Author Topic: Has anyone converted 77-78 from 630 to 530 chain?  (Read 1648 times)
Swoop
« on: April 08, 2010, 11:49:24 AM »
I found a couple of posts saying they were going to try it but couldn't find posted results.
Looks lie only conversion is partsnmore for 15-41 teeth ? Any other sources?
Any success or failure stories?
Thanks
Steve
Offline scondon
  • Mmmm......tasty bugs
Re: Has anyone converted 77-78 from 630 to 530 chain?
« Reply #1 on: April 08, 2010, 12:06:10 PM »
On my 77-78 750F's I just buy the 17/48 sprockets intended for 530 K chains and install them with no mods. No problems for 8 years so far. Ratio is around 2.86 if memory serves
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #2 on: April 08, 2010, 12:16:45 PM »
Bingo.... then you can use all kinds of gear ratios to get what you want.
Converted my 78K to 530.... then realized the old 630 chain had snapped a giant hole in the back of my case...
That was 12 years ago.... it's still in boxes.  :D
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Swoop
« Reply #3 on: April 08, 2010, 12:21:44 PM »
I thought the 630's had a hole in the middle for a big bolt and the early K's had two bolt holes with the twist lock thingy? Same center opening? (splines)
I had read on one of Hondamans recent posts that there are some issues with this conversion????
I'll take a look and see when I get home.
Thanks for your help.
Steve
Offline Laminar
  • Retsam
« Reply #4 on: April 08, 2010, 12:25:39 PM »
I got my 630-to-530 conversion sprocket set and chain from HavocTurbo.
I went to 18/45 to keep highway revs down. The installation was straightforward, nothing difficult at all. I got 47mpg on a recent trip to Kansas City (200 miles each way).
« Last Edit: April 08, 2010, 01:06:55 PM by Laminar »
Offline HavocTurbo
  • Can you tell?
« Reply #5 on: April 08, 2010, 12:26:41 PM »
I'd have to double check.... not sure they make that kit anymore...  :o
09 XL883L - No Name
Offline Inigo Montoya
« Reply #6 on: April 08, 2010, 01:43:57 PM »
My swap was a 17/47 I think and it was a bolt on and go. Nothing special. Chain length ended up being something like 106 or 108 links I think.
Offline scondon
« Reply #7 on: April 08, 2010, 02:30:28 PM »
The 530 front sprocket is just a hair wider than the output shaft on my '78 F. When installed there is a small gap that I fill with a washer behind the single mounting bolt. That's it. I've read about people having "mods" done to fit a 530, and I'm uncertain why they "have" to and I don't. My chain runs straight and true :-\
Offline kghost
« Reply #8 on: April 08, 2010, 02:36:10 PM »
My swap was just the F swingarm....so only needed a rear sprocket
Stranger in a strange land
Offline bender01
« Reply #9 on: April 08, 2010, 07:45:27 PM »
http://forums.sohc4.net/index.php?topic=62798.0
 I did it on my 750f. 78. No spacer needed for me. Since I dont load up and hit the interstate I would go 17/48 next time.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
