Author Topic: starter delete  (Read 2007 times)
Offline wannabridin
  • Patience made me a
  • -Garrett
starter delete
« on: February 02, 2011, 06:37:31 PM »
guys.  i've tried searching, but i got a bunch of info that didn't quite all add up.
i'm trying to delete the starter completely on my build and i need some advice on what all will be required to save and get rid of.  i know i can ditch the starter motor, and i have a plug coming from Voxonda to act as a plug and a crank vent.  i seperated my rotor from my crank today and i'm wondering if i can get rid of the starter gear, or if i still need that for the bearing assembly on it's ID.
also, do i need a starter relay at all for the electrical system?  i'm going to run a Hondaman ignition box, and also a digital guard dog RFID system, just for some extra piece of mind.  i might also try to run the wires through as much of the frame as i can, for cleanliness and also for some extra security.  (i know i'm being very optimistic about this, but i want it!!
if someone has totally taken out the kick starter, and has a walk through or info, i would appreciate it!  thanks again guys!
Offline Silverback
Re: starter delete
« Reply #1 on: February 03, 2011, 07:15:58 AM »
What bike? You should be able to pull the starter gears with no issue.
The starter relay is a connecting point for the charging system, battery and main power. It can easily be eliminated but you have to rewire to maintain the charging and power connections. (Red, red/white and battery should be connected to each other)
red/white-charging
red(2)- main power from battery and out to fuse block
Yellow/red- starter (eliminate)
green/red- ground from clutch switch(eliminate)
« Last Edit: February 03, 2011, 07:20:33 AM by Silverback »
Chris
"It's hard to define soul. You get it in art. You get it in music, and occasionally you get it in machinery."
78 CB750F racer
78 CB750F stock
75 CB750K Baby Blue Sold (She was a great bike!)
71 CB750K (rusty rod)
77 cb550F Sold :(  Bought it Back :)
Basket case 73 CB750, 77 CB750F (Building now)
01 Aprilia Falco
76 kz400
96 BMW K1100LT
Offline carguy5387
Re: starter delete
« Reply #2 on: February 03, 2011, 03:22:02 PM »
Yeah, I'm planing on doing the same thing. My main hang up is not being 100% clear on how everything works as the completed and then stripped down system. I'm no motorcycle mechanic... Anyone know of a good info source?
Offline wannabridin
  • -Garrett
Re: starter delete
« Reply #3 on: February 03, 2011, 04:16:07 PM »
It's a '76 750k.  I need to wait to button up the cases to see how the starter gear bearing installs and if it's really necessary...
Offline Silverback
Re: starter delete
« Reply #4 on: February 03, 2011, 04:48:10 PM »
Are you talking about the starter/sprag gear behind the rotor? I know you can remove the gear that is in direct contact with the starter spur. The sprag should be removable also. The only real benefit would be a little less bearing drag since it does not spin when the motor is running. I would leave it in should you need to install a starter at some point. You might have tuning issues at some point that won't allow you to kick it over.
Chris
78 CB750F racer
78 CB750F stock
01 Aprilia Falco
76 kz400
96 BMW K1100LT
Offline wannabridin
  • -Garrett
Re: starter delete
« Reply #5 on: February 03, 2011, 06:41:24 PM »
i was thinking about leaving it for that exact reason.  as much as i don't want the starter, should i ever need it for some reason, this option would allow me to use it.  i could get away with a "hot wire" w/o having a starter relay.
on the other side, i do have a stator puller, so throwing the sprag gear back on wouldn't be that big of a deal if i needed to add the starter back later, with the motor installed.
