Author Topic: RE: CB750 Need Help Installing Heavy Duty Studs  (Read 4751 times)
Offline chewbacca5000
  • I polish covers!
« on: January 25, 2012, 07:07:42 PM »
I am rebuilding the top end on my K3 most of the machining is done and now comes the fun stuff putting the whole thing back together again!  I just need to know how many pounds are used to install the cylinder studs.  Also how many pounds to torque down the head.
Thanks!
Re: RE: CB750 Need Help Installing Heavy Duty Studs
« Reply #1 on: January 25, 2012, 10:53:29 PM »
When installing the studs, make sure you don't over-bottom them, as it is possible with some of them to break out the bottom of the thread casting boss. I think it's the short ones from API that can let you do this, so once you reach bottom, don't crank hard.
The API recommendation on final assembly is 20 ft-lbs: look on the back of their package, or on the insert sheet for the details.
  • I polish covers!
« Reply #2 on: January 26, 2012, 05:09:30 AM »
Thanks Hondaman!  Much appreciated.
Offline markb
  • When I finish my current project I might be a
« Reply #3 on: January 26, 2012, 06:08:39 AM »
As I recall the torque into the cases should be 8 ft.-lbs. maximum.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
« Reply #4 on: January 26, 2012, 08:54:35 AM »
What keeps the studs from turning out next time the head cap nuts are removed? loctite ?
  • I polish covers!
« Reply #5 on: January 26, 2012, 09:32:46 AM »
This is a very good question.  I am planning on just making sure the threads are clean and installing the new studs.
« Reply #6 on: January 26, 2012, 10:04:00 AM »
I can't answer the question absolutely, but there are a lot more threads in the case, than there are threads in the nut.
I don't think I've ever heard or read that loctite of any type should be used. I just snugged mine down to 8ft lbs. I think i got that number from Big Jay at APE, or his underlings.
« Reply #7 on: January 26, 2012, 10:15:18 AM »
I've never really done the procedure myself  :)..was just wondering.I would imagine that there is some resistance to the threads going into the cases that may hold them in?
« Reply #8 on: January 26, 2012, 11:11:15 AM »
I use red loctite on mine and do not use much torque. If I need to remove them I use heat. I also place a cylinder and head on (after installing the studs) then lightly snug up head nuts to to improve the stud alignment. I allow it to sit for a couple of days for the loctite to fully cure.
« Reply #9 on: January 26, 2012, 11:31:44 AM »
mrIECK: AS always, thanks for the insight!   :D
« Reply #10 on: January 26, 2012, 05:22:41 PM »
great stuff!
I usually get them after the corrosion has become an adhesive that makes red Loctite look like grease....those are REAL secure! :D
« Reply #11 on: January 26, 2012, 07:20:46 PM »
You're welcome MC and thanks for the compliment. Torquing those studs into the case distorts the threads and, IMO and Smokey's, defeats the purpose of the studs. I always set the studs to the height I want....the Loctite will hold them in place and make for a real stout assembly.
« Reply #12 on: January 26, 2012, 07:22:26 PM »
great stuff!
Thank you Mark. I hear you about the corrosion....awful stuff.
« Reply #13 on: January 26, 2012, 08:16:43 PM »
great stuff!
This reminds me...I'm starting on the Performance Book. Could I beg some pics of your work, especially the enlarged valves and those Carlsbad Cavern inlet ports? Please drop me an e-mail at mgparis@concentric.net .
