Author Topic: q's on oil lines & sprockets  (Read 1183 times)
comcrx
« on: April 24, 2006, 08:24:12 AM »
hey all. coupla questions...
1) one of my oil lines has a small leak, I'm 90% sure its from the fitting at the engine. can this just be recrimped, or does it have to be replaced?
2) at 55 mph, in 5th gear, I'm turning at 4k RPM's. how much smaller of a rear sprocket can I go to where at 55 I'm only turning, say, 3K?
thanks for any replies,
andy
Offline dusterdude
Re: q's on oil lines & sprockets
« Reply #1 on: April 24, 2006, 08:59:35 AM »
andy,on your sprocket question.i dont think you can go down to 3000 rpm and stll be able to get off the line.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
comcrx
« Reply #2 on: April 24, 2006, 09:58:22 AM »
I suppose I should go downstairs and count the teeth on my sprockets, but does that MPH/RPM sound right? as it is now, I'd be a little weary of even doing 70 for longer than a minute or two?
theunrulychef
« Reply #3 on: April 24, 2006, 10:30:15 AM »
Andy, these bikes were made to rev relatively high.  You're barely in your power band at 3-4k.  Don't be afraid to push the RPMs.
comcrx
« Reply #4 on: April 24, 2006, 07:28:06 PM »
so, as long as the air is flowing to keep it cool, its ok to run it at higher RPM's, sweet!
thanks!
Offline GroovieGhoulie
  • I have to return some videotapes.
« Reply #5 on: April 24, 2006, 07:33:06 PM »
My 400F is doing 6500 at 70 and 7K or so at 80.  No worries here mate!!!
At 55, she's "barely ticking over" at around 5K give or take a few hundred.
