Author Topic: AN-10 hose for CR oil lines?  (Read 2626 times)
Offline ttr400
    • ttr400 Projects and Billet parts.
« on: August 02, 2011, 10:47:05 AM »
Need to make up the oil lines for my Cr750 build. This is what I know so far.
I would like to Use the pro light black cotton braided hose, sizes listed and converted to metric are 20.06 OD and 14.22 ID for AN10. The std 750 hose measures 22.0 OD and 13.0 ID.
Question: Is AN10 the correct size to use? What do you guys use or could recommend? or point me in the right direction.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline Tintop
Re: AN-10 hose for CR oil lines?
« Reply #1 on: August 02, 2011, 07:19:47 PM »
I used Aeroquip StartLite AN8 hose on my 550 remote filter setup.  However it is only 11.17 (.44"), so I would think the AN10 would be the better choice for the CR750 dry sump setup.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline voxonda
« Reply #2 on: August 03, 2011, 12:27:52 AM »
I used the -10 when using the oem oiltank setup. Actually still do use -10 on my present setup.
Cheers, Rob
Offline lordmoonpie
    • Moonpie
« Reply #3 on: August 03, 2011, 12:41:23 AM »
Hey Kevin,
I used Earls braided -10 hose on my CR, which has a Mead Speed (Bartel) tank and it's very much nice and oil tight so I think you will be fine with AN10 black cotton braided hose.
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
  • Moderator
« Reply #4 on: August 03, 2011, 02:41:44 AM »
It's looking real good Kevin. 8) 8) 8)
http://www.ttr400.com/photo_2.html
Sam. ;)
Offline ttr400
« Reply #5 on: August 03, 2011, 04:28:58 AM »
Thanks Guys, looks like AN10 it is then,
Glad you like it so far Sam. I'm getting there.
Kevin
www.ttr400.com
  • Moderator
« Reply #6 on: August 03, 2011, 05:36:33 AM »
Kevin
Credit where credits due Kevin. ;)
