Author Topic: Anyone shim out their second rotor instead of the caliper?  (Read 6736 times)
Offline mrrch
Re: Anyone shim out their second rotor instead of the caliper?
« Reply #25 on: August 10, 2010, 10:23:53 AM »
Sweet, I have the lightweight racing ones then :D
my build
Offline Tintop
« Reply #26 on: August 10, 2010, 07:51:54 PM »
Was at the shop today, and mocked up 2nd the caliper.  Measured the offset and dropped the lower pivot off at the machine shop.  Amount works out to 2.5mm(-), which leaves .050(+) clearance to the fork leg.  If needed I have brass shims that I can use to get back some clearence.  Nice easy solution to the 'long boss' problem.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #27 on: August 10, 2010, 09:28:08 PM »
I wonder how the machine shop is going to hold the part square, to machine it? Looking at mine, I can't figure how to do it properly, with the equipment I have.
Offline Tintop
« Reply #28 on: August 10, 2010, 09:44:47 PM »
My guess would be parells under the opposite face.  As to how they clamp it ???.
77 CB550 Cafe build
« Reply #29 on: August 10, 2010, 11:30:35 PM »
Hold it in a chuck or v-block..clock in the top surface, then clamp it..recheck, ...then cut..
