Author Topic: 73 750 w no spark out of both coils?  (Read 848 times)
Offline Eck750
« on: May 18, 2010, 12:23:09 PM »
I went out and got a test light and a multimeter but dont have a clue on how to test to make sure that its bad coils ???  ???  I just figured i should test them first since neither of them are working.
"The Honda starts every time you turn the key and it's greatest expense is gas and tires. Maintenance on the Ducati will eat you out of house and home. Don't fool yourself thinking you can do it yourself- you screw up one cam belt learning you will destroy the entire motor. People who ride Ducati's live in big houses. People who fix Ducati's live in bigger houses." -unknown
Offline Gordon
  • 750K1, 550K2
Re: 73 750 w no spark out of both coils?
« Reply #1 on: May 18, 2010, 12:46:05 PM »
Coils don't completely fail all that often.  It's even more rare for both to fail at the same time.  Chances are the problem is in the wiring somewhere before the coils.
Check for switched power on the black wires to the coils and work your way back from there.
Offline Eck750
« Reply #2 on: May 18, 2010, 01:30:15 PM »
yeah i figured it was something other than the coils when i didnt have any spark out of both of them. Im just goin to print off the wiring diagram and just start at coils and work my way back to see where im loosing power at.  Im stuck at work now till 11 so wont be able to dive into this fun project till tomorrow  :-[
 So according to the wiring diagram of the ignition system i just need to follow lead from the battery back if it doesnt have any power at the coil correct?
« Last Edit: May 18, 2010, 01:51:44 PM by Eck750 »
