Author Topic: How can I get this apart?  (Read 868 times)
Offline veloracermike
« on: November 25, 2011, 06:48:21 PM »
This is how my rear sets are attached now.  Anyone have any idea how to get this off the heim joint?
« Last Edit: November 25, 2011, 07:20:05 PM by veloracermike »
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: How can I get this apart?
« Reply #1 on: November 25, 2011, 06:51:49 PM »
Just threads off the rod.  ???
The heim loint and shift arm are not separable.
If you need you can use a shift arm from a CBR and purchase heim joint that fasten with a bolt.
« Reply #2 on: November 25, 2011, 07:19:15 PM »
I mean heim joint not rod end sorry.  So a CBR shift arm will do, what do you recommend for the brake side (same situation)?
Offline Trav-i
  • Has finally become an
« Reply #3 on: November 25, 2011, 07:55:50 PM »
If all you want is the splined part, I would take a cutoff wheel and split the mushroomed end as deep as possible.  Then put it on something that would act as a heavy backing ie a vise or anvil, then hit the spilt with a good chisel.  It should crack right where the mushroomed end meets the small through shaft.  It's the same way I get past stripped machine screws.
Forum member #9962
1992 GL1500 Interstate
« Reply #4 on: November 25, 2011, 08:09:49 PM »
I think I just need new donor arms.  I can just cut down a stock shift lever for that side, but the brake side is the question. The stock 350F brake arm is a big ol'e tubular thing.
Offline Trav-i
« Reply #5 on: November 25, 2011, 08:20:50 PM »
Check out the Dime City Cycles website.  They might have what you're looking for.
Forum member #9962
