Author Topic: Points plate Can you install it wrong?  (Read 1398 times)
Offline adams77
« on: May 27, 2006, 06:31:04 PM »
I am trying to get my eBay parts bike I just bought to start, everything is there I have gas and I have spark and I have compression...so I should be able to run.
I was checking the timing using the static method of placing a probe on the blue wire and turning the crank over till the probe lights up but I am out of adjustment slot before I can get the F line to line up.
 Could I have something on wrong?  I have the peep hole at the top and I can see the 1-4 mark when the bulb lights but I can not turn the plate far enough to line up the F mark.
BTW I used the plate and advance mechanism from another year motor (I assumed they are interchangeable)
Offline Lumbee
    • My pics...
Re: Points plate Can you install it wrong?
« Reply #1 on: May 27, 2006, 06:59:01 PM »
...not sure what you mean here...need more splain'n...
"I'm not a welder, but I play one on HondaChopper.com"
Offline adams77
« Reply #2 on: May 27, 2006, 07:11:52 PM »
The F line here in the pic is too far to the left when the probe light comes on , and the points plate mounting holes are slotted for adjustment of the timing, but Im too far off.
Offline Lumbee
    • My pics...
« Reply #3 on: May 27, 2006, 07:58:32 PM »
...are you saying even when you loosen the screws on the 1/4 point and adjust it, its still firing before the F mark?
...what ever the case, does the motor even sound like it wants to start?  If the timing is even close it should run...
Offline adams77
« Reply #4 on: May 27, 2006, 08:09:57 PM »
I did not loosen the screws on the 1-4 point, just the plate itself.  I guess I have some more studying to do....frigging clymers!
amattel
« Reply #5 on: May 27, 2006, 08:57:06 PM »
I've run into the same eissue.  for me Adjusting the points gap allowed the timing plate adjustment to reach the F mark.  When the gap was off it wouldn't even sound like it wanted to start.  Once I got it right, it magickally started!!
Adam
Offline mcpuffett
« Reply #6 on: May 28, 2006, 09:12:08 AM »
you can put the retard and advance 180 degrees out as well and it wont run , mick.
cd811
« Reply #7 on: May 28, 2006, 10:02:46 AM »
go to FAQ ....the problem is the slack in the plate/housing area...tt explains it well...I had the same problem...run out of adj...take the slack out of there and there ya are
