5") ones get really crankin'.  the under-foot stick-on kind, are crap.
crack them open about 15 minutes before you really need them.  they need a good supply of O2 to work well, and will heat for 4-5 hrs.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: January 12, 2010, 08:16:42 AM »
Thanks for the feedback. I'll have to give them a try.
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #3 on: January 12, 2010, 08:20:45 AM »
Were you fishing, Bob?  If so, what are you catching?
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: January 12, 2010, 08:26:29 AM »
No, not fishing, I was out with the camera. Never had much of a problem with the 35 mm cams as my hand exposure could be limited. With the view camera there's more "fiddling" to be done so the hands are out more. Gloves are no help, though I might look into a pair with the cut-off finger tips.
  • Tuck
« Reply #5 on: January 12, 2010, 08:48:24 AM »
If you go with fingerless gloves, get fleece or wool, not leather.  I was sold on fingerless gloves until I made a "special" pair out of leather.  They simply weren't as good as the wool/fleece ones (at least for fingerless).  There's also the kind that have the flap that goes over the fingers, making a mitten that can be pulled back when needed.  You can find some in the sporting goods section usually.
1974 CB 750
1966 Black Bomber
Offline Steve F
« Reply #6 on: January 12, 2010, 09:59:49 AM »
I have used the resuable type that are like a bag of clear jelly that has a metal disc inside.  They can be activated by flexing the metal disc which causes some kind of reaction in the jelly and makes heat. They last a good amount of time, and after they cool off, you can renew them by placing in boiling water for like 5 minutes, and they're good to go again after they cool off.  I got a few of them from CARHARTT, the people that make the heavy duty coats and jackets.
Steve F
MötleyRöx
« Reply #7 on: January 12, 2010, 10:17:06 AM »
I love hand warmers of any kind!
Poor circulation in my fingers means I'm not too manly to wear mittens.   ;D
Those hand warmers are great in mittens because they can be next to your fingers where the heat really needs to be.
I usually wear glove liners inside my mittens, so that if I need the dexterity, my fingers will still not be exposed if I take off the mittens.
If you like heated hand grips, you'll like these hand warmers too.
« Reply #8 on: January 12, 2010, 11:49:41 AM »
opt for the 2-layer fleece fingerless gloves with a windblock layer (ie.. goretex windstopper).  i often get my hands wet when hefting HEEUUUGE fish out of the river.   ::) ;D
a quick clench of the fist dries them out and my hands keep surprisingly warm.
wool fingerless gloves, with the fleece lined pullover mitten flap.  those are nice too.
Offline Damfino
« Reply #9 on: January 12, 2010, 12:21:08 PM »
Uh-Oh....Sounds lik Bob's down by the river disposing of bodies again! :o :o ;D ;D
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #10 on: January 12, 2010, 12:57:38 PM »
You're on to me. I just ease them into the water in the rapids and they slip under the ice of Barton Pond not to be seen until spring.  ;D
Offline mrblasty
  • Expertly
« Reply #11 on: January 12, 2010, 01:34:41 PM »
Costco sells them for around 10 bucks for a big ol' box of them.  We kill a box of them every winter up here.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline ofreen
« Reply #12 on: January 12, 2010, 05:25:52 PM »
I'll go along with the rest and concur the handwarmer packets work OK.
When I want to keep my hands warm and still be able to work a camera or anything else with small controls, I wear those wool glove liners you can get at the Army surplus store for 1-2 bucks a pair.  They work amazingly well even when really cold (below zero), and even when they are wet.  And they make good glove liners, too. ;)
Greg
'75 CB750F
