Author Topic: Help! 78 case fit 77f  (Read 1540 times)
Offline tweakin
  • tear down
« on: April 01, 2010, 04:06:19 PM »
I am building a 1977 cb750f and ran into a problem with the cylinder studs breaking.  The machine shop I took it to is having major difficulty removing the broken studs.
I have a line on 78 cb750 case, just the case.  Will my 77f parts fit in this case?  I have great 77f heads(rebuilt) and cylinders.
Thanks
« Last Edit: April 01, 2010, 04:16:15 PM by tweakin »
Offline Old Scrambler
Re: Help! 78 case fit 77f
« Reply #1 on: April 01, 2010, 06:22:11 PM »
Black motor parts will exchange..........but, your are using both cases and may (will) need bearing shims to exchange the crank.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline tweakin
  • tear down
« Reply #2 on: April 01, 2010, 07:03:00 PM »
Thanks, I thought I would be ok.  Will I need bearing shims to match the crank out of the old (77f) case that go with the crank of shims to fit the new to me 78 case I will be putting my 77f crank in?
Thanks for the reply.
« Reply #3 on: April 02, 2010, 09:22:55 AM »
shims for the replacement cases.........they come in half sets so be sure to get the tops and the bottoms.  The color code is marked on the bottom case.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline tweakin
  • tear down
« Reply #4 on: April 02, 2010, 10:19:32 AM »
Thank you for all your help.  I was really stressing about this since I have already purchased all the pieces for my 77f cafe rebuild.
