Author Topic: KO  (Read 1503 times)
Offline azporkey
  • Az Porkey
KO
« on: June 27, 2011, 10:22:20 AM »
Last ko built?? All frame & engine numbers & date. Thanks so much.  azporkey. Help me Glenn.
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
Re: KO
« Reply #1 on: June 27, 2011, 11:27:58 AM »
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Offline azporkey
  • Az Porkey
Re: KO
« Reply #2 on: June 27, 2011, 06:31:30 PM »
Thanks ZZ ,something still is not right.Mine built 7-70. before 71 came out but the numbers don't match. What yhe hell????? AZPORKEY
Offline the technological J
  • deliciouso!
Re: KO
« Reply #3 on: June 27, 2011, 09:12:23 PM »
cases frames  engines and ID plates can be changed
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline Bob Wessner
  • "Carbs Suck!"
Re: KO
« Reply #4 on: June 28, 2011, 04:22:53 AM »
Which numbers don't match? If you are referring to the frame vs. the engine numbers, they never do.
Offline azporkey
  • Az Porkey
Re: KO
« Reply #5 on: June 28, 2011, 01:20:47 PM »
I know the engine & frame don't match. I guess I would like to know the last KO numbers??? At what time frame did it become a 71??????????????? azporkey many thanks to all.
Offline zzpete
  • You better get an
Re: KO
« Reply #6 on: June 28, 2011, 02:49:26 PM »
According to the chart CB750-1044650 frame number was the beginning of K-1 on 09/21/70. I double checked those numbers with the Mark Haycock book "Honda CB750" and they are the same!
Offline azporkey
  • Az Porkey
Crazy
« Reply #7 on: June 28, 2011, 04:36:24 PM »
 8) 8)But my bike was made on 7-70. two months before the 71 came out???????????????azporkey Thanks for sending me that info ZZ.
Offline zzpete
  • You better get an
Re: KO
« Reply #8 on: June 28, 2011, 04:41:25 PM »
Put up your frame serial number. X out the last 2 digits if your not comfortable doing so. I have a 5-70 in the garage with frame # CB750-1036XXX
Offline kirkn
Re: KO
« Reply #9 on: June 28, 2011, 04:48:37 PM »
According to here:  http://www.motorera.com/honda/h0750/four.htm
the K0's began with CB750-1000001
the K1's began with CB750-1044650.
No mention made of a calendar date.  I think you might be getting off track on the build date and the "release date" that gets kicked around.  I guess I'd go with the frame serial number as to whether it's a K0 or not.
« Last Edit: June 28, 2011, 04:51:52 PM by kirkn »
Offline dhall57
Re: KO
« Reply #10 on: June 29, 2011, 03:25:46 AM »
My KO has a mfg date of 4/70 and frame VIN#1031XXX
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Hinomaru
Re: KO
« Reply #11 on: July 05, 2011, 02:28:19 PM »
The date is unknown, but the last K0 built had:
Frame number: CB750-1044947 and Engine number: CB750E-1045147
Source: Original CB750 by John Wyatt
