Author Topic: 350f fork compatability  (Read 1493 times)
Offline socalenduro
« on: April 26, 2010, 03:31:11 PM »
anyone know if a 78 cb400 fork set up will work on a 72 350f?
Offline camelman
  • Man... Myth... Legend
Re: 350f fork compatability
« Reply #1 on: April 26, 2010, 03:56:29 PM »
Yes.  The 360T forks are the same too, but much cheaper.
Both are better than the 350F forks.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline DKB
    • E3
« Reply #2 on: April 26, 2010, 04:43:09 PM »
I just picked up a 73 CB350f today that has a CB400F triple tree and fork set up. Looks to bolt right on. The PO said there was a noticable difference in handling after the swap to the CB400f front end...
Offline hoodellyhoo
  • CB350F
« Reply #3 on: April 26, 2010, 04:47:04 PM »
Don't know for sure, but doesn't the 400 have a 19" front wheel? This might affect the handling as well.
Offline jessezm
  • '77 cb400f cafe build
  • Always wrenching...
« Reply #4 on: April 26, 2010, 04:54:06 PM »
CB400f is an 18" front and back.
Offline socalenduro
« Reply #5 on: April 26, 2010, 05:03:37 PM »
this is a 400 twin though i think.....
Offline jessezm
« Reply #6 on: April 26, 2010, 07:46:30 PM »
Oh, nevermind...
Offline socalenduro
« Reply #7 on: April 29, 2010, 07:23:09 AM »
what known front ends simply swap over?
after removing the slider covers the upper tubes are just rusted to hell...
i want to stay with wire wheels
Offline camelman
« Reply #8 on: April 29, 2010, 09:28:56 AM »
I'm confused as to what you have.  Do you have the stock 350F forks and triple trees?  If so, then any 350F forks, 400F forks, and 360T forks should work.  The 400F and 360T might be a tad bit longer, but you can adjust for that in the triple trees.
Your wheel, brakes, and speedo cable should work just fine.
Camelman
Offline strynboen
« Reply #9 on: April 29, 2010, 10:02:36 AM »
mine 400 have a 350 leg ine one side,,think it are komplet same,,just main light holder are diff on 400,,but legs are same
just littel different in dust seal..mont,,that rubber muff is not for 350/400,,but jused korse org dust seal not can mont on 350 leg,,så i fix it that vay
« Last Edit: April 29, 2010, 10:05:27 AM by strynboen »
i hate all this v-w.... vords
Offline socalenduro
« Reply #10 on: April 29, 2010, 11:31:57 AM »
Camelman
I have stock everything, just the slider covers, both upper and lower, and ears that hold the headlights are off. Clearly on this model they did not use the same finish, as they rusted in about 3 days after removal. So i guess im looking for 2 things.
#1 (more important) fork tubes or entire front end that will not be rusted when exposed
#2 (if im going to replace them anyway) a "better" front end is better (more effective compression and dampening)
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #11 on: April 29, 2010, 11:53:36 AM »
an entire front end from 500,550 and 750 will fit.
No.
