Author Topic: What is everyone stripping off to save weight?  (Read 42602 times)
Offline Mekagojira
« on: April 09, 2011, 07:43:23 PM »
I still want to get rid of the center stand - but I use it a lot…
what else can I get rid of?
1975 CB750F
Offline hesselfuzz
Re: What is everyone stripping off to save weight?
« Reply #1 on: April 09, 2011, 08:28:01 PM »
Great idea for a post. Center stand is the most obvious to me. Since you're in LA, the fenders (?), esp. the rear. There isn't much extra on the old motorcycles. It's more a matter of replacing parts with lighter ones. The beefy part of the front fender is a support for the forks. Your lights mount to the rear fender so you need to do something about that but that whole rear fender/ light/ plate mount weighs a ton. The stock seat pan weighs more than it needs to. Lighter battery. Then you start playing with ounces.
Ciao
Moderation is a fatal thing, the only success is in excess.  -Oscar Wilde
73 CB750k
78 CB750ss
70 CB750k
06 Buell Ulysses
Offline GammaFlat
« Reply #2 on: April 09, 2011, 08:39:53 PM »
You can go with lighter wheels - the 750A had aluminum hoops.  The GL1000 front wheel (aluminum) is usable I think.
I been eating less lately too.
What's the purpose of the desire for the bike to weigh less?  It might be easier to just increase your horsepower if it's about acceleration.  :)  There's plenty of ideas and able vendors around here to help you with that. :)
« Last Edit: April 09, 2011, 08:51:01 PM by GammaFlat »
K6
85 Goldwing
« Reply #3 on: April 09, 2011, 09:03:19 PM »
C-stand can be
eliminated at home like this;
 Get 2 4x4 (or bigger)wood pieces, that just slip one under frame, on right side while it is on sidestand. then go to left side , lift bike up level with the bars..or grabrail, the put 2nd block under frame on left side.
 4-1 pipes save weight
 E-start and related parts saves 10 lbs or more.
 If you dont change rear fender, lighter taillight, and removing grab bar  takes off a bit.
 Most mag wheels are lighter, and some are wider.
 Alternatotr can be lightened.
 I use early switch housing on rt hand side, then eliminate left side housing, and run a Magura dogleg lever or similar.
 use only 1 mirror.
 Ceriani or Betor forks save a bunch of weight but are walletwounders.
 -3 braided lines save a bit and you can remove junction if you choose to not run brake pressure switch.
 and more stuff..
« Reply #4 on: April 09, 2011, 10:07:24 PM »
Chips and dip, and the french fries...  ;D
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #5 on: April 09, 2011, 11:33:42 PM »
FWIW, the GL1000/CB750A rims are only about a pound lighter than the stock steel rims. You don't save all that much on overall weight, but it is very helpful reducing unsprung weight.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline Hush
« Reply #6 on: April 09, 2011, 11:33:58 PM »
Beer and fat chicks! ;D
« Reply #7 on: April 10, 2011, 01:44:17 AM »
C-stand can be
 use only 1 mirror.
 and more stuff..
i dont have my centre stand fitted,but i slip it on at home for chain lube or rear wheel removal,less the over centre spring etc,then just slip it of again.
« Reply #8 on: April 10, 2011, 02:32:57 AM »
man!technically if that guy walked into the scooter shop and wanted to buy that they would have to void the warranty?and on a legal note if a cop saw that its way over its designed load rating,imagine the poor brakes on a long decent?
Offline dhall57
« Reply #9 on: April 10, 2011, 03:19:35 AM »
I don't guess this guys ever heard of P90X
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline MoMo
  • Ride like you're invisible
« Reply #10 on: April 10, 2011, 05:39:41 AM »
Here's his long lost riding buddy
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
« Reply #11 on: April 10, 2011, 05:53:50 AM »
I like to strip off my drawers.  Saves at least 2 lbs and aids with cooling ;D
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
Offline jakecb420
« Reply #12 on: April 10, 2011, 06:49:32 AM »
+1
750K3 daily driver
76 750F project
74 CB450 donor
79 50cc honda express 2 moped
73 cb500-4
http://forums.sohc4.net/index.php?topic=73724.0
Offline vames
« Reply #13 on: April 10, 2011, 07:27:46 AM »
Is it just me, or does the benefit of having a center stand greatly outweigh the benefit of shedding 10 lbs of weight off your bike? Things like lubing the chain are a lot easier when you can lift the back tire off the ground and spin it.
Offline 333
  • Time for change
« Reply #14 on: April 10, 2011, 07:43:18 AM »
I would ask why do it at all.  Unless you're racing, shedding weight does virtually nothing.  Maybe if you could get 10 more MPH, but you'd be lucky to get 2.  And if we're talking MPG, you probably wouldn't see even 1.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline dhall57
« Reply #15 on: April 10, 2011, 08:20:08 AM »
This goes against the subject of this post, but I'm not stripping anything off to save a few pounds, and unless your are in a major cafe project where your redesigning the bike anyway and the only thing that looks like  a Honda  when done is the SOHC engine, I don't see the point in taking off usefull parts like the centerstand and other items to reduce the weight a little bit. Is it going to increase your MPG enough to make it worth it, I don't think so, will you be able to tell any difference in acceleration, I doubt it, will it make it handle like the bikes of today, no way.
I'm keeping my overweight, outdated 35 year old bike just like it is, but to each his or her own ;D
« Last Edit: April 10, 2011, 09:25:06 AM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« Reply #16 on: April 10, 2011, 08:26:54 AM »
You can still lose the stand and keep it handy for working on the bike. This is what I did.
Get a pair of pliers and some pennies. With the stand up, and the spring stretched, insert pennies in between the spring coils. Put the bike on the stand and remove the now loose spring. Put the bike back on the side stand, and just loosen, not remove, the pinch bolts for the stand pivot tube. Remove cotter pin in pivot tube. Slide tube out of frame, releasing center stand from bike.
Now, whenever you want to lube your chain, remove it, work on the rear wheel, etc.,etc., just hold the stand up to the frame, slide the pivot tube back in, and put the bike on the stand. The spring is just there to keep the stand from dragging on the ground, so using the center stand without it is no problem. I have done this for 20 years, and have never had a problem or dropped one of my babies.
The center stand, pivot tube, and spring on a "78K weighs damn close to ten pounds.
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
« Reply #17 on: April 10, 2011, 10:09:59 AM »
I could never be bothered to put a c-stand back in, for oiling or a tire change..takes too long..
 Make a set of blocks ..30 seconsds or less to get it up..
 If you dont feel shedding 10 % or more off your bike is worth it dont...
 but dont live under the delusion, that your motor in Scottly's 405 lb cb750, wont be quicker than you 500 LBer
Offline Kong
« Reply #18 on: April 10, 2011, 11:05:01 AM »
If I were really looking for weight savings I'd start with the wheels.  The old Honda assemblies are awfully heavy.  A good bit can be saved by going to aluminum rims.  Its a shame we don't have sprockets available to easily adapt a belt drive, that would save the weight of the chain, which is considerable.  Then there's the fenders and stock tail light assembly - heavy in comparison to a glass unit and minimal tail light.  Same thing for the turn signals, get rid of the monsters in favor of smaller - go to LED's at the same time.  There are little bits to be chopped off the frame, but they don't amount to much.  Smaller battery of course, and then consider a smaller tank - gas weighs 7 pounds per gallon.  On the front end lose the fender, lose the stock headlight mounts in favor of some clamp on aluminum ones, get rid of any extra rubber work up front.
All together you won't get a lot of weight off one one, but if you set a realistic goal, say 25 pounds or so, then I'd say that is achievable.  What will it get you?  Well, you will be able to beat the guy who doesn't do it.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline paulages
  • 1976 cb735
« Reply #19 on: April 10, 2011, 11:29:29 AM »
Have the weight-saving naysayers really never ridden a light bike? It's not necessarily a matter of going faster in terms of the power to weight ratio, it's about how much easier it is to handle a light bike.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline vames
« Reply #20 on: April 10, 2011, 12:24:04 PM »
Just saying that SOHCs are by definition not light bikes. Even if the poster earlier saves the 10% he's talking about -- 50 lbs -- it's still a heavy bike.
Then again, I ride a 400f which is the lightest of them. For exactly that reason.
Offline paulages
  • 1976 cb735
« Reply #21 on: April 10, 2011, 01:06:23 PM »
I have mine down to 385# dry.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline jakecb420
« Reply #22 on: April 10, 2011, 05:22:50 PM »
if you are working on a 75 750f like the one in your info zone, the stock header and muffler are pretty heavy. i feel like i lost the most weight switching to an aftermarket one on my f, that was easier for me than cutting back on pop.
750K3 daily driver
76 750F project
74 CB450 donor
73 cb500-4
« Reply #23 on: April 10, 2011, 06:23:09 PM »
thank you ...+1
« Reply #24 on: April 10, 2011, 06:58:52 PM »
I bet she stops better as well.  ;)  Taking weight off improves handling and stopping, makes the bike more "flickable. All of these improvements can be the difference between a good ride and an accident......You'll never know till you try it..... ;)
