Author Topic: How-to rebuilt your starter/kill/light switch (Heavy pictures!)  (Read 15480 times)
Offline BigBoi
  • It's a jungle out there.
« on: January 19, 2010, 07:41:13 PM »
This is my first attempt at a how-to, so I hope you all enjoy. I figured I'd give back to the community since you've given so much to me.
First, the disclaimer: I don't ever claim to know what I'm doing. I'm not a mechanic, however I'm also not an idiot and this wasn't exactly really rocket science. Switches are simply harder to come by these days and so I figured I'd give a shot at rebuilding mine. If I did anything wrong, I welcome people to chime in and give their opinion so my bike doesn't light on fire in a couple months when I turn it on. Also, sorry for the couple blurry pictures. My camera is ancient.
Please note that I actually did my turn signal switch first but didn't document it. The good news it, it's much easier to do if you can get through this.
Here's the beast. It's my switch from my 1972 CB750K2:
The first thing I did was remove the throttle cables. You simply unscrew the two black fittings that are holding them in place. When you've done so, you'll be left with the switch, and here's what it looks like inside:
Next, I removed the screw and plate holding the cabling between both switches in:
Then, I cut the shrink wrap so that I could separate both halves of the switch:
The switch halves split:
At this point, I went to work on the starter button. I unscrewed the plate holding the button/wiring in place:
Then, everything came out. You should be left with a screw, a plate, some wiring, a spring and a button:
Put that all aside and move on to the top half. It's much more intricate. Remove the plate holding the wiring bundle for the top half by unscrewing the screw holding it in place:
Here's what the internals of the switch look like:
Unscrew the light switch's screw. At this point, pull out the light switch, and the white bundle of plastic which controls the switch. BE CAREFUL. Learn from me, there's little springs and ball-bearings inside which will fly all over the place if you're not careful. Here's what you're left with. I'm sorry the picture isn't that clear, but you should have the following: a screw, a washer, your light switch, a small spring, a ball-bearing, the white plastic, a small metal plate which goes on the connectors from the white plastic. Also, you should now pull out the wiring.
Now we're left with the kill switch internals:
To get this out, again we need to BE CAREFUL. There's two little springs and a ball bearing in the red switch. If you don't pay attention, they'll fly out. Now, pull off the small C clip holding the red switch in place. Then carefully turn the switch upside down and pull out the red switch. You're left with this:
I pulled apart the red switch because I wanted to paint it. It has two springs and a ball-bearing as described above, but it also has a small plate which contacts the wiring.
The next thing I did was clean everything. I used wire brushes mostly, and some household cleaner with Q-Tips for the insides of the switches. Some compressed air works well too. I used my drill with the fine wire brush to get the polished look on the outside of the switches. If this isn't your thing, I'm certain you can paint them just fine. Here's a nice clean half:
Now would also be a good time to inspect and repair any wiring that may be in bad shape. In my case, I only had to add a little individual shrink wrap for a couple wires.
Putting it back together, I started with the bottom half which contains the starter switch. I lubed up everything very well with some dielectric grease. I was personally very generous. I first put the button and the spring in, then the wire wall and finally the plate and screw. I didn't take any pictures of this, but it's really trivial, reverse of removal.
Back on the top piece, note that I've painted my red kill switch with some automotive spray paint. Lots of thin coats seems to have worked well. I loaded up the wiring board with die-electric grease, then slid it in:
At this point, I also put the red kill switch back together. Two springs on the bottom, the round slot contains the ball-bearing and the square contains the connector plate. Note that the springs are different sizes, and the small spring only fits for the square pattern. Make sure you use some dielectric grease on all these as well as the shaft for the red kill button.
Next, flip the switch half upside down and place the red kill switch in the correct hole. Re-insert the C clip to hold it in place:
You'll now have to put the white plastic back together and back in place. To do this, I inserted the small metal plate and spring in the white unit, put the ball bearing and held it in place with my finger. I then grabbed the wiring board and installed it on the white unit (in the small metal plate). I then put it all into place in the actual switch. Again, I was generous with the dielectric grease:
Then, you simply have to install the light switch and screw it in. Make sure you use the washer. After that's in, re-install the wiring bundle plate with screw. Here's what it should look like:
You then need to re-install the holder for both wiring bundles (top and bottom):
At this point, you should check all your connections using a test light and a battery. I found it to be easy enough if you study the diagram a little. You should shrink wrap both bundles together when everything is complete. Here's how she looks:
Hope this was helpful! Feel free to message me if you have any questions!
« Last Edit: January 19, 2010, 07:43:37 PM by BigBoi »
Offline Yoshi823
  • Biker to the bone.
  • Never too old to be a biker
Re: How-to rebuilt your starter/kill/light switch (Heavy pictures!)
« Reply #1 on: January 21, 2010, 05:53:50 AM »
I had a problem with the right hand switchgear on my 550F that I used for commuting. I had the switch apart & found that the small copper bridge that moves & connects the lights on/off together had worn away the raised bits that makes the contact. It was worthwhile doing this to my other bikes as well, so's to lubricate the bridge & stop premature wear.
Bikes...they're in the blood.
Yamaha 2001 R1
Yamaha 1990 FZR1000R EXUP
KTM 2004 450 EXC RFS
Honda 1997 XR400R
Honda 1988 CB125T2
http://www.cb750cafe.com/bikes.php?cat=3&id=67
Offline HedNut
  • Underwater Basket Weaving
« Reply #2 on: January 21, 2010, 10:13:10 AM »
HEY! Thanks for that BigBoi.....
  That sounds kinda dirty coming from me, .... THANKS For the info-pic's and run down, I need to do that too!
Very Cool of you! Cheers!
« Reply #3 on: January 21, 2010, 11:54:16 AM »
Nicely done thanks for the tutorial.
Offline SHELLFISH
« Reply #4 on: January 21, 2010, 01:23:43 PM »
Nice job, Thanks!
I want to die like my grandfather did...in his sleep and not screaming like the passengers in his car!
Offline Johnie
« Reply #5 on: January 21, 2010, 02:05:21 PM »
Don't you just love all those tiny screws and springs. I put a white sheet under my drop area so I can find everything I seem to drop a zillion times. ;D
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Really?
« Reply #6 on: January 21, 2010, 02:15:09 PM »
Nice.  Glad I stripped a screw in there and did not get to see the springs fly.  ;D
btw, is ther ea source for those internal screws?
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline BigBoi
« Reply #7 on: January 21, 2010, 02:39:06 PM »
I don't think you can buy them from Honda. Any regular fastener store that stocks metric should be able to help you though.
Offline Really?
« Reply #8 on: January 21, 2010, 03:01:08 PM »
Sad thing is Fastenal in my area will not break open a bag anymore.  At least that is what they told me the last time I was there.
Offline mystic_1
  • 1970 CB750K
« Reply #9 on: January 21, 2010, 04:53:45 PM »
Most excellent post!
Tip:  when disassembling the internals, get a large plastic bag, put the switch housing into it, and then stick your hands inside to do the disassembly.  This will keep the little parts from flying out and going on walkabout.
mystic_1
- John Augustus Shedd
Offline jasonseasen
« Reply #10 on: January 28, 2010, 10:58:48 AM »
Good idea mystic about the bag. I did it in the open and lost one of those small balls.
Offline markb
  • When I finish my current project I might be a
« Reply #11 on: January 28, 2010, 11:43:19 AM »
Thanks for the photos.  I'll be trying to reassemble mine soon and didn't take as many pictures as you.  It will help.  I had a badly faded K0 one with the black kill knob and nice K2 one with the red knob.  I decided I would pull the black knob from the bad one and swap it with the red knob in the good one to get a decent K0 control.  Unfortunately the shaft on the black knob is shorter than the red one (must also be a minute difference in the housings) so it won't work.  Seemed like a good idea at the time but now I have two to repair.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline Really?
« Reply #12 on: January 28, 2010, 01:04:20 PM »
I think this would be great in the FAQ's
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #13 on: January 28, 2010, 01:19:58 PM »
I'm not sure. It's not like this is asked frequently, as FAQ implies, but I think it is a good Tip/Trick.
I'm open to feedback on this view.
Offline Really?
« Reply #14 on: January 28, 2010, 01:28:30 PM »
I am good with it.  FAQ was the first thing that came to mind
Offline markb
« Reply #15 on: January 28, 2010, 01:31:02 PM »
Tip/Trick is good.
Offline mystic_1
  • 1970 CB750K
« Reply #16 on: January 28, 2010, 01:42:13 PM »
I tend to agree.  It's a great tip but not asked about as much as, say, which oil to use ;)
mystic_1
« Reply #17 on: January 28, 2010, 02:01:52 PM »
It should be noted that the later starter modules have a quite different starter button switch inside the housing.  Those switches are rather difficult to rebuild, and often fall to bits when taken apart.
I guess my concern is that a FAQ of this post may encourage people to take these different style type apart, too.  Since the housing may be the only thing holding the broken/weak plastic of the starter switch in place, taking them apart earlier than needed, will result in an expensive replacement, or a jury rig of something unreliable, with less functionality (like not interrupting the headlight power during start).
At the very least, a make model listing of what the rebuild procedure applies to is required.
For example, this rebuild does not apply to CB400F 75-77, Cb550K 77-78, Cb550F 75-77, Cb750F 75-78, CB750K 76-78.  There may be more models, or it may only apply to switch models that do NOT have a headlight On-Off switch in the module.  But, I haven't seen them all.
