Author Topic: NOS on a CB750  (Read 1717 times)
NOS on a CB750
« on: March 17, 2006, 06:19:36 PM »
I am not crazy. I am curious. These SOHC Motors are pretty strong. If one needed a bit of extra zip on occasion,  NOS would be a logocal choice for cheap and simple HP. How would one feed the NOS to an engine with four individual carbs and manifolds ? I have my own theory of how to do it, but I would like to see what others think.
Re: NOS on a CB750
« Reply #1 on: March 17, 2006, 06:30:02 PM »
Not that cheap Bobby but it can be done.
You would need to tap 2 holes into each inlet stub, then you would need another gas supply from the tank.
Beside all the NOS equipment, you realy need a good programable ignition system.
I don't know what the leagalities are for you, but in the UK it's not road leagle.
Sam.
Re: NOS on a CB750
« Reply #2 on: March 17, 2006, 06:39:49 PM »
Sam.
Sam....just need one hole THOUGH it is best to have it in metal as opposed to the rubber boot. I run NOS on my FJ though I use APE adaptor plates (that had to be modified because the original mounting point for the nozzles SUCKED and there were vacuum leaks that smoked the guides and NO ONE at APE listened to me even though I #$%*ED LONG AND HARD). That's for cylinders #2 and #3 Jay. I had to rotate them approximately 25 degress laterally (drill new holes and tap on the Bridgeport and seal up the old ones)) to get them to clear the cam chain tensioner but no one gave a #$%* at APE even when I offered free advice and pics..... My #$%*ing is done.
« Last Edit: March 18, 2006, 06:02:01 AM by MRieck »
Re: NOS on a CB750
« Reply #3 on: March 17, 2006, 07:03:45 PM »
Mike, do you not run a secondry fuel load as well as the gas ?
Re: NOS on a CB750
« Reply #4 on: March 17, 2006, 08:38:03 PM »
Yes Sam but they are mixed in one nozzle. It looks like a Y upside down. One fuel, one NOS into a common outlet.
Re: NOS on a CB750
« Reply #5 on: March 17, 2006, 09:02:14 PM »
OK, I'm with you now spurt, expert that is ;D ;D ;D
