Author Topic: Steering  (Read 734 times)
Offline patlac
Steering
« on: August 24, 2011, 11:50:11 AM »
 Hi to all I have a problem with my 1977 400/4. When I am pushing it and turn Bars to the left the Brakes bind going Fotward or Reverse Turning Bar to right no problem, I removed Caliper and checked pistons and cleaned them.No good anyone have this problem. Itis suggested that I change Brake Hoses but the previous owner had fitted new ones. Any other suggestions
Re: Steering
« Reply #1 on: August 24, 2011, 12:32:18 PM »
wheel bearings?  The thought being the hub carrying the rotor, is shifting, putting the rotor in a bind in the caliper.
I've heard of this, but never actually seen it. Wheel bearings do not need a lot of miles to be bad. Really old can cause problems too.
Offline Gordon
  • 750K1, 550K2
Re: Steering
« Reply #2 on: August 24, 2011, 12:34:31 PM »
Check the routing of the brake hoses.  You said the PO installed new lines.  They may be routed in such a way that one is getting pinched when turning the bars.
Offline patlac
Re: Steering
« Reply #3 on: August 25, 2011, 11:28:12 AM »
Thanks for replies Guys I believe that they are new wheel bearings but I will check also Line routing Will keep you posted.
