Author Topic: Sneak peak..Don't tell anyone you saw this  (Read 53286 times)
Re: Sneak peak..Don't tell anyone you saw this
« Reply #25 on: September 15, 2015, 11:09:30 AM »
I am not sure what this customer is doing for rods, but we would do this to any 750 sohc crank and supply 2.5 mm shorter Carrillos.
Why can't a base plate be used wth the stock rods?
My very first thought...
Offline SoyBoySigh
« Reply #26 on: May 13, 2016, 01:11:23 PM »
If we all could switch the ignition to the other side, ideally the cycle-X optical trigger - maybe use a total-loss system so you don't need the generator, then a CB900 crank would fit the CB750A primary shaft, right?
So I've gotta ask - if the generator and ignition stuff could be reversed on the DOHC as well, or more to the point use a different adapter to mount each on it's own correct side - then what all could this thing do for the CB900F/CB1100F? Is this a stroker crank for DOHC or really the same stroke anyhow? An alternative stroke length might be interesting for building 999cc-1025cc competition-spec power-plants, for AHRMA etc. I know of a few projects on the DOHC 'F-orum where alternative stroke lengths were used to combine with the RSC DOHC-block and off-the-shelf piston kits, to build a custom displacement to meet class rules of some sort or other.
I had always figured a short-stroke 750 crank and 1123cc kit would make for the best engine, and I guess this is feasible using custom length rods and a block bored out for new sleeves with the oil leak channels welded up shut - the DOHC 750 has the air flow channels between each pair of outer cylinders, whereas the 900 & 1100 are solid between the jugs - hence the need for the oil-coolers to make up for all of those lost fins & surface area, etc.
I put the idea forward, just as a "what if" some years ago, but I was told that the block would have to be skimmed or something, and that the DOHC blocks only have a certain depth of the full size in a "lip" at the top and bottom. Doesn't make sense IMHO, as I was suggesting custom length rods anyhow. Perhaps an adjustment to the cam-chain length even? More like a stretched 750 chain.... Anyway yeah, somebody's building one right now, more or less similar to what I had described. "Great Minds Think Alike" ha-ha.
Well it begs the question though, just what all could be done with yet more alternative stroke lengths. This has got to be soo much "easier" for the GS & KZ folks with their roller-bearing cranks, hey?
Just a brain-fart.
-Sigh.
Offline Vintage King Motor Sports
« Reply #27 on: June 16, 2017, 01:45:50 PM »
Very cool. I won't tell ANYONE!
Offline SoyBoySigh
« Reply #28 on: May 09, 2018, 01:27:46 PM »
The DOHC-4 cranks were 69mm stroke, iirc.
Like I sez, I was always more interested in a SHORT-stroke motor with the 73mm pistons from the 1123cc kit mated to a CB750F crank, for a sub 1000cc displacement that would allow unrestricted diameter carbs in AHRMA "Forgotten Era" - The shorter stroke should help spin things up faster, maybe even keep the piston speed down to the point you can run a much higher RPM than otherwise?
Well then again if you check out Brent "Captain" Hyde's bike, the 69mm stroke doesn't seem to be a hindrance when he's pulling stumps with a 150+RWHP thanks to an original factory race-bike PLUS an extra 40yrs of development....
Even so, yeah - I should think there ought to be some application for a stroke length midway between the 63mm & 69mm OEM cranks?
One has to wonder at the possibilities, where if you're boring out the top crank-case AND going with a custom billet block, AND a custom crank, new sleeves in the block, etc etc - What all might be done if we changed the barrel-to-barrel SPACING? Move the two outer cylinders slightly further outboard, and think of how the bore might stretch even bigger still! Yeah, the valves might have some difficulty lining up - But since we're really only talking about a matter of mere millimeters, one has to wonder at the possibility of a larger valve guide being reamed eccentric to the outboard, and that bigger diameter valve guide needn't be all THAT much of a hindrance not of we're talking about a fully ported head. Right? I mean, YEAH - it's a whole lot more work. Pretty outrageous stuff.
Dunno whether the crank already EXISTS with the standard main bearing spacing, yet with the two outer rod journals spaced further outboard. The most ridiculous thing you'd have to do would be a PRESSED-UP crank, with or without roller bearings shoehorned into milled out crank-case journals - Of course since we're only talking about a couple of millimeters, it MIGHT be feasible to grind out a couple of mm's to one side or another - Surely the crank webs wouldn't be TOO thin at that point?
One way or another, SURELY it's FEASIBLE somehow? Expensive as hell, yeah. Perhaps as a pet project for some wealthy "captain of industry" in the engine building racket? Ha-ha.
What all would you need? However many mm's you expanded over the current max bore, you'd need HALF that for the off-set, correct? So if you're talking about a 75mm bore you'd go outboard one millimeter? 77mm would require two mm's? Not only for the crank, the block, but also the valve guides?
Gotta wonder what the new theoretical limit might be. The holes carved into the top case, however much material were left on the top face? The  gap required for the cam-chain tunnel & the tensioners fitted within with their roller pins? The crank webs themselves? The included valve angle? The exhaust ports?
From what the aforementioned DOHC-4 monster tells us, it would seem like you sure don't want your inlet tracts to be even MORE twisted out of the straight through & through. If you can't build the exhaust outlets and carb inlets far enough outboard, so as to run everything straight as the crow flies, well apparently THAT's  the real limitation on power production - or so I'm told.
IMHO, there's a lot of potential in adding fins to the outer walls of the water jacket on a later era liquid-cooled motor, making retro-fried side covers for 'em, maybe a nice polished round-domed valve cover - something which LOOKS for all the world like the SOHC-4 series, but which is really a CBR954RR engine at it's heart. Or a V65 Magna with a shaft-to-chain conversion ala Magni MV-Agusta or Yam' XS-Eleven, etc etc, done up as homage to the Cezeta CZ Type 860 - Or a copy of the CB750P7-ii 5-bolt dual-disc 40-spoke front hub, along with a wire-spoke conversion of the 5-lug COMSTAR rear hubs to effect a wire-spoke conversion on the GL1100 & GL1200 BIG 'WING and then grab some sort of BEEMER race fairing, move the cross-brace on the swing-arm for a taller rim & tire, and thereby whip up a bigger displacement version of the Doncque DLF-1000 Endurance-Racer!
Well either which way, yeah - I think there's massive potential in doing the retro-fried treatment on the later era motors, in addition to the expected bodywork & running-gear etc.
As for the SOHC-4, I should think the missing element isn't so much in the motors as the CHASSIS - If we could have a decent batch of EGLI replica frames, or more to the point the twin-shock "spine" type frame from MOTO-MARTIN. But above all else the Akront "NERVI" rims for some rebuilt COMSTAR wheels, half the weight in equivalent sizes, available in any width you could possibly dream up for a SOHC-4, all the way out into the 6.0x18" type of stuff which barely looks sensible on a CBX six but let's say IF you wanted something that ridiculous on a SOHC-4 you could have it, or COULD'VE had it, if only we'd begun to rebuild our Comstar wheels BEFORE they were yanked from production! Yeah, if we can get the MORAD people to bring 'em back, we could do some truly awesome stuff with the SOHC-4, get 'em around the track a whole lot quicker.
IMHO a really important part would be a 296mm spec caliper hanger for the 'F2 dual-disc fork (& subsequent DOHC-4 versions of which) not to mention a new center-carrier & caliper-hanger to adapt the 260mm 6-rivet front rotor from CB350F & CB400F onto the 6-bolt & maybe even 5-bolt rear disc hubs - maybe even a 10-bolt pattern to suit 5-bolt AND 6-bolt rear hubs? Paired up with a caliper-hanger to suit, made so as to KEEP the original single-puck calipers (or an exchange-basis modification of the earlier opposed-pair twin-piston rear calipers, the axle hole welded shut & re-drilled etc etc) All of which would be intended for a complete OEM look on a far far better all 'round brake package.
Maybe a new top half clam-shell case/housing for the throttle side cast alloy handlebar switch housings, with the SPORT-KIT style cable reorientation from the DOHC-4 & CBX550F etc. Simple matter to adapt the Sport-Kit rear-sets peg hangers to the 'F2 maybe even the 'F1 alloy peg brackets - The CB1100R alloy pedal is a nice fit but imho it just plain looks better to cut down the OEM pedal and "telescope" it back together.....
Just sayin' - there are a ton of NON motor related elements of these bikes which could use an upgrade. And when they're done in a STEALTH upgrade, it might just stem the tide of all this STARBUCKS RACER nonsense we've seen these past ten or fifteen years, with the USD forks & 17" cast wheels, the billet shillet bedazzled all over the place, rendered in purple anodize like some sort of radioactive bird poop has landed all over the bike? BLECH. And more to the point - MEH. If we could only make it easier to improve things in the OEM style, maybe people wouldn't just want to throw some random crotch-rocket's complete front end at these bikes?
A bit more expensive, to be sure - but not quite so much if they're whipped up in batch production. And everything to be offered piecemeal, step-by-step. The bigger front discs, the thicker fork, the thicker front axle, the lighter weight yet wider Akront "NERVI" rims for the COMSTAR wheel rebuild, perhaps an exchange-basis service for milling weight out of the rear hubs whether Comstar type OR the wire-spoke - And of course the smaller rear disc center-carrier & matching caliper hanger. A custom FRAME copied from one of the greats, maybe all of 'em? But each one amenable to the OEM bodywork, suspension, running-gear etc? Well mainly the brakes & axles & OEM period-correct (more-or-less fork swaps, etc. The SPORT-KIT stuff in retro-fried SOHC-4 four-mat? Just little KITS is all. One step at a time.
HUGE potential for that kinda thing, imho.
-Sigh.
Offline dragracer
  • CB750F Dragbike
« Reply #29 on: June 11, 2020, 01:38:54 PM »
Are any of these cranks still available??
Offline jweeks
« Reply #30 on: May 15, 2021, 07:24:24 PM »
Frank and all,
     Used 900F cranks are readily available. The metal is machinable. I'm running one on my drag Hondamatic. The power "chain" is the same as the automatic takes. You machine one end to match the 750 timing end, using the casting line for where you drill for the pin that goes into it. There are Goldwing transmissions that use the automatic parts going to the transmission. I've never played with that end of things. Slight metal removal is required to spin the 900F crank in the 750 case. The strength of either won't be compromised much. If you're playing with forced induction; that's another story.
     The other end of the 900 crank is splined. There is a stock sleeve that fits over the splined end. You can make a starter clutch and a thin power generating disc fit into the area available on the spline. See Cycle X for alternative power generation parts. In theory, you can make it self starting and have enough power generated for any street use. I welded a starter nut onto the sleeve for external starting of my drag bike. (Total loss system)
     I've talked with Jay at APE about crank stroking. The stock cranks can be stroked up to +5mm. The oil holes get too offset for any bigger strokes. The 900F cranks also can be stroked by APE. How much? 2-3 mm more on my Automatic cases unless you want to relieve the case for the rod throws.
     There's an outfit in Australia that offers a big cc offset bore setup for the CB750's. The pistons look like they came from some other bike brand; the rods aren't very strong looking. They grind one side of two rods big end and add (weld?) more on the other side of the big end. Bearings come from something else.  If my memory is right, the kit was for 75mm bores. If you are looking for big cc's remember that most porting jobs can't put enough air through stock diameter intake valves. My drag motor is very flat through the midrange. There is no peak power. I'm going for bigger intakes to match the demands of the motor.  For what it's worth....
Offline bear
  • Leeton in Australia
« Reply #31 on: May 17, 2021, 10:37:53 PM »
We used to turn our DOHC cranks around then machine the taper end off.
No starter, no charging.
M4 rods from select DOHC 11'000's.
Very reliable using 70mm or 72mm pistons, going to 75mm reduced reliability quite a bit.
We used 410 heads, intake +1mm, exhaust -.5mm.
Good HP, good tourqe, low rpm.
« Last Edit: May 17, 2021, 10:43:53 PM by bear »
Offline Old Scrambler
« Reply #32 on: June 23, 2024, 11:02:42 AM »
May BIG JAY rest in peace :) :)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
