Author Topic: 1975 cb750 purchase  (Read 1112 times)
Offline maliveline
1975 cb750 purchase
« on: February 12, 2011, 04:26:33 PM »
So this guy is selling a 75' cb750 and hes asking 1600 bucks. The bike has appx. 40k+
miles on it. apparently one of the exhaust pipes is cold to the touch when the bike is running. Could this be a simple spark plug replacement or would I be getting myself into a world of problems with this purchase?
1972 CB750
Offline Ernest T
Re: 1975 cb750 purchase
« Reply #1 on: February 12, 2011, 04:46:11 PM »
Yes and yes.  I've got an SL-100 that started as a simple tune up and ended up as a case replacement because the oil drain plug was JB welded in to fix a cracked case. I have an XL350  that I need to tear down to replace a mainshaft oil seal, but I have an CB1100F that I paid little for and has been perfect.  Like the man says, "You pays your money and takes your chances"
That could be a spark plug, coil or spark plug wire, a blocked carb, or a something worse.
What's the bike look like otherwise?
Offline kck3
« Reply #2 on: February 12, 2011, 04:46:40 PM »
Could just need simple cleaning of the carbs.  The plug could be getting fouled and not firing.
« Reply #3 on: February 12, 2011, 05:13:02 PM »
Doubt it's just a plug but most likely not a major fix.
You should use that and 40K milage to talk him down on price.
Got pics?
Offline maliveline
« Reply #4 on: February 12, 2011, 05:26:28 PM »
here
1972 CB750
bollingball
« Reply #5 on: February 12, 2011, 05:58:22 PM »
Pull the plug and see if it has compression.
« Reply #6 on: February 12, 2011, 07:02:49 PM »
Pull plug and check for spark
Offline kck3
« Reply #7 on: February 12, 2011, 09:51:23 PM »
$1600 seems high-he had that bike plus another bike bundled together for $2000.
