Author Topic: I can change gears without the clutch, is this bad?  (Read 4499 times)
Offline scott_cb650
« on: February 27, 2006, 08:12:56 AM »
I have a 1979 cb650.
I have on occasion, in my excitement, forgotten to squeeze the clutch and shifted gears, both up or down at different times.
It shifted rather smoothly.
I know I shouldn't make a habit of it, but is this an indication of something that needs to be fixed?
Also, as a side note, or maybe a new topic, when I shift to 3rd gear I don't get the "click" feel/sound like the other gears.
Should I worry about it?
Thanks,
Scott
« Last Edit: March 01, 2006, 10:57:34 AM by scott_cb650 »
Why worry about tomorrow for tomorrow has enough troubles of it's own.
Offline dusterdude
Re: I can't change gears without the clutch, is this bad?
« Reply #1 on: February 27, 2006, 08:49:35 AM »
the shifting thing is no big deal,what happens is you are hitting the sweet spot in the transmission where the gears are turning at the same speed and the clutch is not needed.i do this with my car quite a bit.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline volz1fsu
« Reply #2 on: February 27, 2006, 09:11:13 AM »
This is actually a good thing, because it shows that everything is in perfect harmony.  It is Not recomended to downshift like this, that will hurt the transmission.  Upshifting is fine as long as you are hitting those "sweet spots" right.  I used to do it all the time and there was no wear when I took that engine down.
Offline Lumbee
    • My pics...
« Reply #3 on: February 27, 2006, 09:15:42 AM »
some might say shifting like this is good for the bike.  First it saves the clutch as its not being used, and to change gears like this you can't rev to high so you really have to "baby" the bike to do it this way....
...just don't try it from neutral to 1st   ;D
"I'm not a welder, but I play one on HondaChopper.com"
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #4 on: February 27, 2006, 09:33:11 AM »
 Yeah really, an attempt to go from neutral to 1st would be disastrous>  Later on, Bill
Member # 1969
Buffo
« Reply #5 on: February 27, 2006, 11:33:05 AM »
a Clutch is cheeper and easier to replace than the transmission...and I dont recomend that you do it often
eldar
« Reply #6 on: February 27, 2006, 11:53:58 AM »
I would stick with clutch. Even draggers use the clutch in their cars.
« Reply #7 on: February 27, 2006, 06:46:25 PM »
But we don't on the bike.  ;D ;D ;D
Offline dusterdude
« Reply #8 on: February 28, 2006, 08:12:01 AM »
just to get out of the hole,then its no clutch at all,but they use transmissions designed to be used that way too.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
« Reply #9 on: February 28, 2006, 08:30:04 AM »
.....forgotten to squeeze the clutch and shifted gears, both up or down at different times.
What you are referring to is called "Speed Shifting" and is used alot in motorcycle racing. I've used this technique for years, while racing....and is pretty common practice. It is mostly used for upshifts...as doing it downshifting can be quite dangerous is scrubbing speed quickly.
A good rider, who knows his bike can speed shift thru the gears pretty fast....without ever letting off on the throttle. I usually like to like to let off just a tad to get some of the draw off the transmission dogs.
Using this technique on a streetbike wont hurt it.....just make sure you know your gearing. I do it all the time on my CR350 cafe bike.....and she still runs like a champ.
Later,
Greg
« Last Edit: February 28, 2006, 08:32:15 AM by ohiocaferacer »
Offline JonnyHonda
  • I've been ill, ok.
    • Honda-SOHC
« Reply #10 on: February 28, 2006, 01:32:27 PM »
I've always done this on the way up thu the gears, but how many of us dropthe clutch slightly early on the way down, just to raise the revs?
Regards and Ride Safe
<url>http://www.honda-sohc.co.uk</url>
Offline Pinhead
  • 1979 CB652-ST
Re: I can change gears without the clutch, is this bad?
« Reply #11 on: May 02, 2006, 08:02:13 PM »
I always thought that's how you were supposed to shift a bike. Clutch in first and no clutch the rest of the way up.
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline oldbiker
  • I HATE RAIN
« Reply #12 on: May 03, 2006, 01:06:22 AM »
When I was racing, I made all up-shifts without the clutch but down-shifts are better made using the clutch to avoid jerking the transmission which can cause you to lose adhesion at the back if you are heeled over.
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
« Reply #13 on: May 03, 2006, 04:30:09 AM »
I seem to remember Keith Code recomending this technique.
If you apply gently preasure on the gearlever then back off a touch on the throttle, if your gearbox is good it
will slip sweetly into the next gear.
It was common racing practice before quick shifters.
In the UK anything over 40 years old only needs insurance and Fuel.
Offline bill440cars
« Reply #14 on: May 03, 2006, 04:54:54 AM »
         Hey Mark, Nice looking bike in your avatar. Yours? How bout some photos, like to get a look at it, as I'm sure others would also. Later on, Bill
Member # 1969
Super Sport 550
« Reply #15 on: May 03, 2006, 06:09:21 AM »
Unless I am trying to ride slowly and smoothly (who does that?), I don't usually use the clutch except to get moving. Downshifting I use the clutch about half of the time. I have shifted without the clutch at wide open throttle on several of my bikes a couple of times, but you've got to be pretty much at redline.
Of course, I haven't ridden my CB550 enough to find out if it is any different in this respect than the old Kawasaki twins and single cylinder Hondas that I've been riding...
I have done that, usually when I am going to pull out of a corner fast.
Offline Demon67
« Reply #16 on: May 03, 2006, 06:29:51 AM »
I don't know if anyone is old enough to remember the kill switches on brit bikes but it was common practice to wind it up then dab the switch to shift, one could get the bike moving reasonably rapidly that way.
Bill.
Offline bill440cars
« Reply #17 on: May 03, 2006, 06:51:38 AM »
Bill.
                  Oh yeah, I grew up around my Grandfather's motorcycle shop and in the last few years, he
        and my Dad had franchises for Royal Enfield (with and without the Indian name), BSA, Norton, AJS
        & Matchless. Plus, it was a button that you had to hold down (to ground out the magneto) til it
        died and if you let go before that, it came back to life. Oh yeah, I remember, as I'm sure some of
        the others around my age do. Also, the vertical twin and single cylinder Indian models had it too.
        I'm sure there were others (about anything with a magneto).  Later on, Bill
Member # 1969
Offline putnaja1
  • '77 CB 550k -Was gonna cafe, but looks cool stock!
    • Jason's Wacky Website
« Reply #18 on: May 03, 2006, 08:38:44 AM »
Hey, I have a related question here..
So, the general concensus here is that you can shift without a clutch- some guys say it's not hard on the trans, other disagree, but obviously it is possible to shift this way.
So, what if your clutch cable breaks away from home, and you don't have a spare?  You can upshift and downshift, but how would you start out?  If you're at a light, can you put the bike in nuetral, and when the light turns green, run with it, then slam it into first when you get back on the seat?  Also, how would you stop?  Shift it out of gear while moving, and into neutral?
Jason
Play Pinball!
My Gallery!
"The world is divided into people who do things, people who get the credit and people who continually criticize.  Try, if you can, to belong to the first class of people.  There's far less competition"
Offline Lumbee
    • My pics...
« Reply #19 on: May 03, 2006, 08:42:36 AM »
...thats the way I'd do it if I was stuck away from home with no clutch...
Super Sport 550
« Reply #20 on: May 03, 2006, 09:01:45 AM »
I've ridden bikes with no clutches many times. Some you have to push faster than others to get started, but it really isn't that difficult. Some bikes you can just shove on the bars and put it in gear. Others you have to really run with. The only thing I have to say is that you had better be able to find neutral pretty easily, and remember that you won't be able to stop without shifting.
Offline bill440cars
« Reply #21 on: May 03, 2006, 09:19:17 AM »
              Jason, As far as taking off (without a clutch cable) I'd get it rolling and carefully slip it into gear
      and proceed from there. And about stopping, you got it right. Slip it out of gear just before you
      need to stop and use your brakes as usual. If you have to downshift, be careful and try to get the
      feel of it. Hope that helps should the need ever arise. I've done the shifting without a clutch before
      but, it's been awhile. That's one thing about the old Jawas. They had a mechanism, at the end of
      the clutch pushrod, that actuated the clutch everytime you moved the shift lever. You could put it
      into gear, while stopped, and as long as you held the shift lever in that position, you could sit
      there. Now. it took some practice to do a good takeoff but it could be done.
       So, it seems there are several of us with the same basic advice.        Later on, Bill
« Last Edit: May 03, 2006, 09:22:07 AM by bill440cars »
Member # 1969
