Author Topic: CB550 Centre stand removal  (Read 4245 times)
Offline iancb550
« on: January 14, 2012, 07:22:19 AM »
Hello all, glad to be on the site :) yet another new member. Hopefully it's ok to start with a question: -
I bought a 1978 CB550F Super sport today, the centre stand has a piece snapped off it which has rendered it unfortunately rather useless so I intended to remove it and buy a restored stand.
I have taken out the small pin, and I have undone the bolts on each side of the stand, I then tried to tap the large pin around which I assume the stand moves out with a screw driver wrapped in rags and a rubber mallet. So far I have got little to no movement from the pin and I just wondered if anyone can tell me if I am going about this the right way.
I have not removed the spring from the stand as I had read on a similar post that it made it easier to remove the stand, unfortunately they didn't shed much light on how to remove the big pivot pin (if that's the right name for it).
Thanks in advance  :)
Offline iancb550
Re: CB550 Centre stand removal
« Reply #1 on: January 14, 2012, 07:27:26 AM »
  Here she is by the way incase anyone wanted to see :)
Offline SohRon
« Reply #2 on: January 14, 2012, 07:49:23 AM »
You might have to spread apart the frame clamps that hold the pivot pin in. Just undoing the bolts won't open the clamps, you'll have to do it with your screwdriver. There's really nothing else holding it in.
« Last Edit: January 14, 2012, 07:54:13 AM by SohRon »
Offline mjstone
  • I'm definitly not a
« Reply #3 on: January 14, 2012, 07:58:14 AM »
Nice lookin' bike!  Welcome to the Forum.  Be sure to post in the 500/550 registry thread.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline iancb550
« Reply #4 on: January 14, 2012, 08:54:31 AM »
That's great thanks for the advice, I wish the bolt on mine looked as shiny and tidy as yours, I get the feeling it's not been off since it left Japan in 78 to be honest. I am guessing that yours has had a total strip down and powder coat etc? Hopefully the spreading of those bolt areas should let it move more freely :) Looking forward to trying it tomorrow.
Going to go and try and add it to the registry now :)
« Last Edit: January 14, 2012, 08:56:16 AM by iancb550 »
Offline Danno
  • 74 CB550,75 GL1000,76 KZ400,77 GL1000,73 CB750
« Reply #5 on: January 15, 2012, 04:28:54 AM »
I use a drift if it is rusted in but you have to spread those clamps
when you own a motorcycle the wife does not have to find you handy she just has to find you
Offline SohRon
« Reply #6 on: January 15, 2012, 07:34:01 AM »
+1 There may be some rust or old, dead grease holding it in. A little heat on the CS pivot tube may help loosen things up.
Yep; that's all in the "Assembling my '74 CB550" thread in my signature
Offline iancb550
« Reply #7 on: January 15, 2012, 09:17:27 AM »
Cheers again for the advice all, I am hoping to be able to try again this week, I had to go and get some other basic bits today for it to ensure it's all road legal :)
I saw your in depth thread on your rebuild just shortly after I sent my reply was really interesting, I think I might be able to look through that for quite a few questions I might have too.  8)
