Author Topic: Center stand pin won't budge  (Read 1332 times)
Offline wrenchmuch
« on: June 21, 2010, 05:46:35 AM »
I removed the 2 bolts that clamp the pivot pin in place for the center stand on my 750 K4 . Hammering won't budge it . I think the end is too mushroomed now to go through the stand's hole . Time for the sawsall ?
P.S. cotter pin is out .
« Last Edit: June 21, 2010, 05:48:08 AM by wrenchmuch »
CB750K1
CB750K4
Re: Center stand pin won't budge
« Reply #1 on: June 21, 2010, 06:16:19 AM »
usually prying the clamping part open helps.
Offline wrenchmuch
« Reply #2 on: June 21, 2010, 03:30:20 PM »
I did that .No joy . New shaft is about $14 bucks . I might get the saw out tonight .
CB750K1
CB750K4
Offline Nikkisixx
« Reply #3 on: June 21, 2010, 03:56:13 PM »
Take a bastard to it
Bastard file that is.  ;)  If it spins/turns in the clamps, you should be able to file the mushroom off.
Offline wrenchmuch
« Reply #4 on: June 21, 2010, 04:51:28 PM »
The pin moves with the stand even with the clamps tight . Seized to the stand me thinks . Hmmmm bastard eh .
CB750K1
CB750K4
Offline Nikkisixx
« Reply #5 on: June 21, 2010, 04:58:07 PM »
Oh yuk,  this may be a job for a bf hammer and a hot wrench (torch) then.  At least the pin is only $14.
