Author Topic: Need to remove this before Powder Coating? (solved... sort of)  (Read 1487 times)
Offline westondc
  • Wes Mantooth
I'm about to powder coat my frame, i have it completely disassembled and cleaned. there is only one item have haven't been able to remove and thats item 6 in the picture below. it's the small hard rubber bushing in the swingarm where the rear shock attaches. i suppose i could get a bearing puller or press them out but if i can get away with powder coating and leaving them in I will do that. ideas?
« Last Edit: August 14, 2011, 08:47:53 PM by westondc »
B.O.X.N.I.F.E. Hospital fund https://www.everribbon.com/ribbon/view/8352
Rider no. 115 on the 2012 SOHC/4 Honda World Tour
Rider no. 274 on the 2011 SOHC/4 Honda World Tour
1972 Honda CB500k1
1971 Honda CB350k3
the project http://forums.sohc4.net/index.php?topic=64499.0
Trip/Project Blog http://easterntowestern.blogspot.com/
just be a vagabond, living out of a backpack on a little Honda, cruisin all over the damn place....
"As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?"
Offline CycleRanger
  • No comment about being an
Re: Need to remove this before Powder Coating?
« Reply #1 on: August 14, 2011, 05:28:19 PM »
Yes, they should be removed. Otherwise the rubber will burn up when the powder coating is cured.
Offline westondc
  • Wes Mantooth
« Reply #2 on: August 14, 2011, 05:29:50 PM »
yeah thats what i figured. anyone with a good idea how to remove these on the cheap?
1972 Honda CB500k1
1971 Honda CB350k3
Offline david 750f
  • 1976 CB750F
1976 CB 750F
Offline westondc
  • Wes Mantooth
« Reply #4 on: August 14, 2011, 05:51:31 PM »
Thanks david 750F, just what i was searching for.
1972 Honda CB500k1
1971 Honda CB350k3
Offline haggeo
« Reply #5 on: August 14, 2011, 08:31:17 PM »
i'm not doubting this but just for the record i had my frame powdercoated before i knew about having to remove those bushings and they are both fine. i do have two new bushings and i'm replacing the old bushings just because the old ones are...old.
Offline westondc
  • Wes Mantooth
« Reply #6 on: August 14, 2011, 08:47:29 PM »
i'm guessing it also depends on the temp and length of time its baked. I'm not sure how the place i'm having it painted does it. i tried a similar method of removal to the one mentioned in the thread above but these little guys are stuck in there real good  :-\
1972 Honda CB500k1
1971 Honda CB350k3
Offline camelman
  • Man... Myth... Legend
Re: Need to remove this before Powder Coating? (solved... sort of)
« Reply #7 on: August 14, 2011, 10:52:24 PM »
I've powder coated a few swing arms now, and just leave those in.  They'll take the heat fine, and I cured at 350F.  If you are concerned about the temp, then check with the paint shop to see what temp they use.  If they are 350 or lower, then don't worry about it.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline westondc
  • Wes Mantooth
« Reply #8 on: August 14, 2011, 11:21:41 PM »
i think i'm going to see what temp the shop bakes at and leave them in. i tried to remove them myself tonight but there going to have to be pressed out by a pro. worse case scenario; the rubber bakes off and i take it in and have them pressed out and new ones pressed in.
1972 Honda CB500k1
1971 Honda CB350k3
bollingball
« Reply #9 on: August 15, 2011, 12:29:46 AM »
You can press them out with a c-clamp and large deep socket.
Offline Lostboy Steve
« Reply #10 on: August 15, 2011, 06:06:55 AM »
Everything that's not metallic must go.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #11 on: August 15, 2011, 06:08:14 AM »
A bench press or a vice with two sockets.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #12 on: August 23, 2011, 01:05:10 PM »
I literally just had my swingarm done and to my amazement  they left them in...
- Sent from my iPhone using Tapatalk
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline westondc
  • Wes Mantooth
« Reply #13 on: August 24, 2011, 11:43:29 AM »
yep, they told me i could leave them in and cover them with some washers and a bolt. we will see how it turns out next week
1972 Honda CB500k1
1971 Honda CB350k3
Offline camelman
« Reply #14 on: August 24, 2011, 01:23:44 PM »
They'll be fine.  Powder coat requires high temps, but not high enough to damage that rubber.
