Author Topic: a little help with purchasing a dyna set  (Read 1750 times)
Offline worlddrum13
« on: April 01, 2011, 10:21:18 AM »
im looking into getting coils and ignition from Dyna for my 750 k6. im a little confused with the coils. i understand that i would replace the factory coils with 5 ohms. if im getting the electronic ignition then i can go with the 3 ohms.. am i right? just a little question i want to make sure before spending the dyna prices
thanks in advance
75 750 k6
Offline Kong
Re: a little help with purchasing a dyna set
« Reply #1 on: April 01, 2011, 02:07:13 PM »
As long as your bike is basically stock and the charging system is up to snuff it should work just fine for you with the 3-Ohm coils.  But if you've added things that give additional electrical draw, things like HID headlights, grip or glove heaters, passenger intercom systems or other sound systems, additional lights - anything of that sort, then you would be better off going with higher resistance coils (5-Ohm) because they will reduce the power-demand of the ignition system, leaving power for your other requirements.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline Skunk Stripe
« Reply #2 on: April 01, 2011, 02:18:27 PM »
Just a point of interest. Halogen lights pull more wattage. HID lights pull less.
Offline Kong
« Reply #3 on: April 01, 2011, 02:36:22 PM »
Thank you, I didn't know that.
1978 Honda CB550K
1977 Honda CB550K
Offline Owned
    • Finished Product
« Reply #4 on: April 01, 2011, 02:38:41 PM »
Look up Dyna's website and give their tech line a call.  I've found that with the CB400F some members here recommend the 3ohm and a few the 5ohm...Dyna was quite helpful and gave me the lowdown.  5ohm is the way to go to avoid over taxing your charging system.  The performance difference is NEGLIGIBLE.
'01 Ducati 900ssie
'74 Honda CB350F
http://www.flickr.com/photos/indyrider/sets/72157619944545142/show/
'73 Honda CB350/400F Hybrid
http://s1231.photobucket.com/albums/ee520/indyrider2/?albumview=slideshow
'64 Honda CB160 Soon to be unveiled!
Offline Steve F
« Reply #5 on: April 01, 2011, 05:13:21 PM »
Off topic....sorry, but OWNED, I just GOTTA see that bike up close some day, I think I'm in love   :P.  Maybe when we get that way with the world relay in the next month or so?
Steve F
Offline wrenchmuch
« Reply #6 on: April 01, 2011, 05:31:36 PM »
If you stick with points for a while the points will wear out faster due to higher current loads across the points with 3 ohm coils . If you think you might stick with points use 5 ohm coils .
CB750K1
CB750K4
Offline worlddrum13
« Reply #7 on: April 02, 2011, 07:05:27 AM »
so i decided on the dyna s system with the 3 OHm coils. my next question is the wires and caps. whats a suppression core wire compared to a copper core?
75 750 k6
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #8 on: April 02, 2011, 08:17:19 AM »
The suppression core usually has a non-conductive core that's carbon-impregnated. Sometimes, they use a coil of very fine wire wrapped around the core. The original idea was to suppress electrical interference that can screw with AM radio reception. These days, the suppression is to prevent interference with the vehicle's computer. Our bikes used leads with stranded metal cores, because they're more durable. The suppression is accomplished with 5,000 ohm resistors in the plug caps.
Stu
MCN DTF
Offline worlddrum13
« Reply #9 on: April 02, 2011, 08:42:35 AM »
Stu
my
so is there a reason to get suppression wires for my bike? there is no computer but it will have electronic ignition
75 750 k6
Offline Kong
« Reply #10 on: April 02, 2011, 12:23:07 PM »
Nope, no need for you to suppress anything other than as a courtesy to the poor slob next to you at a traffic signal in his fully computerized Lexus.  Him you could hurt, but you're bike is as safe as a dinosaur from minor pulsed electromagnetic emanations.  When I bought mine it was (Dyna) copper wires from coil to plug for me and let the rest of the world struggle through as it may..
1978 Honda CB550K
1977 Honda CB550K
Offline worlddrum13
« Reply #11 on: April 02, 2011, 12:35:18 PM »
sounds good thanks for the info! last question. Z1 seems to have pretty good prices on this stuff. anyone know of anywhere else to catch any deals? already checked ebay. not much on there right now
75 750 k6
Offline jbailey
« Reply #12 on: April 02, 2011, 06:52:39 PM »
Z1's price is a deal, AND Jeff provides great service.  Why buy from a stranger?
1975 Honda CB550K
2005 Kawasaki ZG1000 Concours
