Author Topic: Trimming rear brace/filling in open tube ends  (Read 1010 times)
Offline Sheik Yerbouti
  • Likes the warm feeling but is tired of all the dehydration.
« on: March 27, 2011, 10:01:09 PM »
So I've been trimming away at my frame to cut down on some useless (to me) brackets and chopped the back of the frame because it fit my seat poorly otherwise. But I left the back bracket in place. I was contemplating doing a rear hoop (think wrenchmonkees) but decided to just stick with my original seat plan. This isn't my frame, I'm just using it for illustrative purposes. I want to trim the frame where the red line is.
Now I am not quite sure how to plug those ends. Any frame modifiers have any suggestions? Also, I don't think that trimming the brace a little bit like that will effect it structurally, but I wanted to consult you guys first.
Offline beveldrive
Re: Trimming rear brace/filling in open tube ends
« Reply #1 on: March 27, 2011, 10:36:59 PM »
Well Sheik, I chopped and mig'd in a couple of steel ovals, like this...
« Reply #2 on: March 28, 2011, 08:51:44 AM »
If I chop my frame where I was intending I believe that the rails are actually circular at that point. So I guess I could find a piece of material and use a hole saw, but there would still be a hole from the mandrel bit.
What thickness of material is appropriate? I have some 1/8" thick angle iron hanging out that I could hack up.
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #3 on: March 28, 2011, 09:43:45 AM »
The I.D. of the tubing is the same as a 7/8" handlebar so hit a bicycle shop and ask the wrench to give you a couple of bar end pls.u
« Reply #4 on: March 28, 2011, 02:36:02 PM »
NICE!
« Last Edit: March 28, 2011, 02:39:46 PM by Sheik Yerbouti »
