Author Topic: Easy 77 550 carb question.  (Read 775 times)
Offline whtwter
« on: August 22, 2011, 11:18:04 PM »
 After vacation for a month My float bowls are leaking badly!! I cleaned and adjusted the carbs 6 months ago but didn't replace the O rings. I am assuming I will have to sync the carbs after pulling them but am wondering if I will need to do other adjustments as well?
Thanks Chris
Offline whtwter
Re: Easy 77 550 carb question.
« Reply #1 on: August 22, 2011, 11:24:07 PM »
If it wasn't obvious I am pulling the carbs to replace the float bowl O rings.
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: August 22, 2011, 11:27:57 PM »
As long as you're not messing with the slides there's no need to re-synch.
Offline whtwter
« Reply #3 on: August 22, 2011, 11:43:04 PM »
Thanks Gordon.
Offline dtmmil
« Reply #4 on: August 23, 2011, 02:51:01 AM »
Probably need float needles also.
Offline whtwter
« Reply #5 on: August 23, 2011, 03:21:56 AM »
Float needles? Please explain. Fuel is coming out the seams on the float bowls. Would float needles sticking cause that? I am  guessing it is the float bowl o rings as they were not great when the carbs were rebuilt but if I should be looking at other things while they are apart please explain so I can cover all bases.
bollingball
« Reply #6 on: August 23, 2011, 03:37:40 AM »
Fuel level should be just below gasket. You probably need to drop the bowls and spray the shut off valve (needle) while moving the float up and down. look for trash in the bowls.if there is some find out  why.Make sure float moves freely
