Author Topic: Need help on an oil seal!  (Read 2969 times)
Offline Bakeoff
« on: May 11, 2011, 10:33:14 PM »
I'm doing a little refreshing on my 74 cb550 motor and ran into a few things.  With the front sprocket cover removed, it was very obvious that a chain had broken at some point.  The case is hacked, but nothing that will cause any issues.
The problem I'm having is with the oil seal (about 1.25" in diameter) just forward of the sprocket.  The chain hit it and it has a small slice in it.  So, I have two things I need help with:
1. I can't find the damn seal on any of the online sites.  I've checked bike bandit and a few others, but I can't find the seal in any of the diagrams.
2. Can that plug be removed without splitting the cases?  I'd like to avoid splitting them since I was only ripping it down to replace leaky head pucks, which I need to source too.
Any help would be huge!
Re: Need help on an oil seal!
« Reply #1 on: May 11, 2011, 10:40:05 PM »
Thats not a seal its a plug
To replace it you have to split the cases
last i heard it had been obsoleted
try westernhillshonda
part number 91207-374-000
Offline Bakeoff
« Reply #2 on: May 12, 2011, 07:34:36 AM »
I take it, its flanged on the back?
I should probably also replace the seal on the shifter rod, but I can't find that one either.
Offline Duanob
  • Bold Timer
  • Gotcha!
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline strynboen
« Reply #4 on: May 12, 2011, 10:04:28 AM »
hey mine have also that slice ..but så long it are tight and not leak.. dont fix it..the plug and seal have some "dots" who fits in block..so they can not be thanged witaut to split the block..have tryed to remove some on my 400 four..but tjek that 550 are same way..have not have open the blok on my 550..
« Last Edit: May 12, 2011, 10:18:15 AM by strynboen »
i hate all this v-w.... vords
Offline Bakeoff
« Reply #5 on: May 12, 2011, 01:03:28 PM »
Thanks guys!  At least I know its available!  Mine currently has a small slice in it and I found oil in the chain cover when I removed it.
Offline strynboen
« Reply #6 on: May 13, 2011, 06:37:37 AM »
normal kome that oil  leak from pump.. try to klean  all up..and make an test run
« Last Edit: May 13, 2011, 06:39:10 AM by strynboen »
Offline Hannibal Smith
  • 3rd Grade Dropout
« Reply #7 on: May 13, 2011, 07:35:46 AM »
As posted above, it might not be leaking. That plug has a steel disc molded into the "plug" to give it rigidity, and it has to be worn pretty bad to start leaking. I would definitely clean that whole area up with some Simple Green (etc.) and then find out if it really is the culprit.
My old 550 motor before the rebuild was leaking from the pump or the shifter shaft, even though it looked like it was coming from that "plug"..................make sure!
Follow my build "P38 Racer" in Project section
Offline domer
« Reply #8 on: May 13, 2011, 10:01:44 AM »
make sure its you have the right size chain on there too.... too big of a chain will leave that mark.
Offline Bakeoff
« Reply #9 on: May 13, 2011, 11:09:24 AM »
Like I said in the first post, the previous owner had a chain break at some point.  There is damage to the case and the sprocket cover that makes this very obvious.  The plug itself has some of the rubber coating peeling back and there is a visible slice in the metal of the plug.
That said, I know the shifter seal is also leaking.  The Oil pump was clean, but I replaced o-rings on that yesterday.
I was just asking if I could replace it without splitting the cases.  No worries guys.  I'm good.
Offline Fritz
« Reply #10 on: May 15, 2011, 08:06:58 AM »
Hi Bakeoff,
 I'd say 'maybe' the seal can be replaced without splitting the cases. It does not have any ridge or groove in it that could prevent it from being pushed in. Might be difficult to hammer it in without hurting the rubber coating though.
 Here are some pics showing the damage. On the third picture you can see a dent in the metal cup on the left side that indicates that the metal is quite weak here. If it gets rubbed through, oil will weep out.
 Since the transmission main shaft is not pressure lubed, this leak might be fixed with sealant without the need to replace the seal.
 But the correct way to change this seal is during a rebuilt of the bottom end, including splitting the cases and exchanging all seals. Here's one source four this seal:
 http://www.cmsnl.com/products/oil-seal-kitcb550k_90000374000/
 It conveniently comes along with all other seals required to seal the shafts in the bottom end for the next ten to twenty years.
 Good luck
 Carsten
« Last Edit: May 15, 2011, 08:08:46 AM by Fritz »
1976 CB550F
