Author Topic: '76 CB550K wants to creep in 1st with Clutch lever pulled in  (Read 4896 times)
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« on: October 24, 2010, 01:07:25 PM »
Bike: 1976 CB550K
Very new, please excuse basic question.  Did some searching, but wasn't sure what to call this, so no luck.
I have noticed that when cold, right after start up, even when I pull the clutch lever in, once I hit into 1st gear, it stalls.  A little warmer, and it doesn't stall, but it wants to creep forward in 1st, even though the clutch is still pulled.  It seems to only happen when it's cold (and the warming up period).  After that, it's fine.
So I am wondering if this is a product of bad clutch adjustment (or wrong play in lever), or is it that the oil is needing to get worked around a little bit, and it's a "normal" thing.
Thanks in advance.
Scott
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline HalfTon
Re: '76 CB550K wants to creep in 1st with Clutch lever pulled in
« Reply #1 on: October 24, 2010, 04:47:24 PM »
Sounds like it needs an adjustment. In the service manual it talks about how to adjust the cable. I'd check that out first
77 Honda CB550k Cafe
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #2 on: October 24, 2010, 04:55:59 PM »
I did find and read that part of the manual, but I wanted to check in here first. Because the thing that seems strange (and made me hold off from diving in with the cable) is that it doesn't continue after it's warm.
I'm afraid to mess up the way it works warm to fix the way it works cold. Know what I mean?
~Sophocles
Offline Spanner 1
« Reply #3 on: October 24, 2010, 05:55:28 PM »
I would work on the 'cold' adjustment of the clutch for sure.... re-do the adjustments at the clutch actuator and the cable both ends.... b.t.w... what oil are you using ?
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #4 on: October 24, 2010, 06:08:48 PM »
I seller said the oil is 10w-40 Dino. I confirmed it with him last night by phone.  I know it's suggested to replace once you get the bike from a stranger - but the seller was cool, and lived across the street from a Honda dealer/shop. I actually met the mechanic, and checked the oil myself, it looks clean.
I have read the dino vs. synthetic debates, but that it helps a bit with clutch seems to be "agreed" upon.
I will be checking the clutch adjustments tomw if the weather holds. Any tips you think are missing from the Honda manual?
~Sophocles
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #5 on: October 25, 2010, 07:57:11 AM »
Scratch that!  In searching for Clutch Adjustment, i came across a post by 'Hondaman' stating:
Don't use synthetics, or you might lose your clutch.
I'm just going to bail on the synthetic vs. dino oil debate altogether, and stick with what's been used in this particular bike.  Dino it is for me...
Now, just focusing on the clutch adjustment.
~Sophocles
« Reply #6 on: October 25, 2010, 09:00:05 AM »
You know you have a clutch drag situation.
So, first step is to properly adjust the mechanism, so you can ensure full disengagement (as well as full engagement).
Be aware that warped clutch plates can also cause clutch drag, as well as "tired" or worn out oil.
The oil chosen will have an "additive package" blended with it, whether synthetic, mineral, or organic.  It's the additive package that helps or hinders the clutch.  The clutch doesn't care much about the base oil used.
I've used Honda HP-4 (synthetic blend) in my CB550's for many years without negative impact on the clutch.  It sure makes the shifter/shifting nice.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #7 on: October 25, 2010, 09:09:06 AM »
Thanks TT, I read your post on oil a while back.  The clutch benefits that people spoke about, regarding synthetic blend (plus additive package), made me interested.  But it was hard to figure where the debate ended...
I am going to be doing an adjustment to the clutch, and see how that works out first.  Then the oil choice decision, then the warped clutch check, if all else fails.  I'm making sure not to jump ahead of myself, so as to confuse what's working and what's not.
The only thing that is a tad confusing to me (because I've never done it before) in the Workshop manual, is when it discusses the first step: "loosen the clutch adjuster lock nut and turn the adjuster to align marks on the actuating arm and engine side cover."
So, when I adjust the screw down at the bottom, the arm will move?  Should the cable adjustments be loosened before I do this?  I'm thinking not, it definitely doesn't say that in the manual.
Thanks for all your help.
~Sophocles
Offline L.A. Nomad........
  • 1976 CB550 K
« Reply #8 on: October 25, 2010, 09:50:26 AM »
I had the creep with clutch lever pulled in, it made a screech like noise too and non smooth take off from stop. I adjusted and re-adjusted my clutch, with no results.
It ended up being the routing of my clutch cable.  Also remember to use zip ties or the metal straps to prevent the cable housing from moving.
L.A. Nomad....
I am a fuel-injected suicide machine! I am a rocker! I am a roller! [I’m an outta controller] I am the Chosen One! The Mighty and the Vengeance! Sent down  to strike the unroadworthy! I'm hotter  than a rolling dice!
« Reply #9 on: October 25, 2010, 10:53:12 AM »
The debate "ended" with brand loyalty winning out over any technical merit. (Not that any of the brands offer any technical information.)
At least for diagnostic purposes, you might consider doing what the manufacturer recommends, I.E. Honda oil, on the assumption they may actually know what is best for their machines.  Once you get the clutch working as it should, then experiment with whatever oil brands tickle your fancy.
Yes, I agree the manual isn't crystal clear about that part of the adjustment.
 On the clutch cover is a screw adjuster and lock down nut.
The lever on the clutch cover actuates a cam  that presses on the clutch release.
The screw adjuster positions the entire cam near the actuator mechanism.
When the marks align, the cam should be *just* free of the clutch actuator. (So, the clutch is allowed to be fully engaged when released)
The cam itself is of an over-center design meaning as the pressure from the clutch springs get heavier, the cam provides less movement, thereby creating an increased mechanical advantage.  In other words the more the clutch lever travels, the easier it should be to move the lever.
The clutch cover adjustments should be done first, and the cable length and bar level position should be done afterwards.
The final arrangement should leave the lever with little free play when the clutch is fully engaged (lever let out).  And the last 1/3 of the bar level travel while applying clutch should be easier than the mid point lever position.
This is a lot easier to show in person than describe in text.
In effect, I loosen the clutch cover lock nut, position the case lever align marks, then turn the cover screw so that the internal cam is pressed against the actuator, then back off just enough so that no pressure or resistance is felt on the adjust screw, then lock the nut for the adjuster position.  Then adjust the cable length to position the bar lever where I need it.
That the best I can do for description, I think.
Good luck!
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #10 on: October 25, 2010, 11:39:01 AM »
Thanks so much TT.  I think that description should work just fine. In looking at the case, the dots are almost perfectly aligned. But I will make it perfect, and go from there.
~Sophocles
Offline OneWheelDrive
  • A journey of 1000 miles starts with your first carb overhaul.
« Reply #11 on: March 03, 2011, 01:30:41 AM »
Ok all, I'm having the same issue with my '74 550k, but after replacing the clutch cable with OEM, and adjusting as per the manual, I still can't get the clutch to fully disengage.  This is evidenced by the rear wheel spinning while in 1st when on the center stand with the lever fully pulled.  I started messing with the clutch cable/lever/actuator when I started having trouble finding neutral when at a stop and a hard clunking when shifting into 1st.  This trouble then turned into an impossibility accompanied by stalling when shifting into 1st and/or creeping with the lever fully pulled.
I'm familiar with how the cam pushes the clutch lifter rod and disengages the clutch, but I'm not sure why when the cam is fully actuated why the clutch wouldn't be disengaged.  I've even gone so far as to over tighten the clutch cable to allow me to pull the actuator as far as it will go with the same result.  What would I need to replace/repair in order to fix the problem?  I'm going to pull the cover and change the oil tomorrow and see if anything looks out of whack, but anything to loook for would be helpful.  Thanks!
1975 CB550 cafe
1971 CB500 stocker
2008 Ducati Hypermotard 1100S *sold*
1973 CB350F *sold*
1975 CB550K Project "Keeper" *sold*
2010 Ducati Monster S4RS *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
2007 Vespa LX150 *sold*
Offline fastbroshi
  • Puppet
« Reply #12 on: March 03, 2011, 02:18:30 AM »
I think the instructions for adjusting the clutch may be off if you adjust your clutch with worn clutch disks (marks may not align?). You did have all of your cables loose before you went about adjusting?   Keep in mind that little stud needs to be adjusted to where it just makes contact, then you tighten the lock nut.  You wouldn't tighten it like you would a regular screw.  Then tighten your clutch-end fitting, then the handlebar fitting to fine tune.
Just call me Timmaaaaay!!!
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #13 on: March 03, 2011, 08:52:25 AM »
I thought that was normal. As long as you can stop the wheel by hand. If it still wants to rotate with your hand on it then you got problems.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #14 on: March 03, 2011, 09:14:57 AM »
I gots problems  :-[
1975 CB550 cafe
1971 CB500 stocker
1973 CB350F *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
« Reply #15 on: March 03, 2011, 09:39:56 AM »
Like I said, followed the adjustment directions to a T.  Totally slackened the cable, aligned hash marks on actuator, turned adjuster screw (counterclockwise) till it made contact, tightened lock nut, tighten clutch end fitting, then handlebar adjuster till there is about 1/2 inch of play in the lever.  Lever action feels perfect, more resistance in the first 1/4 pull, then progressively easier.  But I'm still not entirely disengaging the clutch!
1975 CB550 cafe
1971 CB500 stocker
1973 CB350F *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #16 on: March 03, 2011, 09:51:12 AM »
Make sure when you move the screw to make contact, after contact, back it off a little bit before you tighten nut.
~Sophocles
« Reply #17 on: March 03, 2011, 11:25:04 AM »
The more I think about it, the more I think my lifter mechanism may be bent/broken.  We'll see tonight when I dig into it.
1975 CB550 cafe
1971 CB500 stocker
1973 CB350F *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #18 on: March 03, 2011, 12:17:48 PM »
I'm pretty positive that this would be mechanically a jinx. Right after responding to your post, I decided I had messed with the bike enough for today - time for a ride.
Fire her up, check te clutch handle tension and SNAP!  Broke the clutch cable.
I had been planning on replacing it soon, had one waiting to go. Figured now was a good time :)
My issue is I can't wrap my mind around the correct settings on clutch end and handle end of cable to get the damn thing feeling and acting right. No idea what "right" is with the clutch end of the cable, despite people trying to explain it to me ad nauseum.  If I set the handle side to make the clutch work correctly (1/2" of play and all that) it doesn't want to snap back out when released fully. It sorta hangs there limp.
If I get THAT problem to go away, then the clutch is only functioning on the last 1/2" of the throw (all the way away from me sitting on bike).
This clutch business is very frustrating indeed!
Good luck tonight.
~Sophocles
« Reply #19 on: March 03, 2011, 12:26:23 PM »
Ouch, that's no good.
The frustrating thing for me is that I'm not having problems with the adjustment.  It feels perfect, and adjusts perfectly to spec, but does not perform correctly.  That's what makes me think it's a lifter issue, not the cable/adjustment.
1975 CB550 cafe
1971 CB500 stocker
1973 CB350F *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #20 on: March 03, 2011, 12:56:48 PM »
Any tricks with the adjustments?  I'm out on a ride now - and holy #$%* the difference a new cable makes. It's not as bad as thought it would be, but I'd love to get it right.
~Sophocles
« Reply #21 on: March 03, 2011, 01:53:29 PM »
Well, I can tell you how I do it, but take it with a grain of salt as I'm still having issues.
I remove all tension in the cable by loosening the adjuster at the case all the way.  I don't like to loosen all the way at the lever adjuster, I set that one right in the middle so if need be I can loosen or tighten as necessary.  Then I loosen the lock nut and adjust the lifter arm, re-tighten the main adjuster till I can move the lever with my pinky (how I define "free play") about an inch.  Then I fine-tune the free play with the lever adjuster till it's about 1/2 inch.  That SHOULD be all there is to it.  :P
1975 CB550 cafe
1971 CB500 stocker
1973 CB350F *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #22 on: March 03, 2011, 01:57:59 PM »
When you say "retighten the main adjuster" you are talking about the adjustment of the cable on the clutch end?
I think that's my weak spot. I'm not sure where that's supposed to be????
You make it so you can lift the arm UP and inch???
Man, I'm ready for this to be done :)
Thanks for the posts.
~Sophocles
Offline fastbroshi
  • Puppet
« Reply #23 on: March 03, 2011, 08:27:41 PM »
  I know you said you did everything by the book, but it's possible you might have the slotted adjuster opposite of where it should be.  It happens.  I haven't checked that section of the manual in a while.   Are you using a Clymer's?
  Case in point:  I was helping a board member with his clutch.  He was having the same symptoms as you on his 350F.  We adjusted per the manual, making sure to follow directional instructions as they pertained to the slotted adjuster and locknut for the clutch.  Something just wasn't right.  Lo and behold, the adjuster had to be turned opposite of what the manual said.  Even the crappy pictures w/ arrows showing the direction to turn the adjuster were wrong.
« Reply #24 on: March 03, 2011, 11:30:00 PM »
So, I opened up the clutch cover, inspected the lifter arm, even compared it to a donor motor I have and everything looked pretty much good.  I changed the oil and filter.  Reassembled and adjusted again as per the manual, and lo and behold, it's functioning correctly.  This time I was very careful about where to set the lock nut and exactly how much "free play" there was.  It still clunks a bit into first, but a normal clunk, not a slam like before, and neutral is now obtainable when at a stop.  Nort, I hope you get everything figured out, but I think as long as the cable is new and you adjust the clutch end carefully you should be good to go!
1975 CB550 cafe
1971 CB500 stocker
1973 CB350F *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
