Author Topic: 7 plates in clutch on 550..or just standart setup  (Read 2582 times)
Offline strynboen
« on: June 03, 2010, 12:00:42 AM »
hey i vorks on my clutch..its that type vith that dobbelt plate in mittel ..have a idea to remove that thing and mont an ekstra set of friktion and metal plate insted...but hvy did honda do that mod..only for noising clutch??..or more for stabilicing for vibrasions in plates
hvat setup works best..i dont care abaut a littel noise,,if its vorks best vitaut thar dobbelt plate..have done search,,and faund a lot ,,but no drive test resultalts....and sorry for bringing this old thing back for 699 time..now it sucks
i tryed to put 7 plates in,,it almost fit,,byt the 4 fingers get to short,,and springs get to kompresed..have some tryed to make some distance pieses? (afstands ringe)to put betveen..to make springs right.....or is this set op ,,give to less space in bottom of clutch to relase..chlutch presure plate can not move back,,for "outer comp" pos 1..
last  thing ,,did some now hov thik that ring..pos 14 are..that thing missed in my clutch..i have made one vho is 1,8 mm..but think it skud be hardnet steel..
and again  sorry for my viking english..lars larsen---strynboen--denmark
« Last Edit: June 03, 2010, 01:46:07 AM by strynboen »
i hate all this v-w.... vords
Offline brandon
Re: 7 plates in clutch on 550..or just standart setup
« Reply #1 on: June 03, 2010, 12:32:30 AM »
Hallo Larsen,
I'm curious as to why you would want to do this? Wouldn't it be easier to use heavier (stiffer) clutch springs?
Offline strynboen
« Reply #2 on: June 03, 2010, 01:43:16 AM »
hey  its for not to overload the kabel  and grip ,,and keep the soft handle  ..ve do somthing similær on yamaha mopeds..but have to modifing a lot to get 3 plates in a fs1...but in first place i need to now..shud i keep that dobbelt plate or thange to the orginale clutch
sistem vith 6 normal plates..its a stock bike..så thances are maybe overkill..like it stock..but like alså a strong clutch
Offline turboguzzi
« Reply #3 on: June 03, 2010, 12:48:00 PM »
i think you are going the hard way
the stock clutch is fine for up to 60 hp on the rear wheel by adding just a 1.5mm washer to the stock springs
with barnett kevlar plates you could even just fit without stronger springs and get a very stong clutch. not an expensive mod, maybe 60$ or such
TG
traveler
« Reply #4 on: June 05, 2010, 08:06:56 AM »
Late model ('77-'78) straight cut plates with Barnett springs is more than you will ever need for a 550 unless you go Turbo....
~Joe
Offline strynboen
« Reply #5 on: June 05, 2010, 08:40:43 AM »
thanks for info..i trying vith 6 normal plates vitaut that dobbelt plate..its not that big vork ,,of i have to go back to..old set up...
i get new pollish set next week,, and get evrything flunky,,, just missing one piston..to get that engine right..other vay i must get 4 new,,and gov one number up,,just a shame..everthing vorked fine..no oli use..just started to melt the one piston,,kud be an air leak vho makes fuel mix lean in one cilender
Offline Bill/BentON Racing
    • BentON Racing
« Reply #6 on: June 05, 2010, 07:39:57 PM »
Action Four's had a 9 plate kit if interested,used it on the CB590cc Yoshi kitted bike.Bill
BentON Racing Website
BentON Racing Facebook
« Reply #7 on: June 06, 2010, 04:33:36 AM »
I thought about replacing that double steel with another friction and regular steel plate.
The problem may be whether or not there is enough free play, and I won't know until I can finish the bike.
Left) 78 basket replacing that double plate with an 8th friction and another regular steel.
Center) 78 stock clutch
Right) 75 Barnett clutch
Hopefully you can see the amount of "free space" in an asssembled clutch. It may well drag without enough space.
As was mentioned shimmed springs or Barnett pieces with Honda clutch parts will take more than stock power but let us know what you decide to try.
Offline strynboen
« Reply #8 on: June 06, 2010, 01:54:49 PM »
hey i just trying vith 6 stell and 6 friktion..just take that dobbelt plate and thange it vith a normal steel plate..if i shud try that 7+1 left model..i have to mashine some matrial of the chlutch..and dont have spare parts..its must vait to i have a ekstra parts engine..
its are just a fev milimeters to move of. pos nr 8 ,,to get it more back.and it vill vork..
« Last Edit: June 06, 2010, 01:59:48 PM by strynboen »
