Author Topic: Wossner big bore kits  (Read 4257 times)
Offline david 750f
  • 1976 CB750F
« on: February 10, 2012, 07:23:10 PM »
1976 CB 750F
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #1 on: February 10, 2012, 07:31:50 PM »
No experience with the company, but that seems like quite a good deal!!  Hopefully others will chime in with experience, but that's a nice kit!!
Offline dragracer
  • CB750F Dragbike
Re: Wossner big bore kits
« Reply #2 on: February 10, 2012, 10:31:42 PM »
A lot of the sport bike guys use Wossners and say good things. I'm not familiar with them myself. Give us a report if you try them.
« Reply #3 on: February 11, 2012, 11:27:19 AM »
They also make H beam rods
Offline david 750f
  • 1976 CB750F
« Reply #4 on: February 29, 2012, 09:50:03 PM »
Just some info in case anyone does a search for Wossner 836 kits. The pistons, rings, pins and clips weigh 215 grams. I believe that is slightly lighter than the Wiseco big bore kit.
David
1976 CB 750F
Online Sam Green Racing
  • Moderator
« Reply #5 on: March 01, 2012, 05:30:49 AM »
Wossner US is run by Land Speed Racer John Noonan (see post #8)
http://www.landracing.com/forum/index.php/topic,10383.0.html
The good thing about their pistons is they all come with Teflon coated skirts.
Sam. ;)
Offline Big Jay
    • CBRzone
« Reply #6 on: March 01, 2012, 09:50:11 PM »
APE is a warehouse distributor for Wossner pistons for the sportbikes. In face we are WD for every major piston supplier, Wiseco, JE. CP, MTC, Vertex, and Wossner.
Offline sorcerer
« Reply #7 on: March 01, 2012, 10:13:51 PM »
John is looking at the replacement pistons for the Sorcerer...pretty sure that's how I'm going. Glad to see they are on your list, Jay.
Jay, any ideas on the wrist pins and retention of same for these nitro motors?
Jr.
  • Moderator
« Reply #8 on: March 02, 2012, 08:39:42 AM »
Jr.
I just use a bit of copper tube, it polishes up nice to give the correct fit, I hold it in with a bit of Locktite or Superglue, they have never moved on me. This set up is nice and light. (don't do this in a road motor, it is for racing only)
For a bit of added protection, I glue a small rubber block on to the underside of the piston just in case the motor hydraulics, the copper piston pin folds and the top of the rod hits the rubber block and stops the component parts damaging one another. Make sure the rubber blocks are all the same weight, we don't want the pistons to be out of ballance........do we?
And that's before I go to the Pub.  ::)
Have a good weekend guys. 8)
Sam. ;)
Offline jaguar
« Reply #9 on: March 02, 2012, 09:03:36 AM »
sound like they could be interesting
Offline Big Jay
    • CBRzone
« Reply #10 on: March 02, 2012, 03:18:34 PM »
Jr.
Were those motors still running 15mm pins?
« Reply #11 on: March 02, 2012, 04:34:03 PM »
I would think you would want a 17mm pin.
  • Moderator
« Reply #12 on: March 02, 2012, 05:02:14 PM »
I can't get 17mm copper tude so I can't help you. ;D ;D ;D ;D ;D bed time, anebriated. ;D
Sam. ;D
« Reply #13 on: March 02, 2012, 07:02:03 PM »
Jr.
Sam. ;)
  Sam....he's not working on toilets. The only copper I want to see is the plumbing in my house. Oh...wait a minute....I remember the "galvanic response" with copper and aluminum. My God....it would make Hiroshima look like a nice holiday according to some people. ::) ::) ;) I think that is funny as Soichiro himself ordered many parts copper plated on the early race bikes. I think some people have their heads -- ----- ---
Offline sorcerer
« Reply #14 on: March 02, 2012, 07:52:57 PM »
Jr.
I'll have to get back to you on that.....Randy has the old stuff at his shop.  I was thinking about wall thickness actually....I did not know there was an OD choice back then...I hope it's the bigger pin.
Jr.
« Reply #15 on: March 02, 2012, 08:00:48 PM »
 I would gladly run 15mm if it got me in the 8's or 7's...
Offline Big Jay
    • CBRzone
« Reply #16 on: March 02, 2012, 11:43:02 PM »
The Honda uses 15mm pins. We have a tool steel pin for them that we original made for the TQ midget guys. Our smallest top fuel pin was a 17mm, that we originally did for the late Elmer Trett.
Today, the pins we make for the Spiderman McBride, and the rest of the guys, is a 20mm. http://aperaceparts.com/wristpins.html
I would have to assume that your dad making both the rods and pistons would have run the bigger pins. If not, there is no reason you can't.
« Last Edit: March 02, 2012, 11:47:50 PM by Big Jay »
