Author Topic: Clutch Hub modification posts  (Read 15967 times)
Re: Clutch Hub modification posts
« Reply #50 on: June 24, 2016, 04:38:16 AM »
10W40 initially, then 20W50 - still have the light.
I have seen that thread too.  I was talking specifically about the grooves Mark mentions rather than the holes.
Thanks though!
Aha, I seen them somewhere, probably in Mark's book. They are just dremel made little grooves on the inner surface, they make the drilled holes look like little stars.
But seems like your problem is somewhere else.
« Reply #51 on: June 25, 2016, 02:51:10 AM »
"Too low oil pressure at idle" .... This can be too low idle. My engine like 1200 rpm or more Up to 1400 rpm is OK. Lamp can blink at 1000 rpm.
Cam will suffer with too low idle. My engine has fresh o-rings and rebuilt oil pump.
Offline CycleRanger
  • No comment about being an
« Reply #52 on: June 03, 2025, 07:28:48 PM »
This is an old thread I know but on the topic of clutch hub holes I was putting a new clutch in my '76 XS650 and I couldn't help but notice the numerous giant holes in the stock hub.
Makes Honda look stingy!   ::)
« Reply #53 on: June 04, 2025, 06:43:26 PM »
Yeah! I think they need more holes (and bigger) because of all those clutch springs?
:D
Offline CycleRanger
« Reply #54 on: June 04, 2025, 07:59:06 PM »
:D
Yeah there's six of them. The XS650 clutch is pretty beefy.
