Author Topic: 76' cb750k build part 2, GSXR conversion  (Read 58932 times)
Offline Elan
    • Vital Motor Parts
Re: 76' cb750k build part 2, GSXR conversion
« Reply #125 on: February 06, 2013, 08:30:26 AM »
WHOOHOO got some parts done on the waterjet at work...
Speedo bracket, oil cooler bracket, oil cooler valve bracket, discs to cover the old hayabusa holes on the rotor, and brackets to hold brackets:)
76 750k
« Reply #126 on: February 06, 2013, 12:36:07 PM »
Nice... ;)
Offline Elan
    • Vital Motor Parts
« Reply #127 on: February 21, 2013, 08:10:08 PM »
ok it fits!
So we've got...
 2010 harley dyna rim with dual rotor mount holes (using harley sealed bearings that came with rim)
 2004 gsxr1000 forks and calipers (painted calipers black)
 Hayabusa 320mm rotors, redrilled hole pattern with 11/32" bit
 hubcentric rings made to center rotors
 stainless cover plates to hide old holes. (The old holes exposed "chambers" in the hub. I didn't want water getting in there).
 5/16" x 8 x 1" grade 8 bolts for rotors, torqued to HD spec of 16-24ft lb with loctite
 10mm Caliper spacers  and m10 x 1.25 x 70(?) caliper bolts, grade 8
 .712 axle spacers, found them for sale as rear harley axle spacers. width might have been different by a couple thousandths. I can't remember the part number off hand.
Next up...
754 is turning my new stem
Going to weld new brackets on the cb fender to fit up
76 750k
Offline knowsnothing
« Reply #128 on: February 22, 2013, 07:05:31 AM »
Looking good!
1978 CB750k Blue - for sale
Offline sinister902
    • Anger Street Kustoms
« Reply #129 on: February 22, 2013, 08:50:13 AM »
Really have enjoyed your build Elan, I just read through it. I appreciate the information on the front end swap, I've just snagged a TL1000R front end on ebay for $150 complete with clip-ons, triples, and brakes so I am also hoping to get spoked wheels working with it....I'm considering going to supermoto 17" wheels so I can run sport-bike sized tires, might require I fabricate a custom rear swingarm however.....
Offline Elan
    • Vital Motor Parts
« Reply #130 on: February 22, 2013, 10:08:04 AM »
Thanks. Ya sounds like you got a good deal.  Have you looked into the stem dims yet? as you probably noticed, mine was the right bearing dims but too short. I toyed with some options, but am having a new stem spun from 7075al. Do you have a build thread?
76 750k
Offline iron_worker
« Reply #131 on: February 22, 2013, 12:05:48 PM »
I love the front end. Lookin very trick.
IW
Offline sinister902
« Reply #132 on: February 22, 2013, 12:54:17 PM »
I kind of have a build thread....I stopped updating it becuase it had seemed no one was paying attention or interested anymore. The front end is still in transit, should be here monday. I've not measured stem dims yet, but I am actually more concerned with offset....based on the pictures, I think I might have to cut some custom trees anyways, so if I have to do that in order to keep trail in check, I'll just make them utilize the factory 550 stem and I'll press that in to my custom trees.
Offline deafcaferacer
  • "I'm sorry officer, I can't hear you!"
« Reply #133 on: February 22, 2013, 01:57:58 PM »
Fellow MA'er here.. looks like there's a bunch of us.
Getting caught up in here. Great thread!
'73 CB750k engine, hubs, and a '76 tank, on 'a 78 frame. Go figure.
Offline Elan
    • Vital Motor Parts
« Reply #134 on: April 07, 2013, 08:35:23 PM »
behold!
SPecial thanks to 754 for making this beautiful stem! Its so nice I hate to cover it up. THis is going to give me the right height for mounting onto the CB head.  Going to press it into the lower triple tomorrow and should have this project moving quickly now.
Also been working on this guy for a buddy....
putting in a pamco, put my old 750 fork lowers on it, lower bars,  some other things.
76 750k
Offline Elan
    • Vital Motor Parts
« Reply #135 on: April 11, 2013, 08:06:17 PM »
stem pressed and fitted. I also tapped the lower triple to fit  the duc monster headlight bracket.  Speedo is ordered.  Got a nice fender, but need to make some brackets for it.  Also need to balance the tire.
Im surprised the clipons sit a good two inches higher that the old clubmans. Should be a better posture. Gotta learn how to tune these forks...
76 750k
Offline iron_worker
« Reply #136 on: April 11, 2013, 08:21:48 PM »
Wow that's lookin really good. Gold accents on black is almost always a good choice.
IW
Offline chris mcshifty
« Reply #137 on: April 11, 2013, 10:13:56 PM »
Awesome really like it can't wait to see a pic of it on the ground
Offline Elan
    • Vital Motor Parts
« Reply #138 on: April 17, 2013, 04:28:42 PM »
Just got the new speedo/tach. Its a GPS speedo, and the tach gets its signal from the coils. I had them put the honda logo in it, and they moved the tach up to 10k, ya know, just incase ;D  I love how thin it is too.
Think I should keep the stainless plate as is or powdercoat it black?? Seems like it gets dirty fast.
It also records you 1/4 mile, 0-60, altitude, average speed, and a bunch of other stuff i'll use once ;D
« Last Edit: April 17, 2013, 04:30:14 PM by Elan »
76 750k
« Reply #139 on: April 17, 2013, 05:30:23 PM »
The speedo looks nice and clean. The tach is a little small for my taste at least.
« Reply #140 on: April 17, 2013, 07:52:28 PM »
How much is the speedo ?
Offline heffay
« Reply #141 on: April 17, 2013, 08:09:29 PM »
Could anodize it gold to match the forks.
Build looks great, just found your thread, good stuff.  Impressive.
Offline Elan
    • Vital Motor Parts
« Reply #142 on: April 17, 2013, 08:45:45 PM »
Thanks guys.
Gold is an option, but I want to avoid any long turnarounds, and I'm not sure how close the match would be...
The speedo is from speedhut and wasn't cheap, over three bills.   A few times a year they have 20% off, and it has a lifetime warranty.
« Last Edit: April 17, 2013, 08:54:11 PM by Elan »
76 750k
« Reply #143 on: April 17, 2013, 08:47:36 PM »
WOW!  Serious gauge.  I had just looked at their website before your reply!  Very high quality and pricey to match.  Looks like a very nice product.
Offline iron_worker
« Reply #144 on: April 18, 2013, 07:22:49 AM »
Sweet gauge. Pretty cool that they can just put the Honda logo in there for you.
I think I would go with black powder coat on the plate. You don't want atention drawn to the gauge holder you want your eye to go to the purdy gauge and lights! At least those are my thoughts. On the other hand I'm terrible at trying to envision how these things will actually look when they're done. ha
IW
Offline sinister902
« Reply #145 on: April 18, 2013, 10:09:21 AM »
I'll have to watch for that 20% off, I love speedhut's products though, I have their gauge overlays in my Focus SVT
Offline bjbuchanan
« Reply #146 on: April 18, 2013, 12:49:36 PM »
Buy a 35w/40 h4. They will have the lower draw and good light
Offline 65Ch3v3LL3
« Reply #147 on: April 19, 2013, 12:34:22 AM »
Looking good. That is the same gauge I plan on running on my build. Let me know how you like it.
1979 CB650
2011 Harley Road King
2008 Harley V-Rod VRSC DX
2012 Sierra Denali 2500HD
1965 Chevelle Malibu SS
1922 Ford T-Model
Offline Stilltime
  • Building my Dream
« Reply #148 on: May 03, 2013, 10:22:23 PM »
Have you hooked up the speedo/tach yet?  Are you using the stock ignition system?  Wondering how their tach works (if if will work) with the stock wasted spark system or not...
Lookin' awesome!!!
Edit:  found their installation instructions online, looks like the tachs are completely programmable for all different types of ignition systems.  Just need to match it to the original gauge and that's it!
Thanks!
Chris C.
« Last Edit: May 03, 2013, 10:34:14 PM by Stilltime »
'78 CB550 - Orange Crush
Offline Elan
    • Vital Motor Parts
« Reply #149 on: May 04, 2013, 07:26:11 AM »
Havent hooked up the speedo yet, doing a bunch of rewiring first. Ya you can program it to just about any engine as I understand.  My ignition is a pamco and ultimate coils. Should wire to one of those wires... ;D
Its an expensive gauge but it is very good quality and waranted till you sell it. Im eager to see id the speedo gps ever "kicks out"
35/40w huh? so then no need for a relay? Im already setting up a relay but i like the idea of less draw on the charging system than this 55w I have...
76 750k
