Author Topic: Looking for a seat pin for my 750k8  (Read 975 times)
Offline import_tuner13
  • Don't you dare call me a
« on: November 29, 2010, 12:32:16 PM »
Basically the seat pin that mounts the seat to the frame. because one of them was missing when i recieved the bike.  can't find this thing anywhere!  does anyone know if the k6 ones will fit?  they are a different part number, and i'd hate to buy it if it was the wrong item.  any help is appreciated!
thanks!
Dan
bollingball
Re: Looking for a seat pin for my 750k8
« Reply #1 on: November 29, 2010, 01:02:31 PM »
Does it have to be perfect? they have some that are close at Lowes or Home depot. If you have one to match it with if not I will measure mine and send you the measurement.
« Reply #2 on: November 29, 2010, 01:14:24 PM »
doesnt' have to be perfect at all, just has to be functional. so you think any pin would work? just don't want a lot of side to side movement.
bollingball
« Reply #3 on: November 29, 2010, 01:18:28 PM »
Sure like I said lowes they will be in the nuts & bolts section do you have one.
« Reply #4 on: November 29, 2010, 01:19:18 PM »
I do have one to compare.  will probably stop by there tomorrow to see if they can match it.
Offline Ricky_Racer
« Reply #5 on: November 29, 2010, 01:43:31 PM »
It's a 6mm (1/4") diameter. RR
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: November 30, 2010, 09:10:09 PM »
- John Augustus Shedd
Offline mazingerzeca
« Reply #7 on: December 01, 2010, 01:18:45 AM »
The K6 ones don't fit. I tried it.
Offline cookindaddy
  • I sure love this bike!
« Reply #8 on: December 01, 2010, 02:19:02 AM »
They call them clevis pins at the home centers but I haven't seen one small enough around here.
You could find a common nail of near the correct diameter, cut it to length and then cross drill a small hole at the end for the clip that holds it in place?
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline Toxic
« Reply #9 on: December 01, 2010, 04:38:57 AM »
+ 1 on the door hinges.  They are cheap, Cut them, drill a small hole for the clip.
Mine needed a little filing up near the head to make them fit flush
« Reply #10 on: December 01, 2010, 08:50:01 AM »
clevis things for the win.  they have multiple holes for different lengths.  found one that fit perfectly.  could not find the little end clips so i had to use cotter pins.  regardless, the seat is on and is staying on!
« Reply #11 on: December 01, 2010, 12:10:10 PM »
6mm bolt/screw, double nutted?
