Author Topic: cb headers on a cl  (Read 983 times)
Offline bigragu
cb headers on a cl
« on: May 01, 2011, 02:40:43 PM »
Any suggestion on how to fix the issue of fitting these cb pipes into a cl engine seems like the collar at the end of the cb headers are smaller then my cl headers, doesn't quit fill the space in the cylinder?
Offline tbpmusic
Re: cb headers on a cl
« Reply #1 on: May 01, 2011, 05:35:17 PM »
What bike??
For 350/450 I can say without question they should be switchable with no issues......
Bill Lane
Offline bigragu
« Reply #2 on: May 01, 2011, 06:43:29 PM »
It's a cl350, you would think they would you could swap them but no such luck. The pipes from my cl have a thicker collar then the cb pipes, might have to have someone at a machine shop make me some custom spacers?
Offline tbpmusic
« Reply #3 on: May 02, 2011, 09:23:18 AM »
You have to be more specific about your model with 350's.
Part # 18233-318-000 (COLLAR, EX. PIPE JOINT) is same for
 CB350G A MOTORCYCLE, JPN, VIN# CB350-5000001
 CB350K3 A MOTORCYCLE, JPN, VIN# CB350-3000001
 CB350K4 A MOTORCYCLE, JPN, VIN# CB350-4000001
 CL350K2 A MOTORCYCLE, JPN, VIN# CL350-2000001
 CL350K3 A MOTORCYCLE, JPN, VIN# CL350-3000001
 CL350K4 A MOTORCYCLE, JPN, VIN# CL350-4000001
 CL350K5 A MOTORCYCLE, JPN, VIN# CL350-5000001
« Last Edit: May 02, 2011, 09:25:44 AM by tbpmusic »
Bill Lane
Offline bigragu
« Reply #4 on: May 02, 2011, 01:57:20 PM »
Looking at the pic on Bikebandit it looks like the collars for the cb are longer then the cl that"s probably the problem.
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #5 on: May 04, 2011, 06:58:02 AM »
Probably not the problem. The part numbers for both the collars and finned joints are exactly the same on both the CB and CL. Might be a matter of terminology, though. What are you referring to as a collar? Are the headers stock Honda or aftermarket? A picture of the problem might help.
Stu
« Last Edit: May 04, 2011, 10:09:28 AM by chickenman_26 »
MCN DTF
Offline bigragu
« Reply #6 on: May 04, 2011, 02:01:34 PM »
I don't have a pic, but it seems as though the collars or half circles are different lengths making the cb header lose unlike the end of the cl header which has a welded on spacer from the factory which is adding to the collars.
