Author Topic: How many volts does the electric start need?  (Read 837 times)
Offline njcafe84
« on: July 06, 2010, 09:07:53 AM »
My battery was sitting at 11.4v yesterday and the electric start would only work if I had a charger hooked up to the battery. Do I not have enough volts for the electric start?
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: How many volts does the electric start need?
« Reply #1 on: July 06, 2010, 09:09:46 AM »
A fully charged battery should measure at least 13v with no load.  Also, do not run the starter with a charger connected, this could damage the charger.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
« Reply #2 on: July 06, 2010, 09:50:02 AM »
You don't have enough stored energy.  A fully charged and rested battery read 12.6 - 12.8 V.
Voltage = potential
Current = flow rate
Voltage X Current = power
Offline strynboen
« Reply #3 on: July 06, 2010, 11:25:46 AM »
yes you are missing some amps...thats are the thing as turns veels araund
i hate all this v-w.... vords
