Author Topic: 550 clutch reassembly woes UPDATED!  (Read 5789 times)
Offline bistromath
« on: February 22, 2010, 11:21:40 AM »
I got a clutch pack from David Silver and either I'm doing something wrong or I got the wrong clutch pack. The disks don't fit flush against the lifter plate. Here's what the clutch pack looks like assembled -- note the gap between the lowest friction disk and the lifter plate:
The larger disk is at the top, outermost from the clutch hub. It has angled grooves and wider tabs than the rest of the friction disks:
And so it definitely has to sit at the outside of the clutch pack, and indeed the manuals say it goes there:
But the lifter plate's diameter is too large to allow the innermost friction disk to sit flush against it, and so there's a gap:
That gap can't be right. I believe the friction disk should sit flush against the lifter plate. But there's fully two millimeters of interference between the ID of the clutch disk and the OD of the lifter plate. Did I get the wrong parts from Mr. Silver? I called them up, and he says they shipped the right parts. Do I have a wonky lifter plate? Is it really supposed to go together like this?
« Last Edit: March 05, 2010, 06:54:28 PM by bistromath »
'75 CB550F
Offline bistromath
Re: 550 clutch reassembly woes! Now with PHOTOS! What am I doing wrong?
« Reply #1 on: February 22, 2010, 06:48:20 PM »
Man, nobody knows? Any guesses? Idle speculation? Anything would be helpful, I'm really at my wits' end on this one.
'75 CB550F
Offline Hush
« Reply #2 on: February 22, 2010, 07:06:48 PM »
Why are you placing a standard disc plate on the activating hub when you state yourself that the book says the larger disc should go there?
In your photos you have a standard disc sitting on the inner hub, what happens when you replace that with the special larger disc?
Offline Hush
« Reply #3 on: February 22, 2010, 07:10:27 PM »
Yep that's what I'd say was wrong, the "special" larger plate allows the "shifter plate" to fit inside it, try rejigging the plates so you have the standard ones all inside the clutch basket then lastly fit the "special" plate and then the shifter plate, that should work. :)
Offline bistromath
« Reply #4 on: February 22, 2010, 08:17:56 PM »
Hush: just so we're using the same terminology, the "lifter plate" is #8, and the "clutch center" #3. The "clutch basket" is #1, but the scan is bad so you can't see the number.
If I put the larger friction disk (#5) against the lifter plate (and it does fit just fine), then the clutch pack won't fit into the clutch basket; the problem is shown in the third photo. The clutch basket has tapered tabs, and the larger friction disk has wider tabs that won't let the disk fit all the way inside the basket. Imagine stacking the rest of the clutch pack on top of the disk in the third photo. It won't go. In order to fit, I'd have to put the clutch pack into the clutch hub backwards, with the lifter plate mounting holes facing INTO the motor instead of OUT of it. But that's no good.
In other words, my #4 disks won't sit flat against the lifter plate. I still think my friction disks are a little too small -- maybe they sent me ones for a 400? If someone had a set of 550 friction disks they could measure, that would be awesome and would confirm the problem so I can sleep at night.  ::)
'75 CB550F
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #5 on: February 22, 2010, 08:29:01 PM »
i've got a 550 stack (but no lifter plate) and can measure the friction discs if you'd like.  need OD, ID, thickness and tab width?
bobp
searching for a dr350se
Offline bistromath
« Reply #6 on: February 22, 2010, 08:34:58 PM »
Just need the ID of the standard (not outermost) friction disks. Thanks so much, you're the man.
'75 CB550F
Offline Hush
« Reply #7 on: February 22, 2010, 11:02:56 PM »
Sorry Bistromath, just checked my manual too and you are right, the "special" friction disc will be the last one coming out of the clutch basket (sorry been working on Suzuki's lately and I'm a bit confused)
Your #8 which to me is the pressure plate, should allow the standard disc to fit right hard up to it.
Wonder if someone fitted a different clutch to your bike at some time?
« Reply #8 on: February 22, 2010, 11:28:52 PM »
Parts 3 & 8 are different on the 77/78 models has a PO done a mix-n-match?
Offline camelman
  • Man... Myth... Legend
« Reply #9 on: February 22, 2010, 11:37:43 PM »
Bistromath,
What date was your bike manufactured?
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline Kevin400F
« Reply #10 on: February 23, 2010, 04:08:07 AM »
It seems too obvious, but can you compare the new discs to ones that came out of the bike?  I'm assuming you must be working on a basket case or something that had been previously disassembled with the prior parts lost/misplaced.
« Reply #11 on: February 23, 2010, 04:08:50 AM »
measured a coupla discs from my 76cb550k donor bike:  OD (no tab) = 5.474/5.477 or 139mm
« Last Edit: February 23, 2010, 11:49:05 AM by shoemaniii »
Offline Kevin400F
« Reply #12 on: February 23, 2010, 04:35:38 AM »
I have a clutch that I'm pretty certain came out of an early 550 ('74 or '75).  The ID of the friction discs is approximately 4.735", which as you can see from the attached photo, fits around the lip on the lifter plate.
« Reply #13 on: February 23, 2010, 11:51:20 AM »
can confirm ID from my '76550k is 4.74/4.73, or about 120mm
Offline strynboen
« Reply #14 on: February 23, 2010, 12:18:09 PM »
     this parts are bayed  at david silver ,,to a 1978 model k3..
              orginal honda parts
          spec frik pl   22202-392-000-1 stk
          metal plates 22321-mt3-000-6 stk
          springs        22401-374-000-4 stk
           norn frik plates no number
« Last Edit: February 25, 2010, 02:35:33 AM by strynboen »
i hate all this v-w.... vords
Offline strynboen
« Reply #15 on: February 23, 2010, 12:36:17 PM »
try to build it together vith the old plates..any differens ???
Offline bistromath
« Reply #16 on: February 23, 2010, 01:32:26 PM »
Well, that makes perfect sense -- mine have an ID of 4.580". So it looks like I have the wrong friction disks after all.
'75 CB550F
« Reply #17 on: February 23, 2010, 04:17:28 PM »
i have a used set if needed, with plenty of friction mat'l left.  am parting out a donor bike, so very inexpensive.  can send pics if needed.  glad you got it sorted,
bobp
« Reply #18 on: February 23, 2010, 09:49:52 PM »
was there a part number on them, they may be 500 ones. Tell dave Silver the inner diameter is wrong for the 550, if he has been supplied wrong he will want to know
Offline Hush
« Reply #19 on: February 24, 2010, 01:32:00 AM »
Strynboen, I love you man...no idea what you are saying but your heart is in the right place. :D
Offline strynboen
« Reply #20 on: February 24, 2010, 03:39:04 AM »
ha ha ha... ;D..anyvay,,ve just drive honda,,world vide..thats the great thing..understanding is sekundery
Offline camelman
« Reply #21 on: February 24, 2010, 11:40:44 PM »
+1
Offline bistromath
Re: 550 clutch reassembly woes UPDATED!
« Reply #22 on: March 05, 2010, 06:56:33 PM »
Well, just when I thought it was safe, I got my replacement friction disks from David Silver.
And they're exactly the same as the last set. 116mm inside diameter.
I'm going to lose my mind! Do they just have a stack of the wrong-sized 550 plates that they keep pulling off and sending me? I asked Mark at DSS to measure them before he shipped them, and he said they measured 120mm. Is the English millimeter smaller than the American millimeter?
'75 CB550F
Offline strynboen
« Reply #23 on: March 06, 2010, 05:59:06 AM »
hey have tjekket mine  new plates, from ds,they are alså smaller in diameter,,,but they fits okay anyvay..its only the special plate,,there shud messing 120.mm.others plates vork fine 116 mm...have some pic of mine clutsh..
but have not begining to komplet it yet..så nothing for shure...
 ...  edit .... have testet it  dammit it dont fix
« Last Edit: March 06, 2010, 10:54:40 AM by strynboen »
Offline strynboen
« Reply #24 on: March 06, 2010, 06:00:12 AM »
more,, pic 1and2 are specil..plate..nr 3 pic are normal plates
« Last Edit: March 06, 2010, 06:41:09 AM by strynboen »
