Author Topic: it started life as a Test-rig  (Read 36646 times)
Offline voxonda
Re: Test-rig
« Reply #50 on: June 14, 2011, 02:36:00 PM »
Good news Rob. You've got all summer to prepare.
Wish I had some of you guys over here to help me out, Brent. For sure would make life easier.
Cheers mate, Rob
Re: Test-rig
« Reply #51 on: June 14, 2011, 04:06:10 PM »
You don't want me around Rob, I seem to be going backwards.
Offline Tintop
Re: Test-rig
« Reply #52 on: June 14, 2011, 04:24:01 PM »
Any other plans for an outing between now and September Rob?
There's a hill in Moncton were up is down, and down is up, are you sure backwards isn't forwards.  You seem to be getting a handle on what the issues aren't. ;)
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline voxonda
Re: Test-rig
« Reply #53 on: June 15, 2011, 01:00:52 AM »
Do not worry to much Brent, I for one have the confidence that you'll sort things out. Like everything in life, to come to 90% is 'easy' but that last 10%.......................................
Keep up the good work.
Rob
Offline voxonda
Re: Test-rig
« Reply #54 on: June 15, 2011, 01:07:25 AM »
Am looking at several occasions. First have to get the bike prepped with lights, battery in seat, put some paint on it. Bike is running fairly well already, want to mount your kit on it to see what that does and Dyno it.
Problem here are the noise regulations. I really do not want to run it silenced.
Cheers, Rob
« Last Edit: June 15, 2011, 01:09:09 AM by voxonda »
  • Moderator
Re: Test-rig
« Reply #55 on: June 15, 2011, 03:00:16 AM »
Cheers mate, Rob
I've got the hands if you have the spanners, shout me anytime, busy 17th July.
Sam. ;)
Offline voxonda
Re: Test-rig
« Reply #56 on: June 15, 2011, 04:24:46 AM »
Thanks Sam,
Will keep that in mind. :D
Cheers, Rob
Online simon#42
  • liverpool
Re: Test-rig
« Reply #57 on: June 15, 2011, 09:59:52 AM »
with luck you wont be too busy on the 17th sam , just doing a few fast runs !    am taking ' your bike' on a test ride to spa in a couple of weeks sam , will arrange to drop it off at yours as soon as im back so you will have a week or so to get a bit of practice in .
Offline Howell
  • Honda the power of dreams
    • CB500 classic racing
Re: Test-rig
« Reply #58 on: June 17, 2011, 12:20:19 PM »
Well "VOXONDA Classic Endurance Team" has signed up for the 3 hour Endurance race-demo on septembre 10th at Aalsmeer in the Netherlands. So the test-rig will have to proof itself. Happy to say that my two heroes of the past will ride the bike. Myself as a back up rider.
Really looking forward to this.
The intention is that Team Howell , Yrjo and me ,  participate also on this event with my CB750F2 with an 860cc engine.
You meet the nicest people on a Honda
Offline voxonda
Re: Test-rig
« Reply #59 on: June 17, 2011, 12:33:32 PM »
Hey Howell,
Please read the regulations carefully, seems they only allow up to 750 with only a small margin.
Do not want you to be dissapointed.
Hope I am wrong.
Rob
Offline voxonda
Re: Test-rig
« Reply #60 on: June 19, 2011, 02:33:06 PM »
Well we're of and running in preparation for that 3h run. A lot of relative small things need to be done or taken care of. Found a guy who will upholster the seat for me, for a good price. Build the 'rig' with the intention to just test parts, but now it needs to run in front of a audience so have to make her neat and tidy. Found no sponsors, so budget is not there. Luckily most of the technical part is already taken care of and have build the engine for reliability so that should 'do the trick'. Hopefully.................. ::)
'cause of the nature of the track will have to shorten the end gearing. Running 17 : 48 now on a 520 chain, so need to find a 520 16 or even a 15 tooth sprocket. Anybody got a source, if not have to turn down 530 ones. Will try to save some more weight, specially on the rear wheel.
Re: Test-rig
« Reply #61 on: June 19, 2011, 03:08:56 PM »
Honda XR500 used 520 sprockets, and the spline on my friend's '82 model looks to be the same as the 750, but I'm not 100% sure.
Re: Test-rig
« Reply #62 on: June 19, 2011, 05:05:55 PM »
Rob I bought 520 fronts from JT Sprockets. Part #'s are JTF281.15 and JTF281.16. They are good quality plus full 530 width through the center where they ride on the countershaft.
Offline voxonda
Re: Test-rig
« Reply #63 on: June 20, 2011, 10:38:35 PM »
Honda uses the 25 x 6 spline a lot.
Cheers, Rob
Offline voxonda
Re: Test-rig
« Reply #64 on: June 20, 2011, 10:39:13 PM »
Thanks Brent, I am on it now.
Cheers, rob
Re: Test-rig
« Reply #65 on: June 21, 2011, 06:09:06 AM »
Hey Rob, I forgot to mention this. Check the JT website. The sprockets I mentioned are slightly larger on one spline than the 500/550/750 countershaft. I wasn't aware of this until I went to their site when I was investigating. The 350/400 fours and the twins and all the rest of the Hondas using similar c-shaft sprockets use a 1mm?? larger spline in one axis.
It accounts for a touch more play on the shaft, but I didn't concern myself with this on mine. Just thought I should mention it.
Offline turboguzzi
Re: Test-rig
« Reply #66 on: June 21, 2011, 09:30:32 AM »
Rob,
Belgium/French made (?) AFAM sprockets might be easier to find in NL...
can give you the part numbers i am using if you want.
They are extremely well made
Online simon#42
  • liverpool
Re: Test-rig
« Reply #67 on: June 21, 2011, 10:27:32 AM »
Rob,
+1    very well made
Offline voxonda
Re: Test-rig
« Reply #68 on: June 21, 2011, 11:29:01 AM »
Rob,
Hey TG,
Yes please , if you want to give me would help a lot. Thanks guys.
Cheers, Rob
Offline Jim F
  • go baby go
Re: Test-rig
« Reply #69 on: June 21, 2011, 12:45:08 PM »
Hey Rob
If you want to compare wast sizes you should see me on sams drag bike
Needless to say I wont be looking for leathers anytime soon
glad to see the big guys back on the toys
Jim
(Big)
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline turboguzzi
Re: Test-rig
« Reply #70 on: June 21, 2011, 12:58:43 PM »
Rob,
Hey TG,
Cheers, Rob
look for AFAM 20500-15 and 20500-16,
20500-17 doesnt exists but that's the one size you've got :)
just to make sure, these are 6-spline hole  with 22 internal/25 external dia. used in different XL's & XR's  but worked well on my 500/4, would be surprised if they dont fit a 750...
Re: Test-rig
« Reply #71 on: June 21, 2011, 03:09:05 PM »
That's what I was trying to mention. The JT 520's use the same spline 22x25mm. The 750 countershaft spline is 21x25mm.
I never knew that until a year ago, it's good to always keep learning my mother told me.  ;D
I can hear Sam laughing from here.  ;)
Offline turboguzzi
Re: Test-rig
« Reply #72 on: June 22, 2011, 12:55:31 AM »
brent,
have a look at the afam catalog, around the "honda area" 20500 or so,
http://www.gasimports.com.au/downloads/afam/2Tech_front.pdf
 i think there is no sprocket with 21 ID.... the shafts might be 21 but seems there's no sprocket out there that makes use of the full extra 0.5mm depth (per side)
Offline voxonda
Re: Test-rig
« Reply #73 on: August 22, 2011, 01:53:55 AM »
Been awhile, but we're back.
Got a 16 teeth sprockets that will be turned down. Bike is in it's finishing stages of preparing, mounted the lights and charging system and it all works. now it is time to give it some color, and finetune the carbies.
Rob
Offline Tintop
Re: Test-rig
« Reply #74 on: August 22, 2011, 05:10:46 AM »
Looking forward to hearing how the 'test' goes in September Rob.
77 CB550 Cafe build
