Author Topic: wide tire  (Read 1206 times)
Offline 77cafe750
wide tire
« on: July 27, 2010, 06:56:14 PM »
so i couldnt find it here but i can be pretty slow what is the widest tire on a stock swing arm 750 with a 530 or 520 conversion
live like an outlaw and love like an angel
crash
blacked out gauges rock
http://forums.sohc4.net/index.php?topic=67710.0
Offline wookie
  • I would get up if i knew i fell
Re: wide tire
« Reply #1 on: July 27, 2010, 07:00:53 PM »
I don't think it's the widest tire but i run a 130 with a 16 inch rim on a 520 chain.  These frames weren't really built for wide rears.  Tires that is.
phudeb
Re: wide tire
« Reply #2 on: July 27, 2010, 07:07:58 PM »
I'm running 130/90 on stock rim.
Offline 77cafe750
Re: wide tire
« Reply #3 on: July 27, 2010, 07:11:15 PM »
thank yall for the info i am tire shopping and was curious thanks
crash
Re: wide tire
« Reply #4 on: July 27, 2010, 08:18:58 PM »
I have a 4.5 inch rear wheel on at the moment, i am going to use an offset front sprocket to make it all line up but won't have much trouble running a 150+ rear tire..
Offline 77cafe750
Re: wide tire
« Reply #5 on: July 27, 2010, 09:03:45 PM »
just a 4.5 rim laced to the stock hub i assume but di you have to offset the rear sprocket in order to make it fit mick
peace crash
crash
Re: wide tire
« Reply #6 on: July 27, 2010, 09:10:19 PM »
Hi mate, no, i am using GSXR stuff so its completely different. I have actually had to machine a little off the Suzuki sprocket carrier to help it all line up...
Re: wide tire
« Reply #7 on: July 27, 2010, 09:12:29 PM »
 The 140 will fit a stock rim, I have even run a 150 with stock sprocket offsets.
 The big tire on stock rims may not be optimal for handling, but if you mainly want more meat-on-the-street.. they will work..
Re: wide tire
« Reply #8 on: July 27, 2010, 09:15:55 PM »
On stock rims  i used to run a 140 Michelin and it worked well, some others may not.   You would be surprised what size you can squeeze in if you have to tools to do the mods.....
Offline 77cafe750
Re: wide tire
« Reply #9 on: July 27, 2010, 10:05:57 PM »
i have plenty of tools and lots of work in my shop at the moment
i just havent got time do much more to sarah right this second i need to get her back on the road finishing custom stock tank custom seat and cowl and rearsets that i may be producing
crash
